Pre to Amp. XLR or RCA, Which is better?
audioluvr
Noob here to balanced inputs. Now that I have amps and pre with XLR connections I would like to know if I can expect any noticable improvement. I am currently using a good set of "Acoustic Research Pro series directional balanced line audio cables".
Thoughts?
Thoughts?
Generally it depends on the way that the balanced connectors are integrated, and if it is a truly balanced design.
YES to ^^^^^
agreed, just because a piece has balanced connections, doesn't make it a completely balanced circuit.
As always, try for yourself and find out, but...I might opt for some better cables than those AR's.HT SYSTEM-
lsi 9's -
How am I supposed to know if it is"truly balanced" then? Tony, if you think the cables I have need upgraded, where should I start? What's a good compromise between budget (say $100) and quality?
Thanks all!Gustard X26 Pro DAC
Try out some inexpensive XLR cables from Monoprice and see what you think of the sound of the balanced connection. Probably the cheapest way to proceed.
https://www.monoprice.com/product?p_id=4754 -
Ok. Ordered some from Monoprice. I also have another set of RCA' s I found. No name on them but they look like good quality and appear shielded. I'll give them a try tooGustard X26 Pro DAC
Cool. Interested to hear your thoughts. I use those XLR cables to hook up my powered monitors!Ok. Ordered some from Monoprice. I also have another set of RCA' s I found. No name on them but they look like good quality and appear shielded. I'll give them a try too
So I hooked up the name cables and either it's the placebo effect or the high frequencies have just been turned up a notch! Can't wait to see what new XLR's will do!Gustard X26 Pro DAC
So you go from AR to Monoprice seems a sideways move to me. I wouldn't buy monoprice anything. We use them at work and the failure rate is very high.
I dont think he went sideways, I think he got some Monoprice XLR's. If that is in fact sideways I'll be a onkeys muncle
Also Audio Advisor's has some Pangea's they just started selling
http://www.audioadvisor.com/prodinfo.asp?number=PGIXCA2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Thoughts?
I used those once, until they removed an outer shield of one of my board mounted RCA terminals.
If those have a tight grip also I would use them carefully. -
That is not a problem with XLR. They lock in and use a ground pin unlike RCA -
Yes they are quite tight. I twist them as I take them on and offGustard X26 Pro DAC
I use these between my Oppo 205 & Parasound P5. They are nice & won't break the bank.
cullencable.com/copper-series-xlr/ -
Nice suggestion and possible upgrade path if he likes the sound of the XLR connection with the Monoprice wires.I use these between my Oppo 205 & Parasound P5. They are nice & won't break the bank.
Thanks Dave! That's perfect! Just under budget too!Gustard X26 Pro DAC
agreed, just because [your equipment] has balanced connections, doesn't make it a completely balanced circuit.
Samsung 60" UN60ES6100 LED Outlaw Audio 976 Pre/Pro Samsung BDP, Amazon Firestick, Phillips CD Changer Canare 14 ga - LCR tweeters inside*; Ctr Ch outside BJC 10 ga - LCR mids, inside* & out 8 ga Powerline: LR woofers, inside* & out *soldered LR: Tri-amped RTi A7 w/Rotels. Woofers - 980BX; Tweets & “Plugged*” Mids - 981, connected w/MP Premiere ICs Ctr Ch: Rotel RB981 -> Bi-amped CSi A6 Surrounds: Premiere ICs ->Rotel 981 -> AR 12 ga -> RTi A3. 5 Subs: Sunfire True SW Signature -> LFE & Ctr Ch; 4 Audio Pro Evidence @ the “Corners”. Power Conditioning & Distribution: 4 dedicated 20A feeds; APC H15; 5 Furman Miniport 20s *Xschop's handy work -
Monoprice interconnects in general. HDMI, RCA but no XLR stuff.
Yes not all gear with balanced inputs/outputs is a balanced topology inside. -
How'd it go with the Monoprice XLRs?Ok. Ordered some from Monoprice. I also have another set of RCA' s I found. No name on them but they look like good quality and appear shielded. I'll give them a try too
I could not tell the difference between the XLR's and the RCA's I have. Could just be my poor old ears have finally hit their sonic limit.Gustard X26 Pro DAC
Perhaps. Or it's possible that the way the XLR connectors are implemented on the B&K amps aren't dramatically different/better than the RCAs.
Another possibility is that the Monoprice cables are "not good". But you didn't mention that they detracted or took anything away from the sound.I could not tell the difference between the XLR's and the RCA's I have. Could just be my poor old ears have finally hit their sonic limit.
On my gear I have a choice of either xlr and rca connections. The specs show there's 4db better s/n using the xlr's. With that and a more solid connection with the xlr's I use balanced where ever I can.
Does it make a difference in the sound? Nothing startling that jumps out at me. The biggest change I've noticed is a quieter background. It seems like a no-brainer to me to use the xlr's and I'll gladly take that 4db difference for just a simple cable swap. -
Correct, I mis-read his post and was referring to the un-balanced AR RCA's which had a death grip on the ones I used once before. -
balanced interconnects can cancel out common-mode noise and (of course) are also shielded.
http://www.rane.com/note110.html
http://www.rane.com/note151.html
http://web.mit.edu/jhawk/tmp/p/EST016_Ground_Loops_handout.pdf -
I have been very happy with how my Signal Cable analog 2 XLR's compared to my former Hero WBT RCA's. SC's = $59, Hero's = $329! I run them from my Benchmark DAC2 to my Parasound A21 amp.
Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2 -
If you are looking for a great bang for the buck balanced interconnect cables, please take a look at our Bravo XLR IC's with Vampire Wire XLRF and XLRM connectors. At $139 for a 3 ft. pair, I'll just about put them up against anything else out there. Of course Polkies get a 10% discount tooSunfire Theater Grand IV
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
http://www.douglasconnection.com -
helipilotdoug wrote: »If you are looking for a great bang for the buck balanced interconnect cables, please take a look at our Bravo XLR IC's with Vampire Wire XLRF and XLRM connectors. At $139 for a 3 ft. pair, I'll just about put them up against anything else out there. Of course Polkies get a 10% discount too
Hey Doug - I received mine today and they look great and sound even better.Living Room
Parasound HINT 6, Yamaha Aventage RX-A 1060, Oppo 103D, Cambridge Audio Azur 851N, KLH Model 5s, Polk CSi A6, Samsung 65" LED
Office
Yamaha A-S501, Auralic Aries Mini, LSiM 703s
Douglas Connection ICs and Cables -
rburgess714 wrote: »helipilotdoug wrote: »If you are looking for a great bang for the buck balanced interconnect cables, please take a look at our Bravo XLR IC's with Vampire Wire XLRF and XLRM connectors. At $139 for a 3 ft. pair, I'll just about put them up against anything else out there. Of course Polkies get a 10% discount too
SRS 2.1TL
SDA 2BTL's
CSiA6
FXiA4
FXiA6
SDA 2A's
Monitor 10A's
