My sub wont work with RX-A1040
afterburnt
in Speakers
SVS PB1000???2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
probably operator error.
Got it to work with the Marantz, the Yamaha's fault
Kinda don't care, spare 2 channel and it werkz
Is the sub turned on in the menus of the Yamaha and the crossover points setup correctly with the mains set as small?afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Yup
It has not been run in a while but it was set up 5.1
Can I hook it up to one of the main pre outs without disconnecting the speaker or will I get that housafire that I asked for?
afterburnt wrote: »Can I hook it up to one of the main pre outs without disconnecting the speaker or will I get that housafire that I asked for?
for that you must check the manual. Some explicitly say no...Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Bedroom 2.1Cambridge Azur 551r; Polk RT25i; ACI Titan Subwoofer -
Did you switch out the sub cable?
Did you make sure the sub is on? (I have done this before...)
Did you make sure you are plugged into the SUB1 and not the SUB2 output on the yamaha?
Did you make sure the sub volume is turned up in the receiver?
Did you run YPAO and see if it senses a sub?Living Room 2.2: Usher BE-718 "tiny dancers"; Dual DIY Dayton audio RSS210HF-4 Subs with Dayton SPA-250 amps; Arcam SA30; Musical Fidelity A308; Sony UBP-x1000es; Squeezebox Touch with Bolder Power Supply
Damn it I am at fort Apache right now and don't have the stuff I need. I do have second sub and really short ICS on hand. Maybe a multimeter in my trunk
OIC said the blind man. All I had to do was put my face not the floor.
