Need saw / blade recommendation
kevhed72
kevhed72 Posts: 5,172
edited May 2011 in The Clubhouse
I need to cut 6 laminated stock shelves...I imagine they are particle board under the laminate. The boards are 36" by 12", and I need to cut 3" off the length. What blade / saw do you all recommend as to keep a super-clean cut.
I own a miter saw, circular saw, and jig-saw....the miter saw will not make 1 clean cut due the blade is smaller than 12"....
Post edited by kevhed72 on
    treitz3 Posts: 20,153
    edited May 2011
    IME, I have never had a super clean cut on particle board as it's not made for that. Not quite sure what you are asking, really...
    Circular saw I'm guessing would be my answer but a table saw would be more precise.
  • seeclear
    seeclear Posts: 1,244
    edited May 2011
    I would expect the cleanest cut with a blade with a lot of teeth, and go slow.
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
    txcoastal1 Posts: 13,519
    edited May 2011
    Tape down your cut area with painters tape helps keep laminate intact on the bottom side of the cut, use a fine tooth blade
  • greyford1979
    greyford1979 Posts: 749
    edited May 2011
    Also tape the cuts that you will be making and it will help keep the laminate from chipping. I always do this when cutting veneered ply and does the trick to keep it from chipping:biggrin: oops I guess I was too late:redface:
    I love animals, they're delicious!
  • kevhed72
    edited May 2011
    Thanks folks...this is one of the last steps in a custom shelf unit for HT room.
    Here's the link to when the project started:
    http://www.polkaudio.com/forums/showthread.php?t=114645
    The shelves are going in the cubby in the first pic:smile:
  • DON73
    DON73 Posts: 516
    edited May 2011
    kevhed72 wrote: »
    A circular saw with a fine (many) tooth blade. You'll need to clamp a guide on the shelf material for the saw to rest against.
    TO ERR IS HUMAN. TO FORGIVE IS CANINE.
  • gdb
    gdb Posts: 6,012
    edited May 2011
    Try a triple chip blade on your circ saw using a guide/fence to run the saw's shoe against. P.S. 71/4" triple chip blades are rarer than 9-10-12s the one below is a little expensive but will give the best possible cut with a hand held saw.
    http://www.amazon.com/Oldham-725P7260-4-Inch-Carbide-Surface/dp/B000LOIK0C/ref=sr_1_fkmr0_1?ie=UTF8&qid=1304881085&sr=1-1-fkmr0
  • TNRabbit
    TNRabbit Posts: 2,168
    edited May 2011
    txcoastal1 wrote: »
    DON73 wrote: »
    gdb wrote: »
    Ditto to the above.
    In my experience, you get the cleanest cut by cutting from the bottom so the saw teeath are coming UP into the taped laminate side.
    TNRabbit
    NO Polk Audio Equipment :eek:
    Sunfire TG-IV
    Ashly 1001 Active Crossover
    Rane PEQ-15 Parametric Equalizers x 2
    Sunfire Cinema Grand Signature Seven
    Carver AL-III Speakers
    Klipsch RT-12d Subwoofer
  • seeclear
    edited May 2011
    txcoastal1 wrote: »
    DON73 wrote: »
    Yeah, FINE tooth, that is what I was trying to say!:wink:
  • FTGV
    FTGV Posts: 3,650
    edited May 2011
    Thin kerf 60 or 80 tooth.
  • kevhed72 wrote: »
    Buddy i think rip saw will be best in this case for you as it make a rip cut across the wood.
    And we can use these blades to cut the wood across the surface and over the stock.
    Your 6 laminated stock shelves can be cut down by rip saw.
    If you are good in woodworking then you can make super-clean cut using it.
    you can check this blog to get idea about Buying guide before purchasing it.
    Best regards
    audioluvr Posts: 5,996
    Jamesfreak9 reported.
  • invalid
    invalid Posts: 1,539
    FTGV wrote: »
    This is what I used to cut countertops and cut it from the bottom with a circular saw. I usually clamp a board with some scrap boards to the bottom so the base of the saw has something to ride against for a straight cut.
  • TEAforONE
    TEAforONE Posts: 1,083
    If you go the circular saw route,use a carbide tooth blade. 60-80 tooth as mentioned above,and use the painters tape as well.
  • ken brydson
    ken brydson Posts: 9,039
    You guys know this is a 9 year old thread revived by a spammer, right?
    pitdogg2 Posts: 27,412
    Party pooper 😹😂
    msg Posts: 10,486
    Good tips though. And Kev might still be in the planning phase.
  • TEAforONE
    Now I really feel silly!
  • kevhed72
    edited September 2020
    For the life of me I cannot remember what project this was....
    msg Posts: 10,486
    haha, looks like you started it when it was the old forum.
    Here's an adjusted link
    https://forum.polkaudio.com/discussion/114645
    Ring any bells?
  • maxward
    maxward Posts: 1,720
    But I’m sure you used the right blade.
  • kevhed72
    Ahhh. My idea at the time turned out to be a bust. I would post a current pic but the room is piled high with the hoarder/wife stuff due the flooded office. I'll update with a pic soon....
    John 1189 reported
