Why i feel a 2 channel setup is the best for your average joe and music lovers.
1. you can spend more money on your main speakers and get a much better set of speakers., so basically if you are on a budget and most people probably are you can buy 2 nicer speakers or you can buy 5 or 7 lower grade speakers with the money you have set aside for your speaker budget... now if you you can afford to buy really nice speakers all the way around in a surround sound set up awesome. In my opinion my 2 channel set up sound excellent for movies and music. i just don't have sound coming from different parts of my room so maybe there is a little magic missing but i would trade that for better sound quality any day..
2 less wires to run. and less money to spend on speaker wires. you could probably spend just say 100 bucks on say 20 feet of excellent quality speaker cable or 100+ bucks on longer runs of the cheaper stuff. allot of people don't think speaker cable makes a difference. i never did either till i got a set of revealing speakers and tried different types now with these speakers i hear a very noticeable difference between my AQ solid copper wire which cost me 100 bucks vs my mono price stranded budget wire which was like 20 bucks for a small spool..
3. with a AVR which is what most people get for surround sound you are paying for several channels of amplification and they are often not the highest quality parts inside., you are paying for all kind of digital processing with a AVR---- now with a good quality 2 channel amp your paying for standard 2 channel amplification that is often made with much higher quality parts inside whith will often result in higher overall sound quality..
here are 2 photos of what you generally see inside of a AVR type receiver.
now here are 2 photos of what you may find inside of a nice 2 channel amp
i believe you can get much better sound quality for your money going with a 2 or 2.1 channel set up vs a 5.1 or 7.1 channel set up.. my current set up sound much better for movies and music than the surround sound systems i had in the past ever did.
my buddys crazy 7.1 home theater set up which was extremely expensive and it does not sound that much better than my 2 channel set up for movies( in my opinion) but when it comes to music i would say mine sounds way better than his. i was never really happy with the AVR's i have had in the past for listening to music but i did enjoy them for movies. i actually enjoy my current 2 channel set up for movies and music better than anything i have has in the past now that i finally have some good quality stuff all the way around. if i were to put the money i have in this setup into a surround sound system i would have bough much lower quality everything..
i personally feel you can get allot more for your money sound quality wise going 2 channel..
Cambridge Azur 651A
Polk LSi M703
Sonos Connect
«134
    mhardy6647 Posts: 33,049
    edited December 2017
    What, like I'm gonna disagree?
    Post edited by mhardy6647 on
    PS (and FWIW), this is more along the lines of what I like to see inside an integrated amplifier...
    (not my HF-81 -- the one in the borrowed photo above is considerably prettier than mine inside)
  • TNTsTunes
    I look at it this way, when you go and watch a band do they just produce a front soundstage or play in surround sound? I want my music system to recreate the feeling of watching a band play.
    Surround sound systems are for watching movies in your home theater.
    Apples and oranges....
    "Make a man a fire and he'll be warm for a day. Light
    a man on fire and he'll be warm for the rest of his life."
  • mikeyb128
    mikeyb128 Posts: 2,885
    I’m not disagreeing either!
    2 channel:
    Theater:
  • motorhead43026
    Tube snobs.
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    The best way to predict the future is to invent it.
    It is imperative that we recognize that an opinion is not a fact.
    Imagine making politics your entire personality.
  • ZLTFUL
    ZLTFUL Posts: 5,640
    You're comparing the differences between a Ferrari and a Rolls Royce...
    Are they both awesome? Yeah.
    But they have 2 distinctly different purposes.
    A properly set up and calibrated home theater surround system can create ambient noise effects that a 2 channel system has no hope in Hades of recreating.
    At the same time, a solid 2 channel system can create a holographic front music sound stage that tends to be muddied by a surround system.
    Nothing personal here but if your buddy's 7 channel surround doesn't obliterate your 2 channel system for movies then frankly, regardless of what he spent, it is NOT calibrated correctly or something is severely broken.
    mikeyb128 wrote: »
    Yers is (much) prettier! :)
    (beautiful, in fact)
  • motorhead43026
    mikeyb128 wrote: »
    Mikey, what is the name of the color on the walls?
    ZLTFUL wrote: »
    Well put.
    I will say this - I get way less worked up about "soundstage" and "imaging" than I do about instruments and vocal(ist)s sounding real -- which to me is more about tone and timbre than it is about imaging... although a hifi needs to get the size of an instrument correctly.
    I vividly remember hearing Magneplanar Tympani IBs' reproduction of a piano. It sounded pretty good, but it was about three times the size, in sonic terms, of an actual piano.
    Impressive -- but not right .
    (and, not that this is germane to the topic at hand, I personally have zero interest in "home theatre")
    gudnoyez Posts: 8,066
    Why not have a decent 2 channel rig and a decent HT rig, do this get the new David Gilmour live in Pompeii Blu Ray listen to it on a 7.2 HT rig and report back. It's glorified Surround sound heaven, of course you can get the David Gilmour live at Pompeii CD and enjoy it on a decent 2 channel rig.
  • ZLTFUL
    ZLTFUL Posts: 5,640
    gudnoyez wrote: »
    Chris Botti in Boston on BD or Cream at Royal Albert Hall or Dave Matthews at Radio City are 3 other great examples of this as well.
  • cfrizz
    cfrizz Posts: 13,415
    gudnoyez wrote: »
    Because some of us don't have room for two separate systems, and even if I did, I still wouldn't have two systems.
    I'm not so fanatical that I let what I may or may not be hearing in music send me into crazy mode to buy more gear and take my system apart trying to hear EVERYTHING.
    I don't/never had locked in preconceived notions that 2 channel is the best, it is simply one way of listening to audio be it movies or music. I had a 2 channel system for years, then I expanded for movies and found a new way of listening to my music as well as movies.
    I switch back and forth as the mood strikes. There is no right or wrong way, and there also is no best way. It is whatever you like, want, and can afford.
  • Polkaguy58
    TNTsTunes wrote: »
    It depends if you're watching Roger Waters or The Dead , they had holographic sound at their venues.
    I'll stick with two channel also.
    Tony M Posts: 11,017
    I have 6 systems hooked up, Outside in the main-cave. 1 surround system..( main TV system ) Yamaha with 2 -12" Klipsch subs and Powered towers , powered center and bi-polar surround speakers mounted 7' up. Exc. sound ! Movie wise. I've never tried to do 2 channel on it too much since I acquired the SDA-SRS2's.
    1 more surround system in the back room. w/powered sub. Not to shabby either.
    5 other 2 channel systems of various costs , ages and purposes. Some EXC., some not to shabby either.
    2 systems inside. JVC Surround sound receivers w/sub outs hooked up to powered subs. Exc. sound for TV and movies! The living room JVC is hooked up to Pinnacle Black Diamond surround speakers and a Pinnacle sub. ( the cheap one..) and on music mode, It is BEAUTIFUL sounding. I guess speakers also play a major part in how the surround systems sound with music.
    These 15 or twenty year old receivers in the house are so good I've never had the desire to want to replace them with 1200.00 receivers that I own or have owned.
    They are JVC- RX-DV31's. Built in DVD players. I have a Blu-ray hooked up to both of them for years now.
    I love a holographic 2 channel system where you can sense the artists are in the room with you. I lived long enough to have experienced it many, many times. I love it.
    But I love watching movies too. Movies would take my mind off my neck issue too.
    A girl once told me about her still being a virgin...
    " you can't miss what you've never had "
    I have long adapted that phrase to say " you can't miss what you've never heard " ;)
    Toolfan66 Posts: 16,925
    If I had the right room I would have a nice system that allows me to go between 2 channel and 7.1 Nothing like having a great Pre Amp with HT bypass..
    They are both great and fun to play with...
  • TNTsTunes
    Polkaguy58 wrote: »
    TNTsTunes wrote: »
    Never saw the Dead live and the only time I've seen Roger Waters live was at a Pink Floyd concert.
    My 2.3's do a great job reproducing Pink Floyd however.
    For serious music listening, 2 channel is the only way.
    Concur (FWIW).
    (although I will confess to using a subwoofer, Philistine that I am)
  • oldrocker
    oldrocker Posts: 2,590
    mikeyb128 wrote: »
    Purdy indeed!
    F1nut Posts: 49,806
    Concur (FWIW).
    Subs are ok and depending on the mains, much needed.
    tonyb Posts: 32,906
    Eh, splitting hairs here. Cathy made a good point though. To have 2 systems with decent quality for both music and movies can get costly.
    Having one, that can do both, with better than average front end electronics can be extremely enjoyable, cheaper than 2 systems, and wife friendly.
    We all have different needs too, different wallets, different ideas of what good sound actually is. There is no hard and fast rules cast in stone. Simply enjoy your music as you see fit. What was the point of this thread again ? :)
  • Thorton
    Thorton Posts: 1,324
    ZLTFUL wrote: »
    Well said.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • Thorton
    Toolfan66 wrote: »
    Yes and I totally agree with what you're saying. But if you significantly prefer on over the other, the other will sacrifice. I like having both to where each one makes me shiver and it is absolutely fantastic!
    DAC: Bricasti M1SE
  • Thorton
    Concur (FWIW).
    Or the room or the optimal placement of the mains.
    DAC: Bricasti M1SE
    Concur (FWIW).
    Yeah, that's where we are here, with basically Altec 515s (i.e., the woofer sections of the 604E Duplexes) in large vented boxes... they are not noted for going very low... but what they do, they do well.
    My -- interesting -- subwoofer prototype is pretty respectable, I think (tho' I am no expert); it's certainly much better at reproducing LF in music than was the cheapie powered subwoofer I got some years back (but that's not saying too much, in all candor).
    38047648301_4927f0eb6a_b.jpgDSC_9751 (2) by Mark Hardy, on Flickr
  • BlueFox
    BlueFox Posts: 15,251
    Three channel is best, but unfortunately when RCA was recording that in the 50s it never caught on. My three channel SACDs in the HT are sweet.
    http://www.elusivedisc.com/RCA-Living-Stereo-Multi-Channel-Stereo/products/1094/
    With that said, I spend most of my time with the stereo.
    I think that the discrete three channel format (common in the 1950s in better recording studios) was generally upstream of the final product -- not that some folks didn't have three-channel systems (Sinatra, e.g.)... but it wasn't really a 'mass-market' format.
    In the early days of home stereo, it wasn't common to find some sort of center channel output on consumer stereo integrated amplifers (Sherwood, Scott, and EICO, to name a few with models that offered either line or loudspeaker-level "mixed to mono" center channel outputs).
    Col. Paul W. Klipsch was a proponent of a 'derived' third channel (mixed-to-mono) in the center for his loudspeakers... he advocated a Cornwall in the middle of a pair of K-horns, or a Heresy in the middle of a pair of Cornies for the low-rent crowd.
    I think this says more about the Heritage Klipsch loudspeakers' imaging deficiencies than it does about anything else, though. :)
    pitdogg2 Posts: 24,585
    I dunno Doc i think you need bigger doorbell transformers. Those look a little weak
    Polkaguy58 wrote: »
    TNTsTunes wrote: »
    Sorry but that was the acid.....
