Yet another car trouble thread...
nooshinjohn
nooshinjohn Posts: 25,384
edited July 2010 in The Clubhouse
My 2000 Jaguar XJ-8 with 87xxx miles on it has begun giving me all kinds of grief. It began with an evap code(p0446) and not I get two codes, P0172 and P0175. These codes are for run-rich conditions ofr the left and right banks of cylinders. In addition to this, the car enters restricted performance mode and stalls, shuts down, sputters, randomly accelerates and a myriad of other symptoms.
The fuel pump is new as is the mass-airflow sensor. All connections have been checked and rechecked as have the vacuum lines and all are clean and properly connected. Any Ideas as to what is happening here and what I can do to fix it?
Any and all help is appreciated.:)
Post edited by nooshinjohn on
«13
  • Jstas
    Jstas Posts: 14,808
    edited July 2010
    Didija install the Mass-Air sensor backwards?
    Seriously. I watched my boss troubleshoot a similar issue on a Volvo for an hour and a half. When he threw his wrench and cursed at it, I walked over, look at the mass air sensor, pointed to the flow arrow and said "It's backwards." He swapped it around, ran like a champ.
    Expert Moron Extraordinaire
    edited July 2010
    It is installed correctly. The MAF fits only one way on the car and the wire harness will not make the connection if installed incorrectly. The MAF has been in the car for a year and a half now. It has been tested and cleaned properly.
    My gut is leaning towards a fuel pressure regulator, but there is a possibility that O2 sensors may be involved.
  • Jstas
    Jstas Posts: 14,808
    edited July 2010
    Well, the P0172 and P0175 codes are likely caused by the restricted performance mode.
    However, I don't think the evaporator code is to blame. Usually a p0446 code comes when the system can't get a vacuum on the gas tank. That's caused by a leaky gas tank, a clogged fuel filter or a bad seal on the gas cap. Typically.
    However, it could be indicative of a bad or worn fuel pump which might also cause the rich condition and low power because fuel pressure is too low. However, it's odd that the fuel pump would not have an associated code as well. But if the pump is drawing proper power and the pumping mechanism is what is worn out, the pump might not throw a code. But, again, fuel pressure should have a code with it too. That's a little weird. then again, it is a Jaguar. It took Ford a good 5-10 years to exercise all of the Prince of Darkness' demons from them.
    I would clear the codes and reset everything and give it a drive. Also, check that the gas cap is all the way on before you pull out. If it still sputters with no codes, you have a fuel delivery problem. That could be a bad injector, a bad fuel pressure regulator, a bad fuel pump or a bad/clogged/improperly installed fuel filter.
  • Polkersince85
    Polkersince85 Posts: 2,883
    edited July 2010
    These car problems of late seem to be connected to people who have visited the Polk Audio forum. Hmmmnn.
    Sounds like one of your system sensors have gone wild or you have a short or bad connection. Go with the codes and look up the diagnostics.
  • LessisNevermore
    LessisNevermore Posts: 1,519
    edited July 2010
    Damn you man,....damn you.:D:D
  • Face
    Face Posts: 14,340
    edited July 2010
    Sell it, it's only going to get worse.
    edited July 2010
    I have already reset the codes and cleared the computers. The pump is new (three weeks old) and has proper output. Gas cap is also new... The car will sputter and die out until the restricted performance lite comes on and the codes reappear. The P0446 codes always come on before the other two.
  • jrgoswick
    jrgoswick Posts: 159
    edited July 2010
    Someone said check MAF direction. I'm saying HO2 sensors and cats(should be like a dozen of them-seriously like 6 though).
    Onkyo TX-SR705 AVR
    Onkyo M-501-Given to my father.
    Onkyo DX-C730 CD Changer
    Onkyo DV-BD507 Blu Ray player
    Onkyo CP-1036A turntable with Grado, Audio Technique, and Azden cartridges(GOT CARTRIDGE??)
    Polk Monitor 12's with RDO's and XO's
    Polk CS300 Center
    Polk Monitor Series 4 rears
    EBAY is like cocaine. At first you only look, next thing you know, your house is full of crap you have no idea why you own.:eek:
    treitz3 Posts: 18,995
    edited July 2010
    When was the last time the fuel filter(s) were replaced?
    edited July 2010
    Fuel filter was replaced the same time as the pump...
    edited July 2010
    Let me ask you this....and this is a long shot. When was the last time you replaced the battery? Was it recently and/or did the car sit without any power from the battery at all for more than 4 or more hours [lately, or since the symptoms started?]?
    edited July 2010
    The battery is in great shape. The car starts quick and the starter cranks with authority. I did disconnect the battery AFTER the troubles began to clear the computers. The car acts exactly the same after clearing them as it did before.
    After power was restored, the car idled for about 20 minutes before it was driven...
    edited July 2010
    John, I understand that you disconnected the battery after the issues began but you may have compounded the issues by disconnecting the battery. Basically, what happens is the computer resets itself to stock or "original" factory settings and and at this point, will not recognize what changes the computer has set the vehicle settings at as the vehicle has aged.
    If your injectors are dirty or any other changes in air/fuel mixture have been adjusted as the car has aged in order to keep the vehicle up to optimal operating specifications, disabling the battery will [as mentioned] reset the computer to factory defaults which results in poor engine performance, stalling when coming to a stop and rough idling/sputtering.
    You may have to have the fuel injectors professionally cleaned and the fuel system changed to reflect changes that has happened to that system since it was purchased.
    edited July 2010
    Allow me to clarify, not changed........but the spec's altered to reflect the changing environments of an aging engine. I did not mean that you have to have it replaced, just adjusted and thoroughly cleaned. Sorry about that.
    edited July 2010
    According to Jaguar, allowing the car to "idle-in" for 15 to 20 minutes after reseting the computers is sufficient time for the car to adjust and re-learn the operating parameters and make the needed adjustments. The car ran just as bad, if not worse, before I followed their guidlines.
    Thanks guys for all the help so far, but keep the ideas coming. I am going to pull and inspect the O2 sensors this weekend.
  • Mike Kozak
    Mike Kozak Posts: 931
    edited July 2010
    Check the flux capacitor (sp)
    edited July 2010
    ^^^Thanks Mike! I forgot all about that.:D
    edited July 2010
    Maybe it's time for a new POLL. How many SDA owners have had car troubles...:eek::p:D
  • Mike Kozak
    edited July 2010
    I had to replace the fuel pump and filter on my 92 caddy, 600.00 Ugh, but not it runs great. 69000 miles
  • wz2p7j
    wz2p7j Posts: 840
    edited July 2010
    John,
    Your engine is running too rich and the engine control module is doing all it can to compensate by backing off on the fuel mixture but can't compensate.
    So it's not a clogged fuel filter or bad fuel pump as those would result in lean mixture problems.
    Could be leaky injectors but that would suggest the unlikely scenario that injectors in BOTH banks suddenly went bad at the same time.
    I'm not familiar with Jags, but is there an equivalent of a MAP (manifold absolute pressure aka vacuum sensor)? If so,it may be reading improperly and telling the engine control module the engine is under load ("I'm accelerating, add fuel") when it's not.
    The ECM then looks at the O2 sensor(s) and says, oh crap, we're way too rich and tries to back off but can't compensate, hence the codes you're getting.
    Just a thought, I used to see this on GM cars but again am not familiar with Jags.
    Chris
  • joeparaski
    joeparaski Posts: 1,865
    edited July 2010
    I'm not familiar with Jags either. But I would suggest you try a professional fuel injection service as was suggested. You need to get that possibility out of the way, either way it would be good to get it done.
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
    edited July 2010
    joeparaski wrote: »
    Joe
    Flow rates read on diagnostics appear to be spot on(within 5%) of each other. The STFL readings are off the charts and fluctuate wildly at idle and even more so under load. With the cruise control set, they swing from -12.8 all the way out to 26.2. The LTFL numbers remain more constant, but also fluctuate...
    Any ideas on what those numbers are all about?
  • wz2p7j
    wz2p7j Posts: 840
    edited July 2010
    Don't know much about Jags, but I'm sure STFL is "short term fuel something" and LTFL is "long term fuel something" kinda like "integrator" and "block learn" on older GM cars. I would expect STFL to fluctuate more than LTFL.
    Some sensor is fooling you're engine management system making it add/subtract fuel causing this problem. Look at any value on the scan tool related to engine load/acceleration. i.e. MAF MAP TPS.
    On older cars, MAP used a 5v reference. Low voltage of about .5-1v was a car at idle. Shouldn't see a MAP voltage of, say, 3v with a car at idle. Same with TPS. Can't remember about MAF, seems like that was usually pulse width modulated or something, can't remember.
    Chris
  • wz2p7j
    wz2p7j Posts: 840
    edited July 2010
    John, it could be the O2 sensors saying "I'm lean, I'm lean" resulting in your rich codes. But right and left bank would both have to go south at the same time to generate your right bank, left bank rich codes. Not likely.
    There's usually only ONE TPS, MAF and MAP and BOTH banks are reading rich. Again suggest starting with MAP, MAF and TPS.
    Good luck!! :D:D
    Chris
    edited July 2010
    The MAF is spot on spec-wise... the O2 sensors are a 4 wire type that transmits readings back to the ECU and tells it to make adjustments to the fuel/air mix. If the wrong data goes back to the ECU, would this cause the wild readings I am seeing?
  • wz2p7j
    wz2p7j Posts: 840
    edited July 2010
    I would expect STFL and LTFL to vary based on load, etc. And STFL to vary more than LTFL.
    Is there a voltage reading you can provide for MAP (vacuum) and TPS at idle and, say, WOT?
    Also, I'm not familiar with Jags - how is MAF spot on, can you please elaborate??
    Thanks! Chris
  • wz2p7j
    wz2p7j Posts: 840
    edited July 2010
    John,
    OK - I Googled "2000 XJ8 MAP sensor" and found some part numbers, so I suspect you have a MAP sensor in your vehicle. Please verify and provide readings, if applicable.
    Thanks!! Chris
    edited July 2010
    The MAP sensor and the MAF sensor are one and the same. I believe we are just using american vs. european lingo here. The MAP/MAF is new. There are 4 O2 sensors on my car, and the first two are used to adjust the air/fuel mix. The back two monitor efficiency of the catalytics. It appears the two in front of the cats have the ability to play all kinds of havoc with regards to fuel flow.
    What I have learned also opens the possibility of bad catalytic converters.
    You guys are great!
    edited July 2010
    Any other ideas out there?
  • Face
    Face Posts: 14,340
    edited July 2010
    Drop the car off to someone who knows what they're doing?
