I blew up my RTIA9, twice..
You really need to pull and check the crossovers before doing anything else.
Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work -
If I remember Skip they are different...
Are the drivers and crossovers identical to the rti12? If so I have a set of 12 that we could work out a deal on.If I remember Skip they are different...
Swing and a miss! -
I think the drivers are the same... not sure on the XO.
Rti12 and a9 use the same drivers- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
I know the older gen RT drivers were different but I thought the move to the A was cabinet and maybe crossover differences. I could be wrong though.
Yes different XO according to Doro and of course cabinet.
I cannot stress enough to look at the XO. Many have cooked parts in the XO doing just as you have done. Makes no sense to put new drivers in to get fouled up quick like from a bad XO. -
Yes different XO according to Doro...I cannot stress enough to look at the XO. Many have cooked parts in the XO doing just as you have done. Makes no sense to put new drivers in to get fouled up quick like from a bad XO.
Have you considered vertical bi-amping? You would need more wire.
Take ‘em out of mono. Taking care to connect + to red, - to black: one channel to the “top,” the other to the “bottom?” Then do the same w/the other amp to the other speaker?
Can’t say how or if it would affect your “party” loudness. Mostly I’m curious about a change in SQ - particularly distortion.
Just a thought. TonySamsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work -
80% volume? I don’t even want to know what that sounds like. Geez manMagico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
This thread is old2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
