Polk surrounds
VinnyP61
Hi I was wondering what surround speakers should I use with my 800I cs400 center iam running with a Denon 3801 thanks
Post edited by VinnyP61 on
Are you looking to do a 5.1, 6.1, or a 7.1 system?
i have the 800i and the 400i...i have the rt35i`s for the surrounds..they sound great...i would suggest those.
I have the 800i with the 245i centre and using f/x300i surrounds.
Sounds awesome.
Bubba -
Thanks I am using 5.1 set up
I have the 800i, cs400i,and I am using the 35i's for my sourrounds in a 5.1 setup and I am very pleased with them.But I would like to do a 6.1 but I cant decide what to go with for the rear sourrounds. I was thinking about moving the 35s to the back and getting some fx500sfor the sides.will the two 35s wired in parallel be large of a load for my receiver ''AVR-2802".
For a 5.1 system, I think conventional wisdom says to get some F/X500i's, or even F/X300i's. Here is a good page to read for determining where to place your chosen surrounds.
wow earnest...we have almost the identical system..I have the 1802,not the 2802 though...I have the 450 sub which is good ,but I think I should have gone with the 650...maybe I`m just being too picky..
It will depend on your room layout, both the fx/500's and the rt35's make good choice's, they match you system well,but to figure out what speaker would work the best, i need more info on you room, where you sit.Dan
I'm using the fx500i's dipole and cs245i as rear center in a 6.1 setup. Absolutly seemless! Check out my system showcase for placement.:D
i defferntley recomend the 500 i love mine thay are too sweet and they look darn cool too
vinny, i had the rt35i's for awhile, upgraded to the fx1000's. the dipole was the way to go for rear HT surround IMO. much more diffuse sound. although i am running the 1000's, i think the 500's would be ample in your set-up. good luck finding them now though, that was my problem...
