The B&K Ref 20 specs
NeilGabriel
NeilGabriel Posts: 1,487
edited August 2010 in Troubleshooting
This relates to post I did on the troubles I am having with this pre/pro.
The rear panel and spec sheet are attached....hope that helps.
This is a pretty typical older 5 channel DD and DTS processor....solid state.
Thanks.
Post edited by NeilGabriel on
  • mantis
    mantis Posts: 17,201
    edited August 2010
    What do you need to know? I have worked with B&K since 1999. If you are still using the Ref20 , dude it's time to move on. Look for a ref50s2 used. It will do wonders for your system and give you so much more.
    Dan
  • NeilGabriel
    edited August 2010
    mantis wrote: »
    This relates to my post on Pre/Pro Issues right below this....the Ref 20 has started to run very hot and sends a lound screech through the speakers and headphones...
    the guys tell me it is power supply...
    I had this with a parasound 5 channel amp and moved it to a 2 channel system...
    heiney9 Posts: 25,203
    edited August 2010
    Neil, the spec sheet won't tell you what's wrong. Call a shop in your area and find out what they charge to look at it. Around here it's $35 to diagnose and then if you decide to repair it the $35 goes towards the repair, if not then you pay the $35 and take the unit home unrepaired.
    Not trying to sound like a jerk, but even if someone could hold your hand thru some testing procedure's, do you have any electronics knowledge or measuring equipment? Decide if you want it repaired or as Dan said, move on up.
  • dpowell
    dpowell Posts: 3,068
    edited August 2010
    heiney9 wrote: »
    $35 diagnostic fee! that's unheard of in CA. Easily $90 to $100 around here.
    +1 on the advice. Time to let it go and get yourself a dedicated 2-channel pre. You may end up getting a lot of money tied up in trying to get it fixed and who knows if other components are damaged now......
    polkaudio Fully Modded SDA SRS 1.2TLs + Dreadnaught, LSiM706c, 4 X Polk Surrounds + 4 X ATMOS, SVS PB13 Ultra X 2, Pass Labs X1, Marantz 7704, Bob Carver Crimson Beauty 350 Tube Mono Blocks, Carver Sunfire Signature Cinema Grande 400x5, ADCOM GFA 7807, Panasonic UB420, Moon 380D DAC, EPSON Pro Cinema 6050
