Securing SDA 2B crossover boards
muncybob
muncybob Posts: 3,065
edited April 2013 in Vintage Speakers
Last night I ventured for the 1st time to the inside of my cabinets....interesting trip to say the least. What are those plastic clips called that secure the boards? Upon removal of the crossovers I discoverd that I had missing and broken clips so I need to replace them....where can I get them? I'm hoping there is a better way to secure the boards other than what Polk originally used?
Yep, my name really is Bob.
Post edited by muncybob on
  • quadzilla
    quadzilla Posts: 1,543
    edited December 2011
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
    heiney9 Posts: 25,216
    I believe you are talking about "stand offs". They can be purchased at a place like Mouser and Digikey, IIRC.
  • muncybob
    quadzilla wrote: »
    Cool idea! Looks like a possibility.
  • muncybob
    OK, next question. I'm still using the original blade/blade interconnect cable. I believe Polk still sells these...would a new one be an upgrade to the original as far as quality of materials is concerned? As far as I can tell the one I have is working as intended but if they have an improved cable then I guess it's worth it?
  • quadzilla
    No, I'm pretty sure it's the same cable.
    Arm: Rega 300
  • brgman
    brgman Posts: 2,859
    muncybob wrote: »
    Bob you said you have SDA2B's right.
    Maybe someone can answer this for us but mine are pin/blade.
    Did they make both p/b and b/b in a SDA2B? And if so can the crossovers be interchanged without issue?
    I’M OFFENDED!!!!
    Toolfan66 Posts: 17,333
    brgman wrote: »
    Yes they did and yes you can but you would need to change one driver as well.
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • brgman
    brgman Posts: 2,859
    What driver would that be sir?
    I’M OFFENDED!!!!
    Toolfan66 wrote: »
    Edit: I was thinking about CRS+'s the 2B's will have the same drivers p/b or b/b but you can still swap crossovers. The b/b 2B's will usually have a 2 piece crossover as the p/b 2B's will have the 1 piece board.
    SVS SB16 X2
  • gimpod
    gimpod Posts: 1,793
    My understanding is that the early 2B's with b/B IC (1987) had the single board style crossovers like the p/B 2B's but used the 2A cabs, I believe they are the studio version. Also the stand-offs shown in the link are for a 8-32 screw hole, I think you would need ones that fit a 6-32 screw hole as the mounting holes on the stock boards are smaller.
    I have had 3 sets of 2B's come through my house all had the wood caps top and bottom.
    1 set had P/B with single board
    1 set with B/B with single board
    1 set with B/B with dual boards
    All were stock looking boards with no upgrades when I got them now I'm not sure if anything had been swapped during the last 20 years or Polk using old parts up..
    To sets of these did end up getting upgrades by two people that I sold them too (friends at work)
    SVS SB16 X2
  • gimpod
    gimpod Posts: 1,793
    That's the fun part about SDA's "you never know what you have until you open them up", It's like Christmas morning. :biggrin:
  • muncybob
    brgman wrote: »
    Yes 2B's with single boards. I removed the board w/o taking out the inductor(?), looks like I could have/should have removed the whole assembly as one piece?
  • brgman
    brgman Posts: 2,859
    muncybob wrote: »
    would have been easier to just unbolt the whole thing from the back IMHO
    you may want to bring those
    I’M OFFENDED!!!!
  • jestwaitn
    jestwaitn Posts: 33
    edited April 2013
    Toolfan66 wrote: »
    newbie looking at a pair of SDA 2B polks. what the heck is this p/b b/b stuff? thanks. :smile:
    treitz3 Posts: 19,215
    edited April 2013
    Hello, jestwaitn. Pin/blade or blade/blade. What they are talking about is the type of interconnect cable configuration that connects the two speakers to offer you the SDA. Welcome to the forum BTW.
  • jestwaitn
    jestwaitn Posts: 33
    edited April 2013
    ok. thanks. didn't realize that there were differences in these.
    chap has a pair of the 2B for $200, which i'm considering. crossovers are upgraded & has new 3000 tweeters. haven't heard them yet. :smile:
  • ken brydson
    ken brydson Posts: 8,783
    edited April 2013
    gimpod wrote: »
    Sounds more like Forest Gump...:smile:
  • jestwaitn
    jestwaitn Posts: 33
    edited April 2013
    this might have been true on JBL also. :smile:
    F1nut Posts: 50,753
    edited April 2013
    2BTL's for $200.00? You better be in your car going to get them right now.
  • jestwaitn
    jestwaitn Posts: 33
    edited April 2013
    so that's a good deal, then?
    :question:
  • TennMan
    TennMan Posts: 1,266
    edited April 2013
    jestwaitn wrote: »
    :question:
    In good condition? Absolutely!
  • westmassguy
    westmassguy Posts: 6,850
    edited April 2013
    jestwaitn wrote: »
    Just verify the crossovers were upgraded AND modified to accept the SL3000. If the owner just replaced the caps and resistors, without adding the 5.8uf cap, they haven't been "TL'd", and will not sound their best.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • westmassguy
    edited April 2013
    muncybob wrote: »
    You'd be better off converting the old blade/blade connectors to Speakon, and making yourself a nice new cable with heavy gauge conductors. It's not that difficult, and you'll never have to worry about those connections ever again.
