RTA 11t's needing Something
audioluvr
audioluvr Posts: 6,050
edited January 2018 in Vintage Speakers
I have a pair of RTA 11t's that I picked up I'm trying to figure out what to do with. They just don't sound very good and I'm wondering if I should upgrade or just get rid of them. Could be my 1C' have me spoiled but the highs are kinda harsh and the bass is very diminished. The cabinet seal is very good so it can't be that. Is there something in the crossovers that is causing this or is this a common problem?
  • FestYboy
    FestYboy Posts: 3,861
    I've never felt there wasn't enough bass from either of my 2 pair of 11Ts, as for the "harsh" highs, you may want to look into TL modding them with the RDO-198s.
    What are you driving them with? Have they ever been opened? Possible polarity issue if so.
  • skrol
    skrol Posts: 3,487
    Also, they should respond well to upgrading the XO caps to some ClarityCaps or Sonicaps.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • westmassguy
    westmassguy Posts: 6,850
    Something is wrong. The 11t/tl are the sweet spot in the MTM RTA line. Great vintage Polks
    Home Theater/2 Channel:
    dhsspeakerservice.com/
    These are bone stock. Was running them with an NAD T753. While I wait for Dave ^^^ to rebuild my crossovers on the 1C's I'll open them up, do some updates, check polarity and maybe throw in some 194's to see if that helps. As for upgrading the crossovers, that will have to wait for now
  • 11tsteve
    11tsteve Posts: 1,166
    Mine went from night to day with a crossover upgrade to Sonicaps and Mills resistors.
    Plus, I am sure the poly switches were shot, which can give a muddy, muted top end.
    I used a 0.5 ohm Mills to replace those.
    A possible experiment might be to remove the crossovers, and replace the poly switch with a jumper just to see if perhaps they are a problem. Depends on what kind of money you want to sink into the speakers.
    Polk Lsi9
    N.E.W. A-20 class A 20W
    Keces DA-131 mk.II
    Paradigm DSP-3100 v.2
    Well I pulled them back out of storage to start updating them. Dynomatted all baskets and swapped out a couple of RDO-194's from my 1C's to see how much that would help. Then I noticed one of the tweeters was not working. Pulled it and stuck a multi- meter on it and sure enough, no signal. Looks like a crossover upgrade is in order...
  • FestYboy
    And down the rabbit hole you go.
    Tick, tock... Deeper I go.
    WTH. It's just money... I can always make more!
    11tsteve wrote: »
    Thanks Steve. I'll probably do the whole shebang like you did.
  • TNTsTunes
    audioluvr wrote: »
    11tsteve wrote: »
    If you do the whole shebang step up to the TL tweeters and use RDO198's. Cost wise it's probably not much of a difference.
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
    Hmmm. What's different crossover wise?
  • TNTsTunes
    TNTsTunes Posts: 751
    edited February 2018
    11t
    https://us.v-cdn.net/5021930/uploads/attachments/4/6/7/2/8/18707.pdf
    11tl
    https://us.v-cdn.net/5021930/uploads/attachments/4/6/7/2/8/18708.pdf
    Not too much, just a few changes in the tweeter circuit.
    Cap wise the 11t uses two 12uf caps, 11tl uses a 12uf and 16uf cap.
    Resistor wise the 11t use a .5 ohm resistor to replace the poly switch, a 2.7 ohm and 2.0 ohm resistors. The 11tl doesn't use a poly switch and only uses a 1.5 ohm resistor.
    To make an 11t into a11tl you would need a .3mH inductor to replace the .4mH inductor the 11t uses.
    Thanks!
    Well unless I can source 2.7 ohm Mills resistors it looks like a TL mod is in order. Anyone know which is the best / correct inductor to use? Parts Express carries 14, 18 and 20 ga. air core.
  • TNTsTunes
    Here you go.
    2.7 ohm Vishay Mills resistor.
    soniccraft.com/product_info.php/27-ohm-vishay-mills-mra-12-p-4636
    For the TL mod inductor choice matters.
    I believe this is the correct inductor Jantzen 000-1452 .30mH .55ohm AWG 22
    Maybe @westmassguy can verify this.
    You'll need to order it from this site below. No one in the states will special order it for you.
    https://hificollective.co.uk/catalog/000-1452-0-30mh-jantzen-air-core-wire-coil.html
    Since it is special order it takes 18 days for them to get it.
    Airmail tracked and signed takes about 7 days. FedEx Int. takes 2-3 but costs almost twice as much.
    I've place multiple orders with them and they went great.
    I'm hoping a 33uF cap will work since I can't find a 34uF one. Thoughts?
    Never mind. Just talked to @westmassguy and the 33uF are within tolerance
    Post edited by audioluvr on
    F1nut Posts: 52,270
    audioluvr wrote: »
    Sonic Craft carries the 34uF, same place for Mills resistors.
    Thanks F1. My uncanny ability to not see what's right in front of me must be active again. I will keep looking.
  • Rrusse11
    Rrusse11 Posts: 116
    audioluvr,
    Don't know where you are, but here's an orphan RTA 11tl, be good for parts if nothing else perhaps.
    https://baltimore.craigslist.org/ele/d/polk-audio-rta-11tl-tower/6486339993.html
    SDA SRS 2.3s
    Pair of Carver TFM 35s
    Carver C-1 Preamp
    CAL Icon MkII CD
    RTA 12s, need major work
    WOW. Never see deals like that in the West coast.
  • Rrusse11
    Rrusse11 Posts: 116
    SDA SRS 2.3s
    Carver C-1 Preamp
    CAL Icon MkII CD
  • FestYboy
    Rrusse11 wrote: »
    audioluvr,
    You can pass on this... The quality of the pieces from that seller is poor to atrocious. Thinks everything is worth gold untill it sits for months on CL, then there's the issue of contacting him...
    If you really want it for parts, sit on it for a while longer, then go in low.
    Rrusse11 wrote: »
    Closer yes. Still 650 miles South of me. I went ahead and ordered all the components to upgrade the crossovers as is and have RDO-194's coming. Should suit my needs quite well once done. I'll keep you all updated.
    Thanks all!
    Well I rebuilt the crossovers using the Dayton Audio caps 5% on the low pass and 1% on the high pass. I started by removing the hot glue, cutting off the old caps, resistors and poly switch, labeling the location as I went.
    Then I desoldered and removed the old leads. Next I drilled new holes farther apart for the 0.5 ohm resistor that replaces the poly switch and an extra one so the 12 uF cap and 2.0 ohm resistor don't have to share a hole. This made reinstallation way easier and because the new caps were quite a bit larger than the originals, gave me more room. Next I moved the inductor over a little installed all but the one one cap that previously shared a hole with the resistor then stacked the last cap on top.
    I pushed all components down tight then bent over all leads and trimmed any excess. This keeps everything tight and in place plus if for some reason fitment isn't right I can still adjust. Finally I soldered and hot glued. Not sure if this is how the professionals do it but it worked well for me.
    I did listen to one new and one old to see if I could hear any difference. I noticed that the vocals were far more clear and highs seemed a lot smoother. Still waiting for the new RDO'S but I really like what I am hearing so far.
    Thanks again everyone for all the help!
  • westmassguy
    The 12uf and 34uf are reversed
  • [Deleted User]
    Chemtronics makes a Flux-Off aerosol (carried at Digikey) that will get rid of the brown flux left after soldering.
    pitdogg2 Posts: 27,738
    One other thing the resistor should never be covered in hot melt glue.....
    91% alcohol on a Q-tip works also.
    You funny! They are not polar.
  • FestYboy
    audioluvr wrote: »
    I believe he's saying that they are in the wrong positions.
  • westmassguy
    FestYboy wrote: »
    audioluvr wrote: »
    Bad wording on my part. The 34 should be closest to the edge of the circuit board, the 12 closest to the shunt inductor.
