Steelers got robbed
That ball crossed the plane in control...... :#
    F1nut Posts: 49,846
    The ball never touched the ground, they got hosed.
  • motorhead43026
    Here come the Squealers :p
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    The best way to predict the future is to invent it.
    It is imperative that we recognize that an opinion is not a fact.
    Imagine making politics your entire personality.
  • Jimbo18
    Jimbo18 Posts: 2,314
    la2vegas wrote: »
    You have to control the ball all the way to the ground.
    He didn't.
    Yeah, unless you are a RB, then you can reach across and lose the ball and it's a TD. How is that okay, but the catch he made wasn't? I know that's the rule, but it's dumb, he obviously caught the ball and had control as it crossed the plane.
    txcoastal1 Posts: 13,134
    It's the "dez rule"....stoopid but it is what it is
    la2vegas wrote: »
    txcoastal1 wrote: »
    Correction, it's the Calvin Johnson rule.
    What was in the news more...tit4tat...whatever
    tonyb Posts: 32,908
    By the other rules, ball crossed the plain, he had control of the ball. In my view, the play was dead as soon as his knee hit the ground while in complete control of the ball.
  • machone
    machone Posts: 1,483
    Tom Brady go away and let somebody else play. :/
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
  • Upstatemax
    Upstatemax Posts: 2,625
    tonyb wrote: »
    I agree with you that in these situations it should stand.
    But, the current rule does not agree with us. If the receiver loses control of the ball while coming down, it’s not a catch.
    As the rule is now, it was the right call.
    F1nut Posts: 49,846
    His right hand had control of the ball the entire time. They got hosed and I really don't like the Steelers.
  • motorhead43026
    motorhead43026 Posts: 3,892
    edited December 2017
    I am still pi$$ed @ the Steelers for the "The Immaculate Reception"
    Serves them right.
    Serves them right.
    That happened so fast the cams didn't even catch it
    tonyb Posts: 32,908
    But he didn't lose control, he had it even after his knee hit the ground. If your going to say the ball is still live after he hit the ground, then the ball crossed the plain while in his control. How long after he hits the ground does he have to maintain control ? Because he hit the ground before crossing the plain with complete control. The very least....it was a catch at about a foot short.
  • jeremymarcinko
    He is not down till he’s touched. The receiver has to control the ball all the way to the ground. He lost control when his elbow hit the ground. Had he made two steps prior to losing control then he would have been a runner with possession of the ball and would have only needed to cross the plane. But he wasn’t cause he didn’t and consequently dropped the football making it an incomplete pass.
    They got the call right.
    Long story short, if New England would have touched him when his knee hit the ground, before reaching over the goal line, the ball would have been placed on the 1' line....like I said...stoopid rule
  • Upstatemax
    He has to make a "football move", which is an insanely ambiguous term.
    Usually it would mean planting your feet and moving while controlling the ball.
    What he did was all under the umbrella of "coming down with the ball". If you bobble the ball and it contacts the ground AT ALL, it's a no catch.
    That ball clearly had contact with the ground.
    Yes, he had control of the ball when he stretched out, but it's a moot point here. It's not a completed catch since he lost control while coming down. You can't rule a play a TD with an incomplete pass...
    The concept of the "the running back can lose control after it passes the line" does not count here. A RB's possession and a receivers possession fall under totally different rules. The RB's rule would have applied IF he was considered a runner (completed the catch and running with the ball), he was not.
    He was a receiver that failed to maintain control while coming down with the ball.
    tonyb Posts: 32,908
    Gotcha, if your a running back, you can be the clumsiest MF on the planet, but a receiver has to catch the ball, do 2 forward flips, a back flip and plant his body 4 inches into the dirt before its a catch.
    Good point Skip on the football move.
    F1nut Posts: 49,846
    He caught the ball, his knee was down, he wasn't touched and basically carried the ball into the end zone. It is not the same as catching the ball in the end zone. It was a touchdown.
  • Upstatemax
    Again, I agree that it should stand.
    But the rules don't. Everything he did was "in the act of going to the ground" and in the end, he did not maintain control all the way down.
    I don't agree with it, but the rules are what they are.
    But he would have been down if the D would have touched him when his knee hit the ground prior to him reaching over the goal line
  • Upstatemax
    txcoastal1 wrote: »
    If he maintained possession of the ball...
    His stretch and attempt to get the TD cost him control and it cost him the catch.
    tonyb Posts: 32,908
    Upstatemax wrote: »
    txcoastal1 wrote: »
    But at that point, he is no longer a receiver since he's already on the ground. Then, all he needs to do is cross the plain, control after that is irrelevant. No ?
  • Upstatemax
    Simply, no.
    His pivot and stretch were all part of him going to the ground with the ball.
    When making a catch like that, until he is fully on the ground with clear possession, it’s not a catch.
    This same rule has burned, and benefited every team in the NFL.
  • Conradicles
    Conradicles Posts: 6,045
    Nothing y'all say matters. Game Over.
  • aprazer402
    aprazer402 Posts: 3,106
    txcoastal1 wrote: »
    Serves them right.
    Should have been an Incomplete Pass IMO, Old, old news anyway.Carry on. :)
    nooshinjohn Posts: 25,122
    And in other news... Teddy Bridgewater found his way back under center for the first time since nearly loosing his leg in a gruesome non-contact knee injury.
  • jeremymarcinko
    Being an unfortunate Browns fan, I just like reading the title of this thread and watching it stay at the top of the recent discussions.
    Bump.
  • motorhead43026
    DSkip wrote: »
    Can't rob the poor eh?
    You can rob them of their dignity.
  • gmcman
    gmcman Posts: 1,765
    If you watch the replay of the Steelers catch, he caught the ball and held it steady with both feet in the air, then both feet touched along with his knee. At that point it was a controlled catch imo.... then he reached for the plane, and crossed it. I understand about control to the ground, but he already did that.
  • trav0810
    trav0810 Posts: 1,056
    This is one of those rules that grants far too much power to the officials. It isn't clear cut and allows them to alter the outcome of a game.
    That being said, the Steelers still had the opportunity to AT LEAST take the game into overtime. Throwing into traffic like that was a flashback to the Patriots/Seahawks Superbowl.
    The difference between genius and stupidity is; genius has its limits.” -Albert Einstein
    Sony Playstation 3 for CD and Streaming
    Thorens TD320
    Modified Carver C-1
    Carver TFM 42 and 45 Amplifiers
    Polk RTA15TL Speakers w/Decato mods
    White Lightning Moonshine DIY Speaker Cables and Interconnects
  • motorhead43026
    ^^Agree, so they didn't deserve the win anyway.
