Reason to be concerned?
brettw22
brettw22 Posts: 7,623
edited August 2003 in Flea Market
Post edited by brettw22 on
  • Strong Bad
    Strong Bad Posts: 4,278
    edited August 2003
    Cat5e cable for the speakers will be included. What the hell do you use networking cable for on a set of speakers?
    Makes ya go...hmmmm
    Be interested to know if anyone out there knows.
    John
    No excuses!
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited August 2003
    A new alias for the beloved Scott Trigg?
    It's possible. The registration date shows 1998, I'm doubting he would be able to keep an ID open THAT long, without ripping someone off.
    Cheers
    Russ
  • brentski
    brentski Posts: 96
    edited August 2003
    I don't know the story on this one, but one way to find out info about the seller, is to pull up one of the previous transactions from his Ebay feedback and e-mail the person who's previously purchased from him and ask them about a name or whatever "special item, term , location" that will let you know if it's "the someone you want to avoid"
    Maybe this is old hat here, but I've found it to be a invaluable way of finding things out about a seller in the past.
    Center; CS-400i
    Main's; RT-55's
    Side Surround's-RT-35's
    Rear center;CS-300
    Sub; SVS PB12-NSD
  • madmax
    madmax Posts: 12,434
    edited August 2003
    It said location US. Did you see indiana anywhere? Looks like a takeoff of a good name on this site. Scares me already!
    madmax
    Vinyl, the final frontier...
  • mantis
    mantis Posts: 17,632
    edited August 2003
    John,
    the whole cat5e thing is nothing more then a bunch of bored people looking for the cheap alternitive to buying real wire.Cat5e is about as cheap as it gets so some chump desided to create a cat5e speaker wire,braid it,put nice ends on it and fool people into believing it's great speaker wire.........try it yourself and form your own opnion........
    Personally I have tried it out of sheer curosity.........results........piss poor.
    Point here is use the correct cable for the correct job.Rg59 are not interconnects and cat5e isn't speaker wire.There are reasons cables get designed for there purposes..........not to be interchanged with other duties........I don't know why this is so hard to understand..........
    Dan
    F1nut Posts: 52,268
    edited August 2003
    Madmax,
    He says in his ad......"Lafayette, Indiana."
  • RuSsMaN
    edited August 2003
    My braided Cat5 sounds great! Cheap? Hardly, once you spend the long hours stripping and braiding. The conductors are smaller, but there can be twice as many (compared to kimber). The idea behind it is to use a similar wire geometry.
    Not the best wire I own, but not the worst either. Tweek, experiment, it's all a learning process.
    Cheers,
    Rooster
  • fgr41
    fgr41 Posts: 432
    edited August 2003
    Sounds like he is about an hour from where I live. YES ITS NASHCAR ****-RE, but don't hold it against me. IMHO if the car doesnt turn left and right than it belongs on dirt.
    Long live F1, CART, and Karting!
    Front
    Polk RT800i (BI-wired)
    Rear
    Polk RT600i
    Center
    Polk CS400i (BI-wired)
    Sub
    SVS 25-31PCi (22Hz tuning port)... it's SubHuman
    Receiver
    YAMAHA RX-V1400
    TV
    Mitsubishi WT-46807 HDTV
    HD receiver
    T i V o HR10-250
  • madmax
    edited August 2003
    :confused:
  • fgr41
    fgr41 Posts: 432
    edited August 2003
    Originally posted by madmax
    :confused:
    NASHCAR = redneck way of saying NASCAR
    ****-RE = redneck way of saying country, sounds like (**** ree)
    Front
    Rear
    Polk RT600i
    Center
    Sub
    Receiver
    YAMAHA RX-V1400
    TV
    HD receiver
    T i V o HR10-250
  • gidrah
    gidrah Posts: 3,049
    edited August 2003
    http://www.tnt-audio.com/clinica/triple_t_e.html
    Mantis is right! It's communication cable. So what if it's teflon over individual copper strands. It probably sounds like when you call a fax line.
    :rolleyes:
    It might not be Trigg. This guy has positive feedback.
    Make it Funky! :)
  • rskarvan
    rskarvan Posts: 2,374
    edited August 2003
    I e-mail'd the guy to check if it was Trigg. Doesn't appear to be.
  • madmax
    edited August 2003
    Well at least we know now.
    madmax
