signa solo
hi, my signa solo stopped working. It was working last night. when I
turned my tv on this am. to whatch news there was no sound. Any ideas
what I should do? I've unplugged all cables for soundbar and still there is
no sound.
  • rooftop59
    rooftop59 Posts: 7,981
    What’s a signa sola? Is it a Polk product?
    Game Room 5.1.4:
    Bedroom 2.1
  • codycatalist
    https://www.polkaudio.com/products/signa-solo
    rooftop59 wrote: »
  • codycatalist
    @soul2heart How did you have it connected to your TV, optical? What brand and model TV do you have?
  • teeseetwo
    My Signa Solo has done the same thing, absolutely no sound. That's with any input, Optical, Aux or Bluetooth. The LEDs indicate the correct input selection, and I have done a factory reset (Pwr & Source & Vol+ buttons on the top, with the LEDs flashing to show reset has been correctly commanded) but still no improvement. It is completely silent. Any ideas what it can be ?
  • metoo
    metoo Posts: 1
    Me too. Just as teeseetwo described. Any help?
  • snickit16150
    same thing, Polk Signa Solo, leds work, hooked up a different soundbar and works. getting signal from tv. tried BT and aux and nothing. only 45 days old.
  • vinay05
    vinay05 Posts: 1
    Same issue with my Signa Solo. Did any one figure it out the issue and fixed it?
  • java
    java Posts: 1
    Same issue with my Polk Signa Solo. 4yrs old. Any solutions to this?
  • SeleniumFalcon
    I would recommend sending an email to: Kim.Jasper@soundunited.com and explain what happened.
  • mcewenjeffrey
    Very same thing has now happened to me. Almost 5 years old. Worked fine a couple days ago, then next time I turned it on: no sound. Remote works. LED’s work. ‘Twas using optical cable input. Tried AUX and BlueTooth on different devices to no avail. Essentially bricked. Factory reset does not help.
    Surely it’s salvageable???
  • cubudman
    Any responses to this thread?
    F1nut Posts: 49,819
    cubudman wrote: »
    Sure
