Anyone know about construction? How much support am I losing? (TV riser)
kazaam
kazaam Posts: 92
edited August 2011 in Speakers
So...i messed up my measurements. I'm building a TV riser to put my TV on top of and my huge center speaker underneath of. How much structural integrity/strength/support/whatever would i lose (if any) by going from TV riser A to TV riser B? The TV + stand weighs 76.5 lbs. I will secure it with 4 large L-brackets, four 2" screws going down vertically, and perhaps adhesive. I want to add something going along the back, but the speaker has a rear firing port and this is apparently not good to do.
A:
B:
Sorry for the weird view, I havent built them yet and I was just trying to see what it would look like (I flipped the images).
THANKS!
Post edited by kazaam on
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited August 2011
    How wide is the base of the stand, is it as wide as that top piece? Can you make the top piece wider and have a build that looks closer to the first image, even if just by a little bit?
  • kazaam
    kazaam Posts: 92
    edited August 2011
    Well, thats pretty much what I planned on doing initially, and what I'm asking now. It seems like A would be the stronger TV riser, which is what i originally had planned, so i think I'll just go get another (larger) piece of wood cut so that it'll look like A.
  • kazaam
    kazaam Posts: 92
    edited August 2011
    If i want the new, revised stand to look like TV riser A, i will have to make it like this:
    stands 22" apart (so there is some wiggle room)
    factor in the extra 3/4" for each board width so thats 1.5" more
    and i guess have about 2" going past each foot on each side=4" more
    so about 27.5-28" total for the top, where the feet will be about 22" apart and the TV stand will probably be about 22" wide as well.
    On second thought though...the legs must be about 22" apart since the width of the center speaker is 21.3" (gives some wiggle room, i might even go 23" apart). The tv stand is completely flat and 21.5" long, and since the speaker must be WITHIN the stands, the tv stand and the speaker stands wont completely overlap. The center is 11.1" deep and the tv stand is 12.1" deep, but i made it 14" deep so it wouldnt be completely flush with the edge and have about 1" clearance on either side.
    I could actually just keep the current shape and add a brace. However if you all think i should go with A, I could also move the center forward a little since both faces are open, and add a brace there too.
    So i guess i could revise it like i said above and add a horizontal brace or keep it as is and add a horizontal brace.
  • newrival
    newrival Posts: 2,017
    edited August 2011
    It's likely to be just fine if that wood is of decent quality.
    The riser strength is a constant. They exert the same r1 resistant value no matter where they are if they are symmetrical.
    The variable, then, is the bracing and the top piece, which I would wager will be plenty strong given the rigid nature of the load.
    so my opinion is legs/risers at the edge with 4 internal L'brackets as sturdy and large as possible to fit intherewithout looking unsightly. plus it will lookbetter
  • jbooker82
    jbooker82 Posts: 1,627
    edited August 2011
    The one with the over hang looks better. Looks more like a shelf than a box. Make it out of a good hard wood. Use wood glue along with fasteners. I bought a tv riser 2. It is black and made out of hard wood stained black. I glued it together and put a couple 2.5 in black sheet rock screws. It holds my 100lb plasma tv fine. No wrapping or bowing at all.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • gdb
    gdb Posts: 6,012
    edited August 2011
    Use either oak or yellow pine stair tread stock, either design will support an elephant!:wink:
  • jbooker82
    edited August 2011
    Here is my tv stand. It will fit a csi a4 but not an a6.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • jbooker82
    edited August 2011
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • Ronster267
    Ronster267 Posts: 60
    edited August 2011
    Why not just get a wall mounting bracket for the T.V.? I got a great wall mount from amazon for $33.00 and it will support up to 165 lbs. It was easy to install and looks great too. You could then put whatever center you wanted right on the stand you were going to put the riser on.
  • JimAckley
    JimAckley Posts: 1,138
    edited August 2011
    I would give it a slight overhang like booker's. If you're worried about strength, you could have a piece in the back that will help support the legs. Here's a rather crude and quickly-drawn SketchUp I made of it with the piece I'm referring to, colored in bright red. You don't necessarily have to add the slant, but it would futher help bear the weight, or if you've got the room, you could make it bridge all the way across for rock solid support.
    Here's what I'm talking about:
    Back/bottom angle, separate pieces
    Back/bottom angle, bridged piece
    Front/bottom angle, bridged piece
    Just remove 3/4" from the depth of your legs (or whatever thickness material you're using) to compensate for the added piece of wood in the back.
    If you wanna get real fancy, snag some black fabric to make a curtain that will hang along the top and sides of your speaker, so nobody can see what you did in the back for support, and hang it near the back of the speaker so it looks like the speaker goes off into the dark abyss without your "curtain" being visible. Plus, it will hide the wires, which helps ever so slightly with WAF
    - Computer Rig -
    YAΘIN MS-20L, polkaudio RT5
    - Main Rig -
    Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
    - Currently In Progress -
    Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
  • 20hz
    20hz Posts: 636
    edited August 2011
    I would do it with a full length back support piece that hangs down at least 3inches down on the back (make sure its deep enough for the center)
    With that you will get strength without the front looking too thick .
  • jbooker82
    edited August 2011
    Ronster267 wrote: »
    I would but I just rent and didnt want to put big holes in the wall. I guess I am to nice of a tenant.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • kazaam
    kazaam Posts: 92
    edited August 2011
    Wow, thanks a lot Jim for the models!
    What type of wood would you suggest I use? How much of an overhang would you suggest on either side? Is 2" enough, or can I go 1"?
    Thanks!
  • jjwm27
    jjwm27 Posts: 123
    edited August 2011
    jbooker82 wrote: »
    got mine on the wall with the Lsic under it, i guess im not that nice of a tenant. thats a very nice stand you got there by the way, i like it.
  • kazaam
    kazaam Posts: 92
    edited August 2011
    Indeed, Booker what wood did you use and how much of an overhang is there on either side?
  • engtaz
    engtaz Posts: 7,669
    edited August 2011
    Look very good. Great work.
    engtaz
  • Geoff4rfc
    Geoff4rfc Posts: 2,839
    edited August 2011
    Ronster267 wrote: »
    jbooker82 wrote: »
    If you were ever considering the wall mount, DO it. You can still be "that" nice of a tenant. I've relocated my wall mount twice, just fill in the holes with sheet-rock mud, spray texture if needed and paint, pretty easy fix and not at all expensive if materials are bought in small quantities.
    Heck, when I owned my home, I had all kind of holes in the walls from various attachments, mudded, some sanding, little texturing, paint and presto, never knew anything was ever on the wall.
    Set up:
    Marantz AV8802A - Sources: BRP Panasonic 9000/CDP Emotiva ERC 3 - Display: LG OLED EVO 83 C3 - Amplification: Emotiva XPA-DR3, XPA-6, XPA-2 x 2 - Speakers: Focal/PolkAudio, Mains/2ch - Kanta No2, C - LSiM706, SS - LSiM702, WS - RTiA9, RS - RTiA9, FH - RTiA3 - Subs: Epik Empires x 2
    Cables: AQ McKenzie XLR's from CDP to AVP to amp for 2ch, Emotiva XLR's for the rest - Douglasconnection: Furutech Alpha 36 12g speaker wire for 2ch, Furez 10g speaker wire for the rest - AQ Forest48 HDMI for the display, AQ Carbon48 HDMI from BRP to AVP - VR3 filtered power cables for CDP, BRP and AVP, Emotiva power cables for the amps - AudioQuest 505 power conditioner.
  • mantis
    mantis Posts: 17,410
    edited August 2011
    What Kind of Tv is it? If it's a flat panel have you considered wall mounting?
    Dan
  • CCNJ
    CCNJ Posts: 384
    edited August 2011
    I'm no expert but I do dabble in small woodworking projects. The straight "Butt Joint" is the weakest woodworking joint. I've used it successfully as a center channel stand but I think I would use something more to reinforce if it's going to hold an expensive and heavy TV. I think JimAckley made a good suggestion is his previous post along with using wood glue to solidify the joint.
    You could also consider something called a "Rabbet Joint" which is much stronger joint. You would need a router or a table saw however to make the cut outs.
    Good Luck
    Rig1 - Totem Hawks, Benchmark HDR, Parasound A21, Sonus, Samsung 52 LCD, Audioquest Type4
    Rig2 - LFD LE IV Integrated, Harbeth P3ESR, Rega Dac, MF V-Link, IMAC, Audioquest Type4
  • jbooker82
    edited August 2011
    I bought my stand from ebay but it can be bought from amazon too. It is call " TV Riser Two" by Wood Tech.
    http://www.amazon.com/Wood-Tech-TV-Riser-Two/dp/B0043WG9H4/ref=sr_1_4?ie=UTF8&qid=1313864979&sr=8-4
    Here is the MFG's web site. It doesnt say what kind of hardwood it is made up of. It is heavy and deffinatly not made up of a soft wood.
    http://www.wood-tech.com/content/tvriser2
    It has 3 sets of holes so you can make it wide or narrow. I put mine on the out side so it is as wide as possible.
    It uses 2 cam bolts and I think (cant remember) 2 dowls on each side support. The cam bolts are those long steel bolts with a big head on them. They stick out of the wood like a wooden dowl. Then in the other pice they go in to a metal disk that you turn to lock it in place.
    I just drilled two pilot holes inbetween the two cam bolts on the top plate from the bottom. Then assembled it dry and used the holes that I just drilled to drill the pilot holes in side supports.
    I used my dremal to remove the finish on the end of the support / leg, and the bottom of the top plate so the glue would bond to the wood and not the black finish.
    Added glue then assembled it like the instructions stated. Finally put two sheet rock screws in and repteaded on the other side.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • Gadabout
    Gadabout Posts: 1,072
    edited August 2011
    kazaam wrote: »
    If it is wide enough for you, Home depot carries Oak Stair Tread. It already has a radius cut on one edge (if you don't have a router). It is almost 1" thick and incredibly thick. All you should have to make are a few straight cuts.
    My guess is it would never bow with a static load of 100 lbs on it. Sand it well and stain it the color of your choice.
    Scott
    Without music to decorate it, time is just a bunch of boring production deadlines or dates by which bills must be paid. ..... Frank Zappa
  • fyrn
    fyrn Posts: 146
    edited August 2011
    I think this has been cover before, so mostly to reiterate.
    The only two issues I see is the width of the stand (distance between the two legs) make sure the "shelf" material is thick enough to support the weight.
    And two I would give the stand some support/bracing to prevent lateral movement. A simple front frame or a "hanging strip" in the back should do.
    Just my two cents
  • gdb
    gdb Posts: 6,012
    edited August 2011
    To reinforce against "racking" you can just screw some steel corner irons on the back of the shelf/leg or..........make dadoes if so equipped.:wink:
  • jbooker82
    edited August 2011
    If you look at my pics you can see the rubber feet on the tv base are close to the side support / legs. There isn't any weight in the center.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • kazaam
    kazaam Posts: 92
    edited August 2011
    So I built it and it fits!
    I tried taking your advice as much as I could.
    I used TV riser B so I wouldn't have to buy more wood, glued the pieces together, screwed three #10 2" screws down vertically on each side, used 4 L-brackets about an 1-1/2" in with 4 #8 3/4" screws in each one. Then, there was a 2-2-1/2" piece that was as long as the entire thing, so I glued it to the back and screwed it in with 6 #10 2" screws. This piece was screwed into the feet and into the top board, and acted as a skirt/brace/lip. The glue was liquid nails.
    The damn thing is solid and fits almost perfectly!
    Now I just need to figure out how to cover it with a black fabric and figure out where to buy that fabric!
  • JimAckley
    edited August 2011
    Hobby Lobby, Michaels, etc.
    - Computer Rig -
    - Main Rig -
  • kazaam
    kazaam Posts: 92
    edited August 2011
    As long as the rear port is open and the speaker has room its ok, right? Theres very little clearance on either side (probably like .25" all around) on the front, but speakers dont get hot/need room or anything as long as the face is completely open and exposed, right?
  • gdb
    gdb Posts: 6,012
    edited August 2011
    kazaam wrote: »
    There is a thread completely devoted to how to find black paint, if that's any help.:wink:
    http://www.polkaudio.com/forums/showthread.php?t=29186&highlight=black+paint
  • JimAckley
    edited August 2011
    kazaam wrote: »
    As long as your port can flow freely, you should be good
    - Computer Rig -
    - Main Rig -
  • kazaam
    kazaam Posts: 92
    edited August 2011
    Front:
    Front showing lip:
    Back:
    Underside (from front):
