Sony STR 6060. Worth fixing?
  • aloutah
    aloutah Posts: 241
    edited January 2012
    So, you can't even test the fuse and yet you're still asking for help on how to fix it. Hello!
    If the fuse would have popped out, I could have just bought more and tried them. No need to test it. Now that Ive seen its soldered on, I will have to take further steps in getting it looked at or serviced. Hello!!!!
  • aloutah
    aloutah Posts: 241
    edited January 2012
    Chances are the tuner works... and those Sonys had pretty good tuners in 'em. If it's not emitting smoke :-P or getting hot anywhere internally (or, jeepers, externally) take the tuner outputs from the "tape out" jacks and use it as a very good analog stereo FM tuner.
    Good Idea, I will try that tonight. Thanks
  • halo71
    halo71 Posts: 4,631
    edited January 2012
    Well, I DID look on ebay to see what that unit goes for. So I feel a little better that I did in fact help a lil' wee bit. lol If you think Joe's response was rude you need some thicker skin. He was simply stating the obvious. But anyway, I am done. As I said before...good luck to ya! :rolleyes:
    --Gary--
    F1nut Posts: 51,767
    edited January 2012
    I see Kip at AK asked you basically the same question I did,
    Do you have a DMM (digital multi-meter) to check continuity?
    When/if you tell him no, he'll probably tell you he can't help you any further and to sell it.
    As for a strong following on that receiver, you need to keep in mind that just about every receiver has a strong following on AK. Some, perhaps even most, there think that a receiver is as good as it gets. Of course, it is not. Therefore, I would take those strong following comments with a grain of salt.
    F1nut Posts: 51,767
    edited January 2012
    aloutah wrote: »
    Since you own a soldering iron, you could have removed the fuse, bought a new one and soldered it in. Hello!!!!!!!!!!!!!!!!!!!!!!!!
    mhardy6647 Posts: 35,014
    edited January 2012
    If they have a following (and it is probably a fairly small one) -- the value in those ol' Sony Rxs is in their considerably-better-than-average tuners.
    edited January 2012
    tonyb Posts: 33,072
    edited January 2012
    Not worth all the hassle in my book. Lots of vintage receivers had 4 and 5 gang tuners, nothing overly special about the Sony's. For what a repair shop will charge you, you could probably pick up another working vintage receiver off of craigslist.
    edited January 2012
    Depending on where you are. Mr. Grand has some nice receivers for sale! Including a couple of Sonys! The pricing is excellent!
    http://www.polkaudio.com/forums/showthread.php?128262-Local-Pick-Up-Audio-Stuff
    cnh
  • aloutah
    aloutah Posts: 241
    edited January 2012
    cnh wrote: »
    cnh
    Thanks for the heads up. Im in Utah though.
    edited January 2012
    Sorry about that. I don't think George ships. But maybe you could convince someone in N.J. to pick up for you and ship?
    Otherwise, CList and ebay. I just picked up an old HK 430 at a decent price on the 'bay.
    Good Luck!
    cnh
  • aloutah
    aloutah Posts: 241
    edited January 2012
    cnh wrote: »
    Good Luck!
    cnh
    Yeah, he does have some pretty good prices. No units Im really interested in though anyway.
  • George Grand
    George Grand Posts: 12,258
    edited January 2012
    That is good. With your attitude, you wouldn't be doing any shopping here anyhow.
    Listed, heavily.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    edited January 2012
    Why would anyone buy a receiver which is broken, and doesn't own a meter or know how to use it?
    And it's worth $100 bucks if it worked. I'm confused was you drunk or on drugs, when you got it?
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • aloutah
    aloutah Posts: 241
    edited January 2012
    Seriously? LOL
  • aloutah
    aloutah Posts: 241
    edited January 2012
    disneyjoe7 wrote: »
    Why would anyone post just to be an a$$? Sounds like you are more than just on drugs or drunk.
    F1nut Posts: 51,767
    edited January 2012
    You've got serious issues, seek professional help.
    heiney9 Posts: 25,432
    edited January 2012
    aloutah wrote: »
    Look in the mirror there buddy.
