My sub wont work with RX-A1040
afterburnt
afterburnt Posts: 7,892
It was moth balled for a minute now it dont6werkz
    txcoastal1 Posts: 13,520
    SVS PB1000???
  • rpf65
    rpf65 Posts: 2,127
    probably operator error.
  • ken brydson
    ken brydson Posts: 9,107
    rpf65 wrote: »
    Ya think?
  • afterburnt
    edited April 2018
    Got it to work with the Marantz, the Yamaha's fault
  • afterburnt
    Kinda don't care, spare 2 channel and it werkz
  • Nightfall
    Nightfall Posts: 10,083
    Is the sub turned on in the menus of the Yamaha and the crossover points setup correctly with the mains set as small?
    afterburnt wrote: »
    Village Idiot of Club Polk
  • afterburnt
    Nightfall wrote: »
    Yup
  • afterburnt
    It has not been run in a while but it was set up 5.1
  • afterburnt
    Can I hook it up to one of the main pre outs without disconnecting the speaker or will I get that housafire that I asked for?
  • rooftop59
    rooftop59 Posts: 8,120
    afterburnt wrote: »
    for that you must check the manual. Some explicitly say no...
    Game Room 5.1.4:
    Bedroom 2.1
  • rooftop59
    Did you switch out the sub cable?
    Did you make sure the sub is on? (I have done this before...)
    Did you make sure you are plugged into the SUB1 and not the SUB2 output on the yamaha?
    Did you make sure the sub volume is turned up in the receiver?
    Did you run YPAO and see if it senses a sub?
    Game Room 5.1.4:
    Bedroom 2.1
  • afterburnt
    Damn it I am at fort Apache right now and don't have the stuff I need. I do have second sub and really short ICS on hand. Maybe a multimeter in my trunk
  • afterburnt
    OIC said the blind man. All I had to do was put my face not the floor.
