I blew up my RTIA9, twice..
  • gp4jesus
    gp4jesus Posts: 1,969
    You really need to pull and check the crossovers before doing anything else.
    Yup Yup Yup I so agree
    Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work
    Toolfan66 Posts: 16,837
    edited October 2018
    If I remember Skip they are different...
  • krazypolk
    krazypolk Posts: 745
    DSkip wrote: »
    Are the drivers and crossovers identical to the rti12? If so I have a set of 12 that we could work out a deal on.
    Toolfan66 wrote: »
    Swing and a miss!
  • mlistens03
    mlistens03 Posts: 2,767
    I think the drivers are the same... not sure on the XO.
    VR3 Posts: 27,970
    Rti12 and a9 use the same drivers
    pitdogg2 Posts: 24,481
    edited October 2018
    DSkip wrote: »
    I know the older gen RT drivers were different but I thought the move to the A was cabinet and maybe crossover differences. I could be wrong though.
    Yes different XO according to Doro and of course cabinet.
    I cannot stress enough to look at the XO. Many have cooked parts in the XO doing just as you have done. Makes no sense to put new drivers in to get fouled up quick like from a bad XO.
  • gp4jesus
    Yes different XO according to Doro...
    certainly true for the ‘A7/RTi10
    yup X3
  • gp4jesus
    edited January 2020
    Have you considered vertical bi-amping? You would need more wire.
    Take ‘em out of mono. Taking care to connect + to red, - to black: one channel to the “top,” the other to the “bottom?” Then do the same w/the other amp to the other speaker?
    Can’t say how or if it would affect your “party” loudness. Mostly I’m curious about a change in SQ - particularly distortion.
    Just a thought. Tony
  • Joey_V
    Joey_V Posts: 8,505
    80% volume? I don’t even want to know what that sounds like. Geez man
    Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
    txcoastal1 Posts: 13,124
    This thread is old
