Audioquest Aspen: Stupid speaker wire is so unbendable
Joey_V
Joey_V Posts: 8,606
Argh
I tried to connect my Audioquest Aspen (4 below my Wel but same line) between the Rotel amp and the Focal Kanta 2.... it’s like impossible! The media console has a small metal opening that bends the wire in a crazy contorted manner that just doesn’t allow it.
Not to mention the wire is so unwieldy that I can’t get it to attach to the speakers unless I pull it out into the room.
I didn’t have this trouble with the main system but I realized it was because it was not a living space and I was not limited by decor and furniture.
Sad day.
  • rpf65
    rpf65 Posts: 2,127
    You start by obtaining a drill, and the proper sized drill bit for tha material you are working with.
    msg Posts: 10,650
    Yeah, I had to core some holes in the back of my cabinet.
    Good excuse to start building up a nice tool collection. A nice cordless will probably work, but I like corded high speed drills for this sort of work.
    You can pickup a boring bit or a hole saw for this. It's pretty easy. Shop-vac'll be handy.
    Pull your gear out, make some measurements for the approximate location, and drill a pilot hole from the inside out where your stiffer cables will be coming in. Then go around back and finish it, if you can't comfortably complete the hole from the front.
    I'm not a fan of contorted cables and stressed connectors, myself. It... uh... stresses me.
  • rpf65
    rpf65 Posts: 2,127
    Bet the dinosaur kid can put holes in things.
  • Joey_V
    Joey_V Posts: 8,606
    edited May 2018
    I think I'm going to put off the Aspen in the game room for now until I find time and money to switch out the console to an open one, I will keep an eye on the holes in the rear from now on. Even with holes in then right spots the AS Aspen puts undue pressure on the binding posts.
    Unfortunate. I think I'll try smaller cables here
  • Joey_V
    Joey_V Posts: 8,606
    rpf65 wrote: »
    Hahahaha
  • ken brydson
    ken brydson Posts: 9,107
    First world problems.
    Get a bigger hammer
  • Joey_V
    Joey_V Posts: 8,606
    Get a bigger hammer
    I need to learn how to bend the AQ at right angles.
  • Joey_V
    Joey_V Posts: 8,606
  • Joey_V
    Joey_V Posts: 8,606
    Well it’s working So far...
    Emma is using the midrange grille as a captain America shield.
    Henry is off on his own.
  • mdaudioguy
    mdaudioguy Posts: 5,164
    My thought exactly while reading the op, then I got down to your post and lol'd! :p
  • Joey_V
    Joey_V Posts: 8,606
    mdaudioguy wrote: »
    Technically this WHOLE forum is first world problems if you think about it
  • Joey_V
    Joey_V Posts: 8,606
    Yes... success!
    Type 4 to the rescue
  • BlueFox
    BlueFox Posts: 15,250
    Use spades.
  • mdaudioguy
    Joey_V wrote: »
    mdaudioguy wrote: »
    That is certainly true!
  • mpitogo
    mpitogo Posts: 523
    Spades.
    • Living Room Music-2.1 Polk Legend L800 | SVS SB1000Pro | McIntosh C70 | McIntosh MA5200 (Treble) | McIntosh MC452 (Bass) | Sublimeacoustic K231 Active xover | Denon DP-2500A | Denafrips Ares II | Marantz HD-CD1 | Belkin Soundform Connect | iPad Pro USB to DAC
    • Home Theater-9.7.6/15.1 (Atmos/Auro-3D) Polk LSiM707, LSiM706c, LSiM702 F/X [x6], Height LSiM703 [x6], HSU ULS-15Mk2x4, VTF-15HMk2x2, VTF-TN1 | Trinnov Altitude 16+4 (2024) | Rotel RB-1590 (L/R) | Appollon NC500 11ch | Martin Logan MP500x2 | Topping DX7s, E50 | AppleTV 4K | Zidoo Z9X | JVC RS2100 | 150” Elite Screen Acoustic Pro UHD
    • Game Room-5.1 Polk LSi25, LSiC, LSiF/X | Marantz SR7009 | AppleTV 4K | Sony UBP-X800 | Xbox One S | Sony PS2, PS3 | Nintendo Wii | Gaming PC | Sony 75" LCD
    • Master Bedroom Music-2.0 Totem Hawk | Marantz PM-10 | Marantz SA-10 | SONY PS-HX500
    • Office-2.1 B&W Formation Duo and Bass
    • Daughter's Gaming Rig-2.0 Ascend Acoustics Sierra LX | Martin Logan Forte
    • Orphans DSW microPRO3000x2 | Rotel RA-1570 | Marantz AV8805A
    • Guest Room 2-2.0 Klipsch RP-600M | SMSL DO100 Pro 2 | Pass ACA v1.6 Monoblocks
    • Guest Room 3-3.0 Martin Logan Motion 40, 50XT | Onkyo TX-SR705 | Apple TV | Samsung 55" TV
    • Guest Room 4-2.0 QAcoustics 3030i | Sansui AU-6900 | Sansui FR-1080 | Fire TV
    • Maintenance: Pro-Ject VC-S Record Cleaning Machine
  • HzTweaker
    HzTweaker Posts: 1,136
    Love the solution for the front firing ports!
    That's what I call hifi tech.
    2ch rig: Speakers: LSi9s with VR3's Fortress mods Preamplifier: Parasound P5 DAC: Fiio K13 Amplifier: Parasound A23 CDP: Pioneer DV-563A Cables: Wireworld Equinox 7 XLR ICs, Wireworld Ultraviolet 7 USB, AudioQuest Q2s, AudioQuest NRG X(preamp)
    Standby: Magnepan LRS w/Magna Riser stands
    Tony M Posts: 12,029
    I was going to suggest using this tool. :p
  • Joey_V
    Joey_V Posts: 8,606
    BlueFox wrote: »
    Use spades.
    Would help but the massiveness itself is what don’t work.
    It’s too bad, it’s a really good speaker wire
  • TEAforONE
    TEAforONE Posts: 1,102
    I would purchase some modest gear,and buy your children some toys to play with.
  • tratliff
    tratliff Posts: 1,905
    I would not be able to manage in that room. I'm stressing just looking at the pictures.
    Not sure this is going to end well.
    2 Channel Rosso Fiorentino Volterra II, 2 REL T9x, Norma Revo IPA-140B, Norma Revo DAC-2, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, ModWright PH-150, SonoruS ATR10, AudioQuest Niagara 7000 w/Dragon power cable, WAY power cables for all other sources, WAY Silver 3 Ana+ speaker cables, WAY interconnect cables
  • Legender
    Legender Posts: 478
    Mikey!! had to read it twice and once out loud... but that is funny.
    Music: Oppo103 - Parasound JC2 - Parasound A21- SDA 3.1
    Theater: Denon 3808 - B&K 7500/Emotiva XPA-3- RTi12, CSi5, RTiA7x4, PSW505
    Sleeping: Marantz 70005 - Harman Kardon 2400 - SDA 2
    2 Channel: Cary 306 SACD - Canary Audio 906 - Pass Labs x250 - PS Audio Perfectwave DAC, Polk LSiM705, SVS SB13 Ultra
    Office: Dell Optiplex, Emotiva XDA-2, Adcom 5500, LSiM 703
    Spares: Yamaha CA-810; LSi 15; Kenwood Basic M2a, Yamaha M60/M80, Polk Monitor 7, SVS SB13 Ultra
  • Joey_V
    Joey_V Posts: 8,606
    Legender wrote: »
    Wait a minute... I read it 3x before I got it...
    mhardy6647 Posts: 35,562
    edited May 2018
    Still alot of money for those cables...
    Your Aspen HAD !!!
    Oh. I see what you did there.
  • miner
    miner Posts: 1,305
    Joey, I bought a pair of the 8' AQ CV8 for 50% off (closeout pricing) and am perplexed at how good this speaker wire is for $300. It replaced a set of MIT cables on my B&Ws.
  • mlistens03
    mlistens03 Posts: 2,767
    Joey_V wrote: »
    mdaudioguy wrote: »
    Your Aspen HAD !!!
    I've read that at least 15 times, and I finally get it! that took way too long :LOL:
