Could 1Bs be converted to 1Cs?
quadzilla
quadzilla Posts: 1,543
edited May 2011 in Vintage Speakers
So... I don't seem to be finding any SDA 1Cs in my area, but I am finding 1Bs. So, if I switched out the xovers (would be done anyway), and maybe the drivers (if needed), could I turn them into 1Cs?
Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Post edited by quadzilla on
    F1nut Posts: 51,786
    edited April 2011
    Why bother? Get the 1B's and be happy.
    pitdogg2 Posts: 27,056
    edited April 2011
    I was thinking the same thing. Get what you can get and make them the best you can.
    heiney9 Posts: 25,440
    edited April 2011
    quadzilla wrote: »
    Not really, the expense and effort still wouldn't make them 1C's. The biggest difference (in the end) being the cabinet structure which you could never replicate.
    X-over replacement, driver replacement would cost A LOT and you'd never get close to your investment out of them.
    1B's are no slouches, so be content if you find a pair of those.
    F1nut Posts: 51,786
    edited April 2011
    Adding to that.....the 1B's cabinets are the same as the 1C studio version.
  • gimpod
    gimpod Posts: 1,793
    edited April 2011
    I have to agree with everyone on this one. It's would cost more to turn your 1B's into 1C's than what you could get a pair of 1C's for and you still wouldn't have 1C's you'd have heavily modified 1B's. I know 1C's can be hard to find but if your hearts set on getting them save your money and keep your eyes pealed.
    And to Quote H9
    Bottom line IMO it's just not worth the time and trouble.
  • RuSsMaN
    RuSsMaN Posts: 17,986
    edited April 2011
    I know the pair you are looking at, I don't know why he hasn't been able to sell them - they look super clean in the pictures. The price isn't bad either.
  • Schurkey
    Schurkey Posts: 2,122
    edited April 2011
    Yep.
    Get the 1Bs, add the 198 tweeters along with the crossover mods. You won't be able to use non-common-ground amps; but other than that I don't think you're giving up much to the 1C.
    Others may disagree.
    F1nut Posts: 51,786
    edited April 2011
    Slight correction....the 1B's can only use the RD0194-1 tweeters.
    edited April 2011
    That's true but I was speaking of standard 1C's.
    edited April 2011
    Schurkey wrote: »
    Yep.
    Probably not giving up much, but enough to still want 1C's if that's what your heart is set on.
    The 1C's have a simpler x-over which yields a more natural SDA experience. 1C's (except early) use different more advanced drivers (side wound voice coils) compared to 1B's and the ability for most 1C's to use the AI-1 cable for non-common ground or mono amps. The non-studio cabinet is also a little better and damping and vibration control.
    While all these things singularly don't seem to mean much...........add them together and 1C's are a little better than 1B's.
    That said if you can find a nice pair of 1B's for a good price locally, go get them.
  • DarqueKnight
    DarqueKnight Posts: 6,765
    edited April 2011
    quadzilla wrote: »
    I have owed 1B's and 1C's. I would hold out for a pair of (later model) 1C's with the oak top and bottom caps and pin/blade SDA cable. Some of the earliest (transitional) 1C's used 1B cabinets and the blade/blade SDA cable. The later 1C's used a new and improved cabinet in addition to improved crossovers and different drivers.
  • quadzilla
    edited April 2011
    Paitence sucks, but it sounds like that's the way to go.
    Arm: Rega 300
  • Schurkey
    edited April 2011
    Unless you rip out the 4.4uf cap in each crossover and replace them with 5.8uf caps. (As pioneered by inspiredsports on his almost-identical SRS 2 Blade/Blade speakers) Then the 198 works just fine.
    5-page thread, but only the last few pages are interesting.
    http://www.polkaudio.com/forums/showthread.php?t=74946&page=5
    Toolfan66 Posts: 18,067
    edited April 2011
    Later Model 1C's gets my vote!! as a matter of fact I should pull them out and give them some juice!!!
  • RuSsMaN
    edited April 2011
    I think they would be neat to own. Everyone has c's.
  • quadzilla
    edited May 2011
    Yeah, I know I have some SDAs, and extremely nice ones at that. But they just make me want a pair of 1Cs all the more. Yes, I know I'm a greedy feckless ****. And no, I don't care. I want what I want when I want it :)
    TFL, if you aren't using your 1Cs, you oughta sell 'em. To me. Or something....
    Arm: Rega 300
    edited May 2011
    quadzilla wrote: »
    ummm no!!!:cool: I pulled em out Friday and have them running. + I have a total of $1100.00 into them + my time and labor so I will be sitting on them for a while:wink:
  • quadzilla
    edited May 2011
    Bah... I've got about 800 in my CRS+s, so I feel you. But I still think you should sell them. They're obviously beneath you.
    Arm: Rega 300
    edited May 2011
    quadzilla wrote: »
    I'm working on my CRS+'s now, just got started on my custom stands yesterday at work should be done by the end of next week. The only thing I got left to do is upgrading the crossovers, and making some custom brass spikes for my stands. There will be about $800+ into these as well..
    The 1C's are not beneath me:confused: they are a great speaker..:wink:
  • quadzilla
    edited May 2011
    <waving hand, speaking in very soothing, slightly gravely voice> These are not the speakers you want. You will sell them now.
    Arm: Rega 300
  • DarqueKnight
    edited May 2011
    Jedi mind tricks do not work on SDA Cultists.
  • dorokusai
    dorokusai Posts: 25,576
    edited May 2011
    Agreed. There's no reason to worry about a conversion here, just mod them if you're restless....or keep looking.
