Got a good deal on CRS pair... now what?
daddyjt
I had been watching these for a couple of days, and called the seller today and asked if they came with the SDA cable. I figured they didn't (if the cable IS included, it's almost always mentioned in the ad), and I was right. I asked the seller if he'd take $130, since I was going to have to fab a cable (which I would anyway!). He said yes, so now I'm the proud owner. Which brings me to a couple questions:
Are these a candidate for the RDO194 tweeters?
For the SDA cable, I was thinking to enlarge the original SDA cable opening and install Nutrik connectors - is this what others have done?
The woofers and passives look great - do they need any attention?
Anything else I should know about this model?
Thanks for any help or advice!
"Conservative Libertarians love the country, progressive leftists love the government." - Andrew Wilkow
― Aleksandr Solzhenitsyn
With correct XO mods, these will take either the 194 or 198. The baskets can be (should be?) Dynamated. There's also a thread that documents other upgrades if you want to go that far.
Have you determined which version CRS+ you have? There are 3 different versions that have different drivers, the 1987 version has the same drivers and crossover as a SDA 2A uses with 6510 drivers in all positions. The other two share the crossover a SDA 2B uses and will either have 6503/6511(1988) or 6510/6511(1989-91) drivers in them. The later two the versions can easily be upgraded with the RD0198/4.1TL mod done.
I believe a member here "westmassguy" has the info needed to update the earliest CRS+ version. He did the RD198/TL mod to some SDA 2A's.
Crossover and driver info can be found in the schematics posted at this link. It also shows a schematic for the RD0198/4.1TL mod. forum.polkaudio.com/discussion/55888/polk-audio-speaker-wiring-schematics-more-stereo-dimensional-array-sda
Here is a link to westmassguys SDA 2ATL "Franken-Polk" build. http://forum.polkaudio.com/discussion/143984/my-2as-finally-finished-almost/p1"Make a man a fire and he'll be warm for a day. Light
a man on fire and he'll be warm for the rest of his life." -
Here's a couple of good CRS+ build threads.
forum.polkaudio.com/discussion/169838/sda-crs-crs-something-different/p1
forum.polkaudio.com/discussion/172176/sda-crs-with-an-external-crossover-twist/p1"Make a man a fire and he'll be warm for a day. Light
Ok, thinking maybe I got hosed on this one...
Right speaker has 6503/6513 and sl2000
Left speaker has 6503/6503 and sl2000
The SDA connector is blade/blade, and both speakers have sw100 passives.
― Aleksandr Solzhenitsyn -
Got a crossover picture?"Make a man a fire and he'll be warm for a day. Light
Looks like someone did a down and dirty repair for a quick sale. Threw in any old Polk woofer. Those are blade/blade, 3rd generation by the looks of it. They should be all MW6510 woofers. The 6503 however, is the only replacement Polk has now for the 6510, so they'll most likely work just fine. You'll need one more 6503 though. Then again, if you want to do a correct restoration, you'll need four 6510s, and fleaBay is about the only place you'll find them (salvaged).Home Theater/2 Channel:
dhsspeakerservice.com/ -
Here are some pictures of the crossover - also, is there any issue with removing the wire mesh grill over the passives (aside from eliminating the protection it provides)?
Nope, remove away bro.
"....not everything that can be counted counts, and not everything that counts can be counted." William Bruce Cameron, Informal Sociology: A Casual Introduction to Sociological Thinking (1963) -
Definitely the first version of CRS+'s which are the 3rd CRS version(the first two had dual tweeters). That is the same type of crossover as a SDA 2A uses. They should be fine with 4 MW6503's in place of the original MW610's like westmassguy stated. He knows how to do a TL/RD0198 swap on that model too.
Still a good score all things considered.
Pick-up another 6503 and have wmg build the crossovers around those and a pair of 198's. Heaven.
What models used the 6513? Maybe it's just me, but that's not a model # which seems to come up often.
Why do you want to remove them?
President of Club Polk -
No real reason honestly. I took them off to remove the passives and check them over. I left them off for now, because the boxes sit flat while removing drivers and checking things over from the front. Then i started wondering why the grills were even there - I haven't grills like that since my car stereo days forever ago.
I think they will be a fun project - the boxes are in fabulous shape, and the grills are perfect. I'll grab another 6503 and a pair of 198's and then tackle the crossovers.
We must be neighbors - I had my eye on those too! I was going to go get them last weekend but the stars didn't align... This wasn't the first time those were up on KSL... that said, I was going to offer you a driver, but I just checked the garage and I only have 6502's. Interested to hear how they work out for you!Current Collection: Monitor 4a (Peerless), Monitor 5B (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), SDA CRS+ (194’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩
They are used in the AB700 for sure, as I'm staring at 4 of them. -
I read a post you made earlier today that said those use MW6012's???
According to this chart, they are only used in the SDA SRS 2.3. Might be a rare one, I will put it on eBay and maybe offset the price of the 6503 I need.
https://us.v-cdn.net/5021930/uploads/attachments/4/6/7/2/8/35349.pdf"Conservative Libertarians love the country, progressive leftists love the government." - Andrew Wilkow
I'm in Layton - just north of SLC. Thanks for the thought on the driver!
Farmington!Current Collection: Monitor 4a (Peerless), Monitor 5B (Peerless), Modified Monitor 7b (Peerless), RTA15TL (SL3000), SDA CRS+ (194’s), SDA SRS 2.3TL, R100's, R200’s, R300 🤩 -
If the 6513 is from a 2.3 it will have a donut weight on the drivers face. It might just be a 6503 with the donut added, I'm not sure.
Sorry, you're right, the AB700 are mw6512, not 6513 -
Looking at the schematic that is it. 2x6510
2x6511
2x6513 -
Not all 6513's came with the donut. Just another quirky part of SDA history.Political Correctness'.........defined
2x6511
2x6513
Yup. The 6511's are the stereo drivers, the 6510's are the SDA drivers and the 6513's are the sub bass drivers that have the donut weight mass mounted to the speaker cones.
I believe the donut is just added to an existing MW 65?? driver to make it a 6513. I have a feeling they used a 6503 to make a 6513 driver but I'm not sure.
His 6513 has a 10 stamped on it like it was from a M10 speaker. A 6513 might just be a 6503 with the donut added to it. Polk might have needed some that 6503's for production and may have used a 6513's that didn't have the donut attached yet to keep the production line going.
If you look at the full size image you'll see all the stampings on his 6513 driver match the ones on the 6503 driver next to it. Even the signature matches.
In his first post you can see his 6513 driver lacks the donut weight mass. It's not a true 6513 driver. He may be just fine with the drivers he has, hard to say.
Nope, there were 6513 drivers with donuts and 6513 drivers without donuts. They were not converted 6503's.Political Correctness'.........defined
Thanks for the insight - this is all very confusing, but very interesting at the same time.
If I could ask, what is the difference between all the different drivers? The 6513 I pulled has an impedance of 7 ohms...
All of the MWxxxx drivers have different Q, Resistance and Fs ratings. I believe that info is posted somewhere in here.
And here it is. Note, the 6513 is not listed.
http://forum.polkaudio.com/discussion/118471/current-production-drivers-vintage-support/p1Political Correctness'.........defined
What was the donut supposed to do? It seems the added weight would keep the driver from moving.Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
Ok, thanks, that makes sense.
Is the 6503 available from Polk? If not, I found a couple on eBay going for $45...."Conservative Libertarians love the country, progressive leftists love the government." - Andrew Wilkow
