psw125 problems
ag43
a few months ago my psw125 started emitting low "heartbeat" noises even when no input is plugged. i've ignored this but now the sub started making weird noises or not at all. how can i fix this?
Hello,
From your description it is likely that a problem has developed with your unit's bass amplifier. Give Polk CS a call at: 1-800-377-7655 select option 1 and they'll need the serial number and date/place of purchase.
Regards, Ken -
i'm from israel.
Hello Israel!
In that case send an email to: Ken.Carter@soundunited.com and he will direct you to the correct place.
Regards, Ken -
thanks.
hi. just wanted to update that ken took care of the problem and my sub works again. great customer service polk!
That's great I'm glad he was able to help. Enjoy your sub.
so, a year and half later and the exact same problem returns. disappointing.
ok polk. there's a defective line of subs and there's this:
this is a fire hazard. reminder - this is the replaced amp i've received from you. it was supposed to not have a problem, not almost set my house on fire.
I would think twice before buying from you again.
