best way to repair surround?
soundfreak1
soundfreak1 Posts: 3,414
edited September 2011 in Vintage Speakers
Have a driver with a small tear in the surround. Tape, glue, if glue, what kind. Just a quick fix till replaced. Thanks
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
Post edited by soundfreak1 on
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited August 2011
    I am in the same boat with a center channel that I moved to the rear . The hole in my cone is right next to the rubber
  • Joe08867
    Joe08867 Posts: 3,919
    edited August 2011
    Rubber cement, Gasket sealant, I have used both.
    Rubber cement worked quite well and almost disappeared.
    Gasket Sealant was same color and blended right in.
    Use either from the back of the cone not the front for better appearance.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited August 2011
    Tub caulk.
  • TNRabbit
    TNRabbit Posts: 2,168
    edited August 2011
    Clear silicone; applied a very thin layer to the area. It works great for a temp fix when foam surrounds begin to disintegrate~
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • RuSsMaN
    edited August 2011
    Macaroni.
  • gimpod
    gimpod Posts: 1,793
    edited August 2011
    and cheese.
    mhardy6647 Posts: 35,047
    edited August 2011
    If the surround is foam, it is best to replace it. Replacement foam surrounds are available from numerous vendors, both generic and driver-specific. A popular one, for example, is www.partsexpress.com
    Rubber surrounds are probably best repaired with a combination of a single-ply of toilet paper (or artists'/modelers' tissue paper) behind the tear and rubber cement or a flexible cement such as "GC Service Cement" (available from local or on-line electronics parts/supply houses). It won't hurt to saturate the TP with the cement, too. You want the repair to be strong, flexible, but light in weight -- not to mention, ideally, airtight.
    BEFORE: Rotted Pioneer HPM-1100 (JBL-esque) foam woofer surround, undergoing a CAT scan.
    Results of CAT scan:
    AFTER: Repaired woofer - this somewhat specialized woofer deserved, and got, a non-generic surround.
    Cheese is good in a pinch.
    Tony M Posts: 11,625
    edited August 2011
    Great 5-star surround replacement job!:wink:
    I've yet to do one but I need to get to it since I have many advent,JBL and one set of Cerwin Vegas woofers waiting and I now have a little spending cash.:smile: I start with the Cewin Vega of course..
    edited August 2011
    heh. my first surround replacements were a pair of C-Vs. Perfect fodder for practice :-) Bought the PE kit with the charming and appropriate red foam.
    They served my son well for years.
  • soundfreak1
    edited August 2011
    Thanks for the good responce and detail info mhardy also nice looking job on the repair. Thanks again.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • soundfreak1
    edited August 2011
    Btw great cat scaner! Got one almost identicle to it.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • drumminman
    drumminman Posts: 3,396
    edited August 2011
    Got it at Lowe's. The package says it's their most durable, and stays flexible. Especially good for rubber.
    I used it to seal a small hole in the surround on one of my MW's that now serves as a back up.
    edited August 2011
    De nada; just showin' off :-p
  • DON73
    DON73 Posts: 516
    edited August 2011
    Looks better than some so called professional repairs!
    TO ERR IS HUMAN. TO FORGIVE IS CANINE.
  • DON73
    DON73 Posts: 516
    edited August 2011
    Those reds on one of my Advents would make the others laugh (to hide their envy)
  • rebuy
    rebuy Posts: 695
    edited August 2011
    You can always use the Handy Mans secret weapon, Duct Tape.
    Those silver surrounds and cones will be nice.
  • RuSsMaN
    edited August 2011
    Boogers.
    edited August 2011
    RuSsMaN wrote: »
    Boogers.
    are you channeling Dr. Johnny Fever, Russ?
    OK, rubber cement and toilet paper or the equivalent on the back of the rubber surround?
    Trying to repair a couple of tears in Monitor 5 mids and also 'reattach' the surrounds? What substance would you use to secure the rubber surround to the assembly itself?
    I have a tear in one mid and some leaks in the other because some 'genius' tried to install the mid screws without first cutting out some of the rubber surround so that the screws would NOT tear them to pieces as they were being turned! And I'm supposed to be technically incompetent. At least I know not to do something this stupid.
    Almost ruined the Monitors, but I think we can save them. They play, they're fine--but leaking air through less than perfect surround seals and surround tears doesn't cut it.
    Many thanks!
    cnh
  • Joe08867
    I use Epoxy to secure the surround to the Frame and Rubber Cement to fix tears in the surround itself.
    Thanks Joe. Where can I pick that up? Hardware store, Auto store?
    cnh
  • Joe08867
    Hardware store. I usually get the kind in a split tube you mix. You don't need much and I try to make it as thin as I can or you can see a bump. Not pretty that way.
    Sounds good. Have an Ace Hardware about two blocks away!
    Thanks!
    cnh
  • halo71
    halo71 Posts: 4,632
    You didn't try to stick a banana plug in it did you?:tongue:
    --Gary--
    Looks good there. I still haven't gotten around to it. I put two big amps in for fixing. The bill comes next week. Then I might order my practice surrounds.:wink:
  • soundfreak1
    Used the silicon method , worked fine just a little ugly but works perfect. Will replace speaker when can but it works. Thanks all for thw ideas.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
