Xbox 360 Experts
jimmydep
jimmydep Posts: 1,305
edited January 2011 in Troubleshooting
My son's Xbox 360 is giving him trouble, it won't play the new game Black-ops. It doesn't even load the game, so he never gets to the intro screen.
He gets a disk error message while playing his other games after 15 to 30 minutes of play time.
I bought a new disk drive and swapped out the control board with the same results.
Just so you know I don't play video games and never use his system, so it's probably something simple.
any suggestions would be appreciated.
Jimmy
Post edited by jimmydep on
  • mantis
    mantis Posts: 17,611
    edited January 2011
    Hook it up to the internet and get it updated. The Xbox 360 is a very flawed machine. You might have to have it serviced , this is very common.
    Dan
  • jimmydep
    edited January 2011
    Thanks Dan, I'll try to update it and see if that works.
    Jimmy
  • dvran
    dvran Posts: 280
    edited January 2011
    Make sure there is enough hard disk space. I believe Black Ops is about 3-4GB. If there is not enough space, delete old games not played.
    Make sure you're connected to the web to recieve updates.
    Finally, make sure the parental controls are turned off to allow him to play rated M games. You'll find this in the Xbox setup menu.
    ~Dan
    Projector: Epson 705HD on 106" DaLite
    TV: Samsung 50" Plasma PN50B550
    Receiver: Onkyo 607
    Fronts: Polk 1000i
    Center: Polk Csi40
    Rears: Polk Fxi30
    Sub: Velodyne Minivee 10
    PS3 and Xbox
  • xKYLEx
    xKYLEx Posts: 6
    edited January 2011
    What kind of Xbox 360 is it? For example, is it white or black, arcade or elite, the thick version or thin version? Also if you look on the back of the Xbox there is 3 different numbers, MFR Date, Serial Number, and Product ID. Let me know more of a description and I'll do everything I can to help you out.
    I had one of the very first 360's and what you're describing is what happened to mine before the dreaded RROD (Red Ring of Death).
  • jimmydep
    edited January 2011
    I don't know what it's called but it has a white slightly curved case with a black face plate. Manufacture date is 2006-07-22.....ID#77109201059992162907.
    I did go to Microsoft's website and downloaded the update, and I still have the not reading the Black-ops disk problem, other games seem to play ok. I had the disk checked out on another machine and it worked fine.
    Thanks for your help
    Jimmy D
  • xKYLEx
    xKYLEx Posts: 6
    edited January 2011
    @JImmydep
    I'm sorry to do this to you again, but does your Xbox have HDMI? I'm asking because I'm trying to figure out what chipset/motherboard is installed (unless you know already know it). Also, what errors is your Xbox displaying?
    Here's a better guide on how to figure it out your chipset. Look above the power connector on the Xbox and find the corresponding number and reference it to this web article (or notice the actual power input. All 3 Xbox's have a distinct input). http://www.examiner.com/xbox-360-in-seattle/easy-guide-to-identify-your-360-chip-set
    If you have one of the older Xenon/Zephyr Xbox's, then I would put money on the fact your console is working on it's last leg.
  • nguyendot
    nguyendot Posts: 3,594
    edited January 2011
    MFG date is 2006 and you asked if it has hdmi? Cmon.... that should have been the first clue. This is a first gen.
    Main Surround -
  • YeorgoT
    YeorgoT Posts: 11
    edited January 2011
    I had the same issue with a new copy of Black-Ops on my original first generation 360 that would just not read. When I upgraded my 360 to the new slim it worked fine. I do believe they have some compatibility issues with the first gen 360's.
  • xKYLEx
    xKYLEx Posts: 6
    edited January 2011
    nguyendot wrote: »
    Sorry, I don't know the exact date the Elite came out or what manufacturing date is printed on the back of those consoles. Since you wanna be a dick, then you can help this guy out. Peace.
  • polkfarmboy
    polkfarmboy Posts: 5,703
    edited January 2011
    My machine would not load certain games and then I swapped out the disk drive and it worked so its puzzling
    If you have the elite then I assume you had to use a brand new benQ drive
