Audioquest Aspen: Stupid speaker wire is so unbendable
Joey_V
Joey_V Posts: 8,522
Argh
I tried to connect my Audioquest Aspen (4 below my Wel but same line) between the Rotel amp and the Focal Kanta 2.... it’s like impossible! The media console has a small metal opening that bends the wire in a crazy contorted manner that just doesn’t allow it.
Not to mention the wire is so unwieldy that I can’t get it to attach to the speakers unless I pull it out into the room.
I didn’t have this trouble with the main system but I realized it was because it was not a living space and I was not limited by decor and furniture.
Sad day.
Magico, JL, Emm, ARC Ref 10 line, ARC Ref 10 phono, VPI, Lyra, Boulder, AQ Wel, SRA Scuttle Rack, Bluesound
  • rpf65
    rpf65 Posts: 2,127
    You start by obtaining a drill, and the proper sized drill bit for tha material you are working with.
    msg Posts: 9,481
    Yeah, I had to core some holes in the back of my cabinet.
    Good excuse to start building up a nice tool collection. A nice cordless will probably work, but I like corded high speed drills for this sort of work.
    You can pickup a boring bit or a hole saw for this. It's pretty easy. Shop-vac'll be handy.
    Pull your gear out, make some measurements for the approximate location, and drill a pilot hole from the inside out where your stiffer cables will be coming in. Then go around back and finish it, if you can't comfortably complete the hole from the front.
    I'm not a fan of contorted cables and stressed connectors, myself. It... uh... stresses me.
  • rpf65
    rpf65 Posts: 2,127
    Bet the dinosaur kid can put holes in things.
  • Joey_V
    Joey_V Posts: 8,522
    edited May 2018
    I think I'm going to put off the Aspen in the game room for now until I find time and money to switch out the console to an open one, I will keep an eye on the holes in the rear from now on. Even with holes in then right spots the AS Aspen puts undue pressure on the binding posts.
    Unfortunate. I think I'll try smaller cables here
  • Joey_V
    Joey_V Posts: 8,522
    rpf65 wrote: »
    Hahahaha
  • ken brydson
    ken brydson Posts: 8,655
    First world problems.
    Get a bigger hammer
  • Joey_V
    Joey_V Posts: 8,522
    Get a bigger hammer
    I need to learn how to bend the AQ at right angles.
  • Joey_V
    Joey_V Posts: 8,522
  • Joey_V
    Joey_V Posts: 8,522
    Well it’s working So far...
    Emma is using the midrange grille as a captain America shield.
    Henry is off on his own.
  • mdaudioguy
    mdaudioguy Posts: 5,165
    My thought exactly while reading the op, then I got down to your post and lol'd! :p
  • Joey_V
    Joey_V Posts: 8,522
    mdaudioguy wrote: »
    Technically this WHOLE forum is first world problems if you think about it
  • Joey_V
    Joey_V Posts: 8,522
    Yes... success!
    Type 4 to the rescue
  • BlueFox
    BlueFox Posts: 15,251
    Use spades.
  • mdaudioguy
    Joey_V wrote: »
    mdaudioguy wrote: »
    That is certainly true!
  • mpitogo
    mpitogo Posts: 478
    Spades.
    • Living Room Music-2.0 Polk Legend L800 | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Belkin Soundform Connect | iPad Air USB to DAC
    • Media Room Ht-7.2.6/13.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x4], height LSiM703 [x6], HSU VTF-15H MK2 Dual | Marantz AV8805A | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Sony UBP-X800 | AppleTV 4K | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.0 Ascend Acoustics Sierra LX, DSW microPRO3000 | Rotel RA-1570 | Marantz HD-CD1
    • Daughter's Bedroom 1-2.0 TBD Martin Logan Forte | Roku TV
    • Guest Room 2-2.0 Klipsch RP-600M | Martin Logan Forte
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Topping DX7s | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • HzTweaker
    HzTweaker Posts: 725
    Love the solution for the front firing ports!
    That's what I call hifi tech.
    2ch rig:Speakers: LSi9s with VR3's Fortress modsPreamplifier: Parasound P5Amplifier: Parasound A23CDP: Pioneer DV-563ACables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
    Tony M Posts: 11,018
    I was going to suggest using this tool. :p
  • Joey_V
    Joey_V Posts: 8,522
    BlueFox wrote: »
    Use spades.
    Would help but the massiveness itself is what don’t work.
    It’s too bad, it’s a really good speaker wire
  • TEAforONE
    TEAforONE Posts: 1,006
    I would purchase some modest gear,and buy your children some toys to play with.
  • tratliff
    tratliff Posts: 1,670
    I would not be able to manage in that room. I'm stressing just looking at the pictures.
    Not sure this is going to end well.
    2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Silver 4+ Interconnect Cables, AudioQuest Niagara 7000 w/Dragon and Hurricane Power Cables
  • Legender
    Legender Posts: 478
    Mikey!! had to read it twice and once out loud... but that is funny.
    Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
    Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
    Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
    2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
    Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
    Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra
  • Joey_V
    Joey_V Posts: 8,522
    Legender wrote: »
    Wait a minute... I read it 3x before I got it...
    mhardy6647 Posts: 33,070
    edited May 2018
    Still alot of money for those cables...
    Your Aspen HAD !!!
    Oh. I see what you did there.
  • miner
    miner Posts: 1,305
    Joey, I bought a pair of the 8' AQ CV8 for 50% off (closeout pricing) and am perplexed at how good this speaker wire is for $300. It replaced a set of MIT cables on my B&Ws.
  • mlistens03
    mlistens03 Posts: 2,767
    Joey_V wrote: »
    mdaudioguy wrote: »
    Your Aspen HAD !!!
    I've read that at least 15 times, and I finally get it! that took way too long :LOL:
