New crossover boards 1C's and 1.2tl's
Toolfan66
Toolfan66 Posts: 18,292
edited March 2011 in DIY, Mods & Tweaks
I have spent most of the day working on my new Crossover boards for my 1C's and my 1.2tl's from gimpod (1C's) and DK (1.2tl's). the hardest part is getting through the hot glue to take the inductors off the original boards.. :frown: what a pain in the ****!!
These new boards are awesome to work with and my solding skills are top notch as well,very pleased how they are coming out.:cool:
Sorry Jesse but I had to try it my self..:tongue: The solding station was worth every penny and then some, made life much easier..
Doubt I will get them in to take a listen today,but soon..:wink:
Will post pics soon...
Post edited by Toolfan66 on
  • ben62670
    ben62670 Posts: 15,969
    edited February 2011
    Which soldering station did you get?
    Ben
    ben62670 wrote: »
    Weller Wes51.
    I will post pics of the 1C's after the battery charges
  • Systems
    Systems Posts: 14,872
    NICE!:eek:
    Testing
    Testing
    Testing
  • On3s&Z3r0s
    On3s&Z3r0s Posts: 1,013
    Damn, that's pretty... just some seriously top-shelf work.
    The upgraded original crossovers are the set Ben did almost two years ago..
  • Conradicles
    Conradicles Posts: 6,396
    Those are sooooo sweet, wish I could get a set for my LSi9's, hint hint...
  • Face
    Face Posts: 14,340
    Nice work Larry!
    The crossover of the LSi9 is simple in comparison. Cut a .5" strip of MDF narrow enough to fit through the woofer's hole, and build a point to point crossover on it.
  • newrival
    newrival Posts: 2,016
    damn that is some cleeeean solder work.
    They really did a killer job on laying out those new boards too.
  • cincycat13
    cincycat13 Posts: 887
    any concerns with the small inductors located that close to each other in the same direction? it could just be the purist engineer in me but I thought that was bad practice? looks great tho!
  • geoff727
    geoff727 Posts: 546
    Beautiful improvement Larry!
    G~
    Polk SDA SRS 2
    Polk RTA 15tl
    Polk Monitor 7C
    Polk Lsi9
    Infinity RS-II (modded)
    Infinity RS-IIIa (modded)
    Infinity RS 2.5 x 2
    Magnepan 1.6QR (modded)
    System: http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1290711373
    F1nut Posts: 52,158
    Looking good Larry. Tony's boards make it easy, don't you think?
  • DarqueKnight
    DarqueKnight Posts: 6,765
    cincycat13 wrote: »
    The inductors are actually at a right angle to each other. However, even if they were in line with each other, it probably wouldn't have any audible effect: Loudspeaker Inductor Crosstalk Measurements
    Two of the inductors were side by side on the original boards.
  • gimpod
    gimpod Posts: 1,793
    Nice job TOOLFORLIFEFAN, Now we just need to see the pics for the 1C's
  • thejck
    thejck Posts: 849
    are the boards GA yet? or we still testing?
    I got all my crossovers in today,and all is working well. I only listened to my 1C's for about half an hour,and moved them out of the way to finish up my 1.2tl's.I was really curious about them since I changed the inductor as well with this setup. Both set of boards work great and really clean them up. I was lucky enough to have two sets of 1.2tl crossovers so I didn't have to take apart the work Ben did for me on my original set,and I can A/B test if I want too.
    Again a very fun project..
    Thanks again DK and gimpod...
  • gimpod
    gimpod Posts: 1,793
    edited March 2011
    No offense, but maybe one of these day's and your thought's if it's not to much trouble.:confused:
    edited March 2011
    gimpod wrote: »
    I plan on giving them some listening time this weekend...:tongue:
  • gimpod
    gimpod Posts: 1,793
    edited March 2011
    That would be COOL seeing how I'm going to go ahead and order up a run of boards Monday. BTW did you get my last PM ? and if so could you respond by PM I would really like to know what you think.
  • analog97
    analog97 Posts: 328
    edited March 2011
    Please don't rush. Your efforts are too valuable! Please consider waiting until all the beta folks test the boards on all the SDA models for which you have designed your board. Just a friendly caution here.......:smile:
    edited March 2011
    I will say this the boards make everything simple to follow and solder together. it seems Gimpods boards will work on most SDA's, I could have used them in my 1.2tl's as well as my 1C's I see no problem in them.
    I will say one thing about the inductors,and that is I will be doing it in my 1C's as well. Yes they do make a difference a big one at that.. I'm not sure there is much left that is stock in my 1.2tl's...
    For gimpod being a newb "if you will" the guy has done a fantastic job in a short time here..
  • schwarcw
    schwarcw Posts: 7,360
    edited March 2011
    Hi Larry!
    Nice job! I am a little confused from your post and the pics, which inductor(s) did you replace? Just the big one?
    Regards,
    Carl
  • fbm211
    fbm211 Posts: 1,488
    edited March 2011
    Yes larry, tell us about the inductors.
    I plan on doing my 2Bs with these new boards and should probably go with new inductors too.Id like to tackle the whole thing and not have to upgrade something later.
    SDA-2BTL with custom IC
    Harman Kardon T-55c TT
    DH LABS REVELATIONS ICs-amps
    Revelation Audio Labs Paradise cryo-silver ICs-Source to pre
    edited March 2011
    Sorry bout that, Yes I just changed the big inductor with a North Creek 16mH inductor in my 1.2tl's.
  • fbm211
    fbm211 Posts: 1,488
    edited March 2011
    Will that work in all the SDAs?
  • On3s&Z3r0s
    edited March 2011
    Since we're bugging you with inductor questions... what wire gauge did you use? It looks like North Creek's smallest is 14 and the schematics use 18ga.
    edited March 2011
    I used 14ga, and yes you can do this to all SDA's.
    edited March 2011
    Looks like my 1C's use the same size inductor as my 1.2tl's (16mH) and my CRS+'s use a 16mH..
