New 1C Purchase Questions
SCompRacer, The 1C's have a pin blade interconnect cable. I'm hoping the guy wired them up right as I have no idea they are supposed to be. Currently the pin in one speaker goes to the pin in the other.All, I have noticed some weird stuff going on with these speakers that may explain poor sound quality.
**When I turn the balance all the way to the right,
On the right speaker:
I hear full volume on all drivers and bottom tweeter. Quieter sound coming out of the top tweeter.
I would expect full tweeter volume from the upper tweeter, restricted HF from the lower tweeter. The schematics hosted on this site show the upper tweeter is the "main" one, with shunting and additional filtering for the lower tweeter--unless the schematic isn't showing the actual placement of the tweeters. At any rate, one loud and one softer is normal.On the Left speaker:
I hear reduced volume on the outer drivers and nothing on the inner drivers and nothing out of either of the tweeters.**When I turn the balance all the way to the left,
On the left speaker:
I hear full volume on all drivers and bottom tweeter. Quieter sound coming out of the top tweeter.On the right speaker:
I hear reduced volume on the outer drivers and nothing on the inner drivers and nothing out of either of the tweeters. -
Ok so I need to build new interconnect cable with just the pins... Copy. Does anyone make gold plated pin terminals? Thanks again for all the help!
do you have the correct pin/blade factory interconnect cable? If not look below.
https://www.ebay.com/itm/Interconnect-Cable-Polk-Audio-SDA-SRS2-3-Speakers-others-20ft-Gold-New-Read/382305899983?hash=item59033515cf:g:DDMAAOSwR29ZDIPR -
Update. So I found out that my Carver 1.0 is the non common ground one. That is why my speakers sounded lame. I had the left channel inverted via Carver's wiring diagram. I guess these old ones were mainly intended for mono use. If I get the A1 dreadnaught interconnect setup how does that affect sound quality compared to a common ground amp? I am currently running them on a lowly Carver MXR receiver (that apparently everyone here hates) and they sound fantastic! (I don't play my music at ear bleeding levels though).Gustard X26 Pro DAC
The Dreadnought will allow you to use any non-common ground amp including mono blocks. The sound is vastly improved using the Dreadnought even with common ground amps.Political Correctness'.........defined
President of Club Polk -
Forgive me audioluvr but are you referring to a M1.0t?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Garage #2: Cambridge Audio EVO150 Integrated Amplifier, Polk L200's, Analysis Plus Silver Oval 2 Speaker Cables, IC's TBD. -
The earliest version of the M1.0 had one channel opposite polarity of the other. This was "corrected" at the output terminals by reversing the color code of the inverted channel.
With typical monophonic bass, the bass notes would draw power from both the + (one channel) and the - (the other channel) power supply. This lessens the load on the power supply. It also makes bridging to mono very, very easy.
Of course, since one channel cannot tie the negative output terminal to ground, these early 1.0s cannot be made common ground.
Later M1.0s did not have the inverted channel, and the output terminals and such was different on the back panel, which is how they're easily identified. Still later (I think) came the M1.0 "T" version which also does not have an inverted channel. -
Thanks Schurkey. I had to look at both of my M1.0t's and yes they are the non-inverted ones. Whew !!!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I have one of the first 1.0' s made sn#0012XX. These were a much simpler design internally. I'm trying to decide if I should get another amp or go with the dreadnaught setup. My budget (~$400) is about the same either way.Gustard X26 Pro DAC
Dreadnought2-channel: Modwright KWI-200 Integrated, Dynaudio C1-II Signatures
Well Dreadnought it is! Now if I can maintain the patience to wait for someone to build one for me... On to the DIY upgrades! Got the RDO-194's in and the PR baskets dynomatted so far! Sound great!Gustard X26 Pro DAC
Update: Well got all the upgrades done except crossovers. Cabinets sealed, Dynamat, BH5 (Sonic Barrier), batting repositioned, deoxit all connections, magnets glued, RDO 194's, MD weatherstripping, and spikes.
Just got my Carver M1.0 back from a full restoration. Holy crap! Good thing I don't have neighbors! Just turning it up enough for the first set of meters to flicker felt like china was going to vibrate off the wall. Can't imagine why you'd want one of these for each channel. Rolland at Hi-Tech did an amazing job.
I will listen to them until this weekend and then the crossovers are going to DHS. While they are away I will finish the Dreadnaught build. Can't wait to hear what it all does for the system.
Sorry but there is better than the cord caulk. Your gaskets look to be in good shape on the drivers. Armacell pipe tape works wonderfully and is less likely to strip screw holes or pull off part of the front baffle. Drivers come out much easier with the armacell.
It can be sourced from Home Depot. -
The "cord weatherstripping" (around here, it's referred to as "Mortite" as that is one brand name of the stuff, Dennis is another brand name, and it's also generically called "rope caulk") will be a mistake.
The stuff works GREAT for sealing drivers to the cabinet. And then at some point you need to remove the drivers, and it's near impossible to pry them back out of the cabinet. And then you get to clean-up the mess all that smeared and crushed caulk makes before you can re-assemble the drivers back into the cabinet.
Just use gaskets on the drivers. Leave the rope caulk for other applications. -
Too late. I rolled it out to a fine bead to prevent excess from squishing out. I almost never drive speakers hard. Should be fine for as long as I am aroundGustard X26 Pro DAC
Remove it now before it's too late. Very bad choice.Political Correctness'.........defined
Oh all right. If you say so. Wasn't really doing anything this weekend anywayGustard X26 Pro DAC
What size did you cut for the BH5??? Thanks!!!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
A 4" wide vertical strip behind the drivers starting flush with the bottom driver.Gustard X26 Pro DAC
Thank you!!! How far did you run it upward? Hard to tell with the pic, but it looks like it is flush with the top of the MW?Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
You want a 3 or 4 inch wide strip directly behind the mid-drivers only.Political Correctness'.........defined
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
nooshinjohn wrote: »
Or sell it to me -
While still waiting for @westmassguy to build my crossovers I did some more work on my 1C's. Yesterday I built my 800va dreadnaught, built IC cables with Speak-on terminals, rebuild the terminal cups, soldered all connections, coated the back of the Speak-on terminals with liquid tape...
Suspecting a poor factory seal I resealed the back of the cups with this stuff...
Because I didn't want Jesse to get mad at me for using rope seal...
Then I pulled the RDO194'S to fix the crappy basket design. Being borderline obsessive compulsive ( friends say there's no borderline about it) I felt just putting washers on the backs are not going to do it. So I added rope seal (sorry Jesse) around the magnet and perimeter. This totally dampened it and made the stock gasket much more effective.
Dynamat those backs after adding washers. JATDon't take experimental gene therapies from known eugenicists.
Hi @audioluvr you may want to consider sealing the outer corners as well. Based on the pic, their could still be a leak path in those areas!
FYI - I added the washers on my new tweets as well. I re-purposed the original SL2000 gasket however.
I like how you marked the polarity of the terminals. Good idea!Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
Hey I noticed you put some dynamat on the brace in between the MW's. Never seen that before. Is that recommended?
UghPolitical Correctness'.........defined
If I may be so bold to translate @F1nut (not sure why he's limited to single syllable words today)
Ugh = Armacell Foam tape. All the rage these days.Basement: Polk SDA SRS 1.2tl's, Cary SLP-05 Pre with ultimate upgrade,McIntosh MCD301 CD/SACD player, Northstar Designs Excelsio DAC, Cambridge 851N streamer, McIntosh MC300 Amp, Silnote Morpheus Ref2, Series2 Digital Cables, Silnote Morpheus Ref2 Series2 XLR's, Furman 15PFi Power Conditioner, Pangea Power Cables, MIT Shotgun S3 IC's, MIT Shotgun S1 Bi-Wire speaker cables
I think he uses the roll of speaker foam they sell at parts express."Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life."
