Polk surrounds
VinnyP61
VinnyP61 Posts: 28
edited April 2002 in Technical/Setup
Hi I was wondering what surround speakers should I use with my 800I cs400 center iam running with a Denon 3801 thanks
Post edited by VinnyP61 on
  • OrangeToupee
    OrangeToupee Posts: 488
    edited April 2002
    Are you looking to do a 5.1, 6.1, or a 7.1 system?
  • ted538
    ted538 Posts: 63
    edited April 2002
    i have the 800i and the 400i...i have the rt35i`s for the surrounds..they sound great...i would suggest those.
  • reidbubba
    reidbubba Posts: 5
    edited April 2002
    I have the 800i with the 245i centre and using f/x300i surrounds.
    Sounds awesome.
    Bubba
  • VinnyP61
    VinnyP61 Posts: 28
    edited April 2002
    Thanks I am using 5.1 set up
  • earnest poole
    earnest poole Posts: 22
    edited April 2002
    I have the 800i, cs400i,and I am using the 35i's for my sourrounds in a 5.1 setup and I am very pleased with them.But I would like to do a 6.1 but I cant decide what to go with for the rear sourrounds. I was thinking about moving the 35s to the back and getting some fx500sfor the sides.will the two 35s wired in parallel be large of a load for my receiver ''AVR-2802".
  • OrangeToupee
    edited April 2002
    For a 5.1 system, I think conventional wisdom says to get some F/X500i's, or even F/X300i's. Here is a good page to read for determining where to place your chosen surrounds.
  • ted538
    ted538 Posts: 63
    edited April 2002
    wow earnest...we have almost the identical system..I have the 1802,not the 2802 though...I have the 450 sub which is good ,but I think I should have gone with the 650...maybe I`m just being too picky..
  • mantis
    mantis Posts: 17,061
    edited April 2002
    It will depend on your room layout, both the fx/500's and the rt35's make good choice's, they match you system well,but to figure out what speaker would work the best, i need more info on you room, where you sit.
    Dan
  • scottvamp
    scottvamp Posts: 3,277
    edited April 2002
    I'm using the fx500i's dipole and cs245i as rear center in a 6.1 setup. Absolutly seemless! Check out my system showcase for placement.:D
  • goingganzo
    goingganzo Posts: 2,793
    edited April 2002
    i defferntley recomend the 500 i love mine thay are too sweet and they look darn cool too
  • juice21
    juice21 Posts: 1,866
    edited April 2002
    vinny, i had the rt35i's for awhile, upgraded to the fx1000's. the dipole was the way to go for rear HT surround IMO. much more diffuse sound. although i am running the 1000's, i think the 500's would be ample in your set-up. good luck finding them now though, that was my problem...
