Polkfest 2012
1111213141517»
    edited October 2012
    That's certainly a decent combo, above. I've heard CJs a number of times. They're OK, but not quite warm enough for me, personally. There are a "plethora" of possibilities for a set of LSi-M 703s. I'd suggest you listen to a few amps.
    I've never heard an Aragon pre-amp, only amps--which I would also consider, if you can find a good used piece!
    I think this new series of LSi speaker, because it has a more detailed and re-engineered Vifa up top, is a little more detailed and just a tad on the brighter side, so I would (again, this is my preference) go "warmish" with the amplification whereas I would consider something a bit more neutral or even a little forward with the old LSIs.
    In any case, saving up some money is a good idea because none of this is cheap. (One reason why I'm two or three years away from upgrading my LSi-7s to LSi-M 703s!).
    cnh
  • rromeo923
    rromeo923 Posts: 1,513
    edited November 2012
    Hmmm.
    I agree I would certainly love to audition other amps and preamps w/the LSIMs.
    However, what I heard at the Polkfest demo w/the above configuration did not strike me as being bright in any manner. I am bad w/these audiophile terms but I would definitely put it on the warmer side w/a very large soundstage w/great instrument delineation. It also had a tactile feel. Anyways I cant describe it.
    I would love to hear from others who were there and see what they have to say.
    Anyone?
    I got static in my head
  • strider
    strider Posts: 2,568
    I got to play with the 703's for a bit. Never heard the set up at HQ though. Had them first in the demo tour, so they spent the first 100 or so hours breaking in, but I never felt like they seemed bright at all. I'd say the high end was relaxed. Not overly warm, but relaxed.
    At the time I was running a tube preamp and a Class A amp with about 25wpc into 8 ohms.
    Wristwatch--->Crisco
    Dubai "hot tubs"?
    No thanks, we don't need any!
    REPORTED!
    cnh
  • Anthony Hinton
    Anthony Hinton Posts: 107
    edited January 2013
    I really need to get to one of these Polkfests, seems like a really good time.
    F1nut Posts: 52,360
    edited January 2013
    Drenis wrote: »
    You and F1 don't nearly look as tough as your internet egos make you out to be.
    What ya talkin' about, I'm a sweetheart here compared to real life and trust me, you don't want to run into John in a dark alley.
  • George Grand
    George Grand Posts: 12,256
    edited June 2014
    We're getting reasonably close here no?
  • Jstas
    Jstas Posts: 15,014
    edited June 2014
    Yeah, we are. You should post in the right threads, though.
    http://www.polkaudio.com/forums/showthread.php?155407-Polkfest-2014-Official-Info-Thread
    http://www.polkaudio.com/forums/showthread.php?153864-Polkfest-2014...
    We don't get moderation around here anymore so a 2 year old sticky is still at the top.
    Expert Moron Extraordinaire
