Let's Talk Carts and Styli
Ok, I received tons of good info under Turntables and I think I've decided on one...now, let's talk about cartridges and benefits of MM or MC. I'm not going to say what table I've decided on, but, let's assume it's a DD table very similar to the Technics 1200. I'm looking for a good cartridge that will fit my style of music (mostly 70's rock, some JT, Natalie Merchant, Steely Dan, etc) being played through a tube electronics. I like a rich, detailed, slightly forward sound without any edge in the upper mids. I'm not sure what budget will be...wanting to possibly get two carts to play with to compare and contrast. Tell what you like, why you like it and at what price point you think it should be picked up. Also, any other info you have on carts and styli let it rip. What is the process to installing a stylus? How do you know if it's installed properly? Thanks in advance.
«1345
    mhardy6647 Posts: 33,134
    edited August 2017
    I voted already in another thread :)
    http://forum.polkaudio.com/discussion/comment/2340162#Comment_2340162
    I will add (since I never know when to shut up!) that, if you have an appropriately massive arm & the budget, the Ortofon SPU family are superb to my ear.
    https://www.ortofon.com/hifi/cartridges-ranges/spu
    spu-modeller-spu-collector-box.jpg?height=500&quality=80
  • tratliff
    tratliff Posts: 1,670
    edited August 2017
    I have been really happy with my SoundSmith Zephyr MIMC. Prior to that I had a Clearaudio Maestro. The Maestro was nice but not even close to the detail and warmth I get from the SoundSmith. The nice thing about the SoundSmith is they will recondition it for something like $250.
    Prices are all over the place depending if new or used. You might check with elusive disc. I know they have factory refurbs sometimes, from many manufactures. I think new price was around $1750.
    2 Channel Rosso Fiorentino Volterra II, 2 REL Carbon Limited, Norma Revo IPA-140B, Lumin U2 Mini, VPI Prime w/SoundSmith Zephyr MIMC, Modwright PH 150, Denon DP-59l w/Denon DL-301MKII, WAY Silver 3 Ana+ Speaker Cables, WAY Silver 4+ Interconnect Cables, AudioQuest Niagara 7000 w/Dragon and Hurricane Power Cables
    Yes.
    Soundsmith = good :)
  • soundfreak1
    soundfreak1 Posts: 3,389
    What's the budget on the cart?
    Main Rig:
    Nakamichi EC100 Active xover
    MIT exp 1 ic's
    Perreaux SA33 class A preamp
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    MIT exps2 speaker cable
  • kharp1
    kharp1 Posts: 3,453
    I don't have one yet. I don't want to go crazy right off the bat. Would like to get a good quality, good sounding moderate level cart to start with. I saw the Denon 103 waa about 250-300 and that seems fair for all the good things I've heard about it. Read good things about Dynavector and the 10x at 650 would be my max at this time.
  • soundfreak1
    Before cart you have to make some decisions. Don't know for sure what phono preamp you're using in your preamp but would start off with an MC high output entry-level cartridge like a Denon dl-110 for instance dynavector also makes a couple models in this class I believe in their 10 x 2 and their 10 x 4 they may have a high output as well. Probably (the denon) one of the best bangs for the bucks in MC entry levels. Since its high output you don't need a head unit to start with. You can pick one up for $200 or less. Don't know of any cartridge equal price or less than touch it. That's just my experience. Once you get your feet wet and decide you like it you can always upgrade cartridges upgrade head units and you're Off to the Races any direction you want to go. This will get you started at a minimal cost and a maximum reward.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • dromunds
    dromunds Posts: 9,990
    Look around for a Denon DL110 for $75, be patient. Carts can be a big rabbit hole if you're spending money while getting your learn on. I may have a Shure M97XE that I'd sell very reasonably but not sure if I still have it. Spending $650 for a cart is not my idea of a party unless you're really sure you want (and need) it.
  • [Deleted User]
    Denon DL110 and a Schiit Mani. Done.
  • soundfreak1
    TForan wrote: »
    I'd call that a good start! (I'm a realist) LOL
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • jdjohn
    jdjohn Posts: 3,020
    I don't see it mentioned here yet, but one consideration is replaceable styli. You will find that MM carts have removeable styli that can be replaced, and MC carts do not - you have to send it off (expensive) for re-tipping, or replace the cartridge altogether. Swapping out the stylus on an MM cart is a piece of cake, so no concerns there. And many MM carts with swappable styli provide an upgrade path for more advanced styli as your budget allows. Differences can be cantilever thickness and material used (straight tube vs tapered; aluminum vs boron), diamond shape (elliptical vs exotics like Shibata, micro-line/ridge, line contact), and nude vs bonded diamond mounting. Audio Technica is known for having stylus upgrade paths for certain 'families' of cartridges which have similar body styles.
    Cartridge/stylus compliance is another consideration. This is the suspension of the cantilever/needle. Some are stiff (low compliance), and some are softer/springier (high compliance). The best one to use is dependent on the weight of the tonearm. Heavier tonearms work best with stiff/low compliance, and lighter tonearms with softer/high compliance, so matching makes a difference.
    I would say decide on a turntable first, evaluate the tonearm, then look for cartridge(s) with compliance that match well. THEN depending on the cartridge (MM or MC), decide on a phono-stage. Better phono-stages have adjustable settings that allow for either MM or MC.
    Cartridge brands tend to have a 'house sound', so depending on your taste, you can be steered in certain directions. IME, Audio Technica tends to be brighter and more detailed in the highs; Shure tends to be warmer with somewhat rolled-off highs; Ortofons can be clinical and analytical....at least newer models I have heard...those older ones mhardy mentioned are a different matter B) . I've only heard one Denon - my DL301MkII - which is a low-output moving coil (LOMC), and although refined, IMO it is a little more laid back. I imagine the DL110 might be a little more authoritative, being a HOMC.
    You mentioned Dynavector, which are excellent. I have a Karat 23R which actually got damaged, and then repaired with a cactus thorn cantilever. My favorite MM is the Grace F9, and mine has a SoundSmith replacement stylus; the Grace OEM styli are supposedly great, but rare as hen's teeth, and there are some other stylus that will fit it as well. But that SS replacement I have sounds sooo good.
    In general, and again in IME, LOMC have a delicate signal which, when properly loaded with impedance and gain, sounds magical. I find them more forward in the upper-mids, and more subdued in lows and highs, but still tight. Whereas MM (and even HOMC), are more robust all around, and less fussy with loading. So what sounds 'best' can depend on the rest of the system and personal preference.
    A word on the Schiit Mani: they are nice units for the money, but if you have any suspicion of RFI in your area, you should avoid it. I have one gathering dust because there is an FM transmitter a few miles from my house, and it comes through on my Mani just enough to be annoying :s This is a known issue with these units, and sadly Schiit provides no solution. But I know there are LOTS of folks that love them and have no issues, so physical location might dictate whether it's a good option for you. Mine needs a good home!
  • Msabot1
    Msabot1 Posts: 2,098
    Let's see...take your hand,grab some fine sand and let it trickle through your fingers..that is just the amount of choices that you have dude...but when all else fails...trust your ears!..LOL!..
    The Mani is inexpensive and capable (i.e., adjustable); both of which are very admirable -- but opinions on its sonic performance are mixed. I have no ears-on experience, but based on feedback from folks whose ears I trust... it might not be the best choice for semi-serious users.
  • mikeyb128
    mikeyb128 Posts: 2,885
    Don't forget to use the resonance frequency calculator!
    rf = 159 / sqrt ((eff. mass + cart weight + fastener weight) * (compliance))
    - rf: resonant frequency in hz
    - eff. mass: rated by tonearm manufacturer
    - cart weight: rated by cartridge manufacturer, but if accurate scales exist, an actual weight value could be used
    - fastener weight: screws, nuts, spacers, washers, shims. They have weight and add to the mass over the stylus
    - compliance: rated by cartridge manufacturer
    :wink:
    2 channel:
    Theater:
  • kharp1
    kharp1 Posts: 3,453
    mikeyb128 wrote: »
    :wink:
    Ok, I quit right here. NO MORE MATH! Got suckered in to taking a crane certification course through work and it was like being back in college. NO MORE MATH!
    Think I'll get a cassette deck
  • soundfreak1
    Oh yeah cassette deck that'll solve your problems nothing like trying to find cassette tape somebody who has the equipment and can set the Azimuth on the heads every year not to mention pinch rollers and rubber grommets and all the stuff in the belts you can run you just can't hide
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
    edited August 2017
    It's actually just arithmetic; take a bunch of numbers and plug into an equation; an answer pops out the other end. (I would recommend "dimensional analysis", though -- it makes it way easier to tell if one plugged the right numbers into the right places!)
    Mathematics is for (ahem) real men. Or women. Or transgender people. But they gotta think math.
    I don't think math.
    My son does, though :)
    https://doctorhardy.wordpress.com/
    msg Posts: 9,549
    I know Mikey, wtf, man?!?
  • dromunds
    You won't get any good cassette tapes unless you record from vinyl. Lol
    speaking of "carts and styli"...
  • soundfreak1
    dromunds wrote: »
    Yep that's what we did way back when.
    Main Rig:
    MIT exp 1 ic's
    AQ kingcobra ic's
    OPPO 83 CDP
    ADS L1590/2 Biamped
  • Inscrutabl0915
    mikeyb128 wrote: »
    Yes, if you already have your tonearm picked out, you need to go here (no math, just plug in the numbers):
    https://www.vinylengine.com/cartridge_resonance_evaluator.php
    to get a matching cartridge, and some will be taken out of play (pun). you would like to get resonance in the 8-12 hz range.
    If you do not have a specific table/arm yet, then you can pick cartridge first and then find an arm that matches well (though that's usually a bit backwards ... unless you have a particular one you are in love with.
    msg Posts: 9,549
    mikeyb128 wrote: »
    Mikey, what's all this about?
    I'm Polking around a bit in reading, but Cliff's Notes version?
  • kharp1
    kharp1 Posts: 3,453
    Ok, I think I've decided on the new Pioneer PL-1000. My research says not much wrong with it except it's a direct drive and that just automatically puts it on the wrong side of the fight for snobs, um, I mean purists. :)
    I'll use that arm for the time being while I'm getting my feet wet and continue to do research with some actual hands on experience.
    SCompRacer Posts: 8,365
    edited August 2017
    To each, their own... I'm in the LOMC, MicroLinear with passive gain SUT and MM phono stage camp. Been in other camps, love this one.
    We need cartridge action pics...
    Sumiko Blackbird...
    Dynavector Karat 17D3...
    Denon aluminum bodied 103R...
    My current fav, AT33PTG/II.....
  • mikeyb128
    msg wrote: »
    mikeyb128 wrote: »
    Hehe! First time I read about it I was like huh? Turns out it's super easy. I've even got the formula memorized. Never know when you need it on the fly!
    2 channel:
    Theater:
    msg Posts: 9,549
    edited August 2017
    SCompRacer wrote: »
    Sumiko Blackbird...
    [gush]
    Veritable beautes. That Blackbird and the AT... wow.
    I'm curious to visit this camp. Are all of those MicroLinear or just the AT?
    I thought this was a pretty good primer on stylus types, pros/cons, etc.
    https://www.sound-smith.com/articles/stylus-shape-information
    edited August 2017
    The Blackbird had a Low mass elliptical, the 17D3 was a Micro-Ridge, the 103R is a micron round and the AT is MicroLinear.
    Yes, Soundsmith has a good write up!
    I had installed an AT33 for someone and liked the cartridge so I tried the PTG/II.
    nooshinjohn Posts: 25,156
    Another vote for the Blackbird, but 95 percent of its performance can be had in the Sumiko Bluepoint EvoIII for half the price.
  • kharp1
    kharp1 Posts: 3,453
    SCompRacer wrote: »
    Sumiko Blackbird...
    Ahhh, prono!
  • kharp1
    kharp1 Posts: 3,453
    This is where things might slow down for me, I had some knowledge of tables, have none on this stuff. The learning curve will be a bit steeper.
