Not a good day with my SDA 2A speakers!
helipilotdoug
helipilotdoug Posts: 1,229
edited July 2010 in Vintage Speakers
Oh Boy! Well, i went to put in the new tweeters I got from Polk audio, and found some things I was not expecting. Thinking these were SDA 2B speakers, Plans were to do the TL mod so I ordered RDO-198 Tweeters.
First of all, the tweeters I got from Polk have no markings on them whatever. No model number, production date or anything. I ordered the RDO-198's and have to assume that's what I got. Anyone else get these tweets with no markings?
Second, and this is the real kicker! I found the outside MW on the LH speaker has the surround ripped at two of the mounting holes. From the looks of it, the surround was deformed when manufactured. I had replaced this MW 2-3 years ago, and just found this. It's a 6503, and the date of manufacture shows 01 March, 2004.
And third, as if that did not make my day enough, I decided to remove the inside MW from the left speaker, and found the magnet slipped off to one side! How this speaker was putting out any sound is a mystery to me! Also, I found out these are apparently SDA 2A's not 2B's. I pulled all the MW's and found all the rest to be 6510's. Sooooo, my plans to upgrade this set may be messed up. The other set of speakers are 2B's, but I don't have them yet. I bought them on Audiogon from a guy up in the Dallas area, and he's supposed to be bringing them down soon. The speakers I have now are not doing well, and I've unhooked them. :( I need some speakers!
OK Guys I need some suggestions. What should I do with these SDA 2A's? Can they be upgraded to the 2B TL mod or not? From what I've read they can not. What do you recommend?
Sunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com
Post edited by helipilotdoug on
  • nadams
    nadams Posts: 5,877
    edited June 2010
    When you replace mid drivers, you have to ensure that the screw head is not going to grab the surround and twist it, which is exactly what happened here. Sometimes you have to cut a little bit out with an xacto knife to let the screw head clear.
    The magnet shift is quite common... I would recommend applying JB Weld to the rest of the driver magnets before they shift as well.
    As for the TL mod, I'll let that info come from someone more experienced.
    Ludicrous gibs!
    heiney9 Posts: 25,217
    edited June 2010
    None of the RD0's have ever had markings on them. The only way to tell the difference is connector prongs. One model has a large and small connector the other model has two large connectors. I forget which is which.
  • helipilotdoug
    edited June 2010
    heiney9 wrote: »
    These have 1 large and 1 small connector.
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • helipilotdoug
    edited June 2010
    nadams wrote: »
    Thanks, I imagine that's what happened with the surround. :( I'll know to be a lot more careful about that from now on!
    And I'll make sure to do the JB weld mod to the rest of the MW's before I put them back together.
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • Conradicles
    Conradicles Posts: 6,138
    edited June 2010
    That would be the 198 tweeter.
    Toolfan66 Posts: 17,337
    edited June 2010
    The RDO 194's have two small connectors.
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
    edited June 2010
    I think Polk with stand behind the defective driver (the one with the bad surround) just email customer service and explain what happened. When you get the next one be sure to inspect and cut the excess rubber from the mounting hole if this is still an issue.
  • gimpod
    gimpod Posts: 1,793
    edited June 2010
    As far as pic #4 go's that's exactly what happened to one of my 6511's in my 1C's (The dreaded shipping fubar) i didn't notice it till i started to crank it and then it would make a sticky **** sound:eek:
    If you want to try and fix it check out these two links.
    http://www.audiokarma.org/forums/showthread.php?t=130808
    http://www.audiokarma.org/forums/showthread.php?t=202963
    The first thing to do before trying this is check the voice coil with an ohm meter it should read around 8 ohms for a 6510, if it reads 0 Ohms don't bother it's toast. also check it visually make sure there's no lose or stray wire that could come in contact with the slug inside the magnet if so just glue them down with super glue and a small paint brush.
    Believe it or not this does work, but if you decide to part them out i know geppy1 is looking for a pair of 6510's. if not you should try and replace that 6503 with an original 6510.
    Any way you decide to go good luck.
  • stubby
    stubby Posts: 723
    edited June 2010
    Hey Doug, I just bought a 2B crossover from leroy and was just going to use it as a spare. Sounds like you could get better use of it. Let me know if you want it. Then you could slam it in your 2A cabinets and do the TL upgrade.
    stubby
    SRS 3.1TL
    Harman Kardon Citation 5.1
    Anthem AVM2
  • helipilotdoug
    edited June 2010
    stubby wrote: »
    stubby
    Thanks Stubby. How much do you want for them? I might be very interested in trying that route with these 2A's. It's either that, or order a set of RDO-194's, and upgrade the X overs. I'm not sure what other changes might have to be made to turn these into 2B's.
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • stubby
    stubby Posts: 723
    edited June 2010
    I'm in $35 for them.
    SRS 3.1TL
    Anthem AVM2
  • stubby
    stubby Posts: 723
    edited June 2010
    Looks like you would also have to swap out the 6510 MW's for a 6511 and 6503, in each cabinet, to make them true "b"'s. You already have the RDO's
    SRS 3.1TL
    Anthem AVM2
  • helipilotdoug
    edited June 2010
    stubby wrote: »
    I know the wiring is different, so I might have to re wire them too. As an example the interconnect cable uses both wires on the 2A's but only 1 wire on the 2B's. I'll have to do some more research and see what needs to be done. I'm very interested in your 2B X overs. If I can go with the upgrade to 2B's I will want to take you up on that.
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • Schurkey
    Schurkey Posts: 2,104
    edited June 2010
    Wouldn't that be two LARGE connectors? That's what the SL2000 has; and the 194 is supposedly a direct replacement.
    The 198 has one large, one small, and required the wiring harness to be modified with one smaller connector per tweeter when I converted my 1Bs to '198s. I never did find a wiring harness connector with an exact fit.
    My 198s had no markings on them; and no country-of-origin labeling, either. I thought all imported consumer products had to have country-of-origin labeling either on the product or on the packaging.
  • hearingimpared
    hearingimpared Posts: 21,136
    edited June 2010
    They are RD0198s.
    WHoops sorry I just noticed this question was answered. . . carry on!
  • JPSmario
    JPSmario Posts: 142
    edited June 2010
    This was discussed in quite some depth in this thread:
    http://www.polkaudio.com/forums/showthread.php?t=97536&highlight=RDO198
    I hope this adds an option for you.
    JIm
    Dual 1229/Grado Gold/Rotel RCD1070/RC995/RB980BX/Pioneer 7100/Denon DRM710/Monster HTS3600MKII/PolkAudio SDA2B/TL's
  • helipilotdoug
    edited June 2010
    Thanks JPSmarino. :) That was a good read. For now, I'll keep these as 2A's. Talked to Polk Customer Service this morning. He gave me a special price of $30 each for the two 6510's and I also ordered two RDO-194 tweeters. While I'm at it, I'll do the dynamat and Mortite mods, plus install the new hardware rings I got from TOOLFORLIFEFAN. I should end up with a really good set of SDA 2A speakers! :)
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • hearingimpared
    edited June 2010
    JPSmario wrote: »
    JIm
    Great link Jim, it clears up a lot of misconceptions.
  • george daniel
    george daniel Posts: 12,096
    edited June 2010
    Yes sir you will have a very good set of speakers.I'm glad that you got it squared away--I think your decision to keep them as 2A's is to be commended--stay in the boat.:)
  • hearingimpared
    edited June 2010
    Hear, hear!
  • helipilotdoug
    edited July 2010
    I got the 194's and 6510's from Polk. Yesterday I installed the tweeters, installed the 2 new 6510's as the main driver in both cabinets, dynamated both new 6510's and the PR in the left cabinet. I ran out of time, and did not finish dynamating the right PR or the SDA drivers. Will get around to that soon, as well as mortite. On first impression of the new tweeters, they are not as "bright" harsh as the 2000's but still pretty bright. I'll give them some play time to break in before making any judgments. I'm very happy so far. I have a question on the mortite installation. Do you remove the old driver/PR seals when installing with mortite, or leave them in place?
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • hearingimpared
    edited July 2010
    If you are going to use Mortite then yes you need to remove the gaskets at least I did when I used Parts Express Speaker Seal which I think is a better bet than Mortite. That is just my opinion as I've not used Mortite but I have heard that it can be a real PITA to apply and remove if necessary be a few members here.
    edited July 2010
    After about 300 hours the RD0's will sound about right. They are anything but bright in my experience.
  • hearingimpared
    edited July 2010
    heiney9 wrote: »
    Ditto & ditto!:)
  • dhart86
    dhart86 Posts: 1,594
    edited July 2010
    Doug.........how much do the RDO's sell for? Thinking about upgrading my tweets
    Main Rig:
    Antipodes DX > Roon > PS Audio Directstream Jr.>deHavilland Ultraverve 3 >Belles Reference 150a >Harbeth C7 ES3
    Second Rig:
    Roon> PS Audio Directstream Jr Bridge II > EE Minimax pre (Tutay mods) >Belles 150A Ref >Monitor 5 (Westmassguy-modded)
  • helipilotdoug
    edited July 2010
    dhart86 wrote: »
    As a Club Polk member, $48. each. Make sure you tell them you are a member. Free shipping too! :D
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • helipilotdoug
    edited July 2010
    After about 24 hours of play I've noticed a big difference already. Much smoother sound from the 194's now. Far superior to the 2000's. It's worth the price all right!
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
  • Driver_King
    Driver_King Posts: 266
    edited July 2010
    Hey Doug.:D With the replacement 194's, could you go into detail about the differences compared to the 2000's? I have the original SDA II's with the dual SL2000's, so I'd really have to know if the difference is worth the cash since I'd be replacing four tweeters.:eek::p One thing I heard may not be so great about the 194's is the sound of cymbals or brass instruments compared to the SL2000 and I was wondering if that's what you found to be true or not.
    Home Theater:
    Onkyo TX-SR805
    Behringer EP2500 for SDA's
    Polk SDA II fronts
    Polk Monitor 5Jr. surrounds
    Polk Monitor 4 back surrounds
    DIY A7-900 and DIY A3-300
  • JPSmario
    JPSmario Posts: 142
    edited July 2010
    This is going to be a personal call/gamble. I'm one that found the SL2000's had a 'bite' (some say around 12Kz) that I couldn't listen to for more than an hour or so at a time on my SDA 2A's:( It particularly bothered me with cymbals and orchestral brass and otherwise seemed to add an unnatural high frequency 'liveness' to the stage. Once the RDO194's burned in, they are much more natural to my ears than the 2000's with a 'blackness' that enhances space on the stage. and I can listen to them all day:D
    Of course, your ears and your system are different, so good luck with whatever you decide.
  • helipilotdoug
    edited July 2010
    Driver_King, I have found the 194's to be very good so far with the cymbals and brass. I agree with what JPSmario said. I had a hard time listening to my 2A's for a extended amount of time, because of the harshness, bite, or un-natural brightness, at higher listening levels. These new 194 tweeters have not been fully broken in yet. I listened to quite a few random selections yesterday, and can say so far I'm very pleased with the sound of the Cymbals and Brass. I do not consider myself a audiophile, and I'm not good with explaining what I'm hearing like a lot of folks on here. The best I can tell you is IMHO, so far, the 194's are WELL WORTH the money.
    The SDA2's have one tweeter for the stereo side and another for the SDA side. You might think about getting 2 194's and replacing the stereo tweeter in each cabinet at first, to give you an idea if it's worth it to your ears. From what I understand, the stereo drivers are dominant, which should give you a good indication if they will sound good to you. If they don't I'm sure you can sell the 194's on here. Someone else chime in here on this.
    SRS 2.1TL
    SDA 2BTL's
    CSiA6
    FXiA4
    FXiA6
    SDA 2A's
    Monitor 10A's
