What is the largest center channel speaker?
![DonnerUndBlitzen](https://w7.vanillicon.com/772d0a6bb60f78460abe8d7fcc375334_100.png)
DonnerUndBlitzen
I just bought (thru Amazon) a Polk Audio CSI A6. It is 24 inches wide by 14 inches deep and about 8 inches high. A Very large center channel! But, is it the largest mass production center channel speaker ever produced? No!
The Klipsch RC-64 has four 6.5 inch mid-range/woofers plus a horn tweeter. It is a little over 35 inches wide and 13.25 inches deep. Is the RC-64 the largest center channel? I have not seen a larger center channel.
The RC-64 also costs an arm and two legs while the CSI A6 only costs an arm.
Not sure, check out the CS1000P....
https://www.cnet.com/products/polk-audio-cs1000p-center-channel-speaker/specs/Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Definitive C/L/R 3000 is up there - dual 6.5" with a 10" subwoofer (powered)- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Utopia center channel
"Conservative Libertarians love the country, progressive leftists love the government." - Andrew Wilkow
― Aleksandr Solzhenitsyn -
I might have to buy this. I have half-way been looking for a new center.
Three 20 amp circuits. -
Klipsch dual 8" w/tractix horn.
Model # escapes me?
It was HUGE!
It's the RC 7 - the center of the Reference "7" line up. I run the full Reference 7 set in my HT. Very beefy center indeed..."Conservative Libertarians love the country, progressive leftists love the government." - Andrew Wilkow
Seen it heard it SERIOUS center blow your well you know WHAT back. -
I have been more than happy with the Polk Cs1000p. I got it adjusted to where I like it-just recently & it does the job just fine. The subs are adjusted to pleasing bass right at you. I'm not too bass needy or I'd add a decent sub. But with SDA's why bother
You can put a 55 inch tv on it if needed & do yourself a favor & don't move it often cause it is frign heavy
OOOH, That's my baby right there. One day gents....one day.HT SYSTEM-
lsi 9's -
31.5W x 13D x 12H Salk Soundscape 7C. 86 lbs of sweet Salk sound and it's in my entertainment center and sounds fantastic._____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
I have a Klipsch KV4 in the garage, two 8" woofers with a horn in the middle just like that one above. Came with a pair of Forte IIs. One of the rubber surrounds is torn though, gotta figure that out. Don't use center channels not sure what to do with it!
Biggest? This guy built a pretty large one ...
http://www.audioheritage.org/vbulletin/showthread.php?39208-My-JBL-4355-Homecinema-Soundbar-buildPost edited by lawdogg onmy 3.1TLs
I will fix your shifted magnets for free. -
If you are talking about the largest center speaker Polk has ever made, it is probably the CS1000p as far as physical size goes.
CS1000p Specs:
Size: 34"W x 14"D x 8.6"H
Weight: 60lbs.
Power Handling: 20 Watts to 250 Watts
But if you are talking about the baddest center speaker Polk ever made it has to be the SRT center speaker.
SRT Center Speaker Specs:
Size: 26"W x 17.5D x 6"H
Weight: 40lbs.
Power Handling: 100 Watts to More than 1,000 Watts
I think I have the SRT series speaker. Bought new in 1996 ish. It has opened where there were seams. Is this under warranty? Thank you for the support.
This channel rocked and wud hurt ears < 15' away alone. POLK POWERED HOME.
No.Political Correctness'.........defined
