DIY Acoustic Panels With WAF...Pics!
About a buck a board...
CEDDBBCB-184A-46CC-B946-9EB30B72C3B6_zpsckzrqfdv.jpg?1455057397291&1455057398023&1455057404261&1455057418454&1455057432817
Easy cuts...48" and 25.5"
59D2CBBB-F30D-4099-A495-50D09A472A81_zpsgrtaedro.jpg?1455057397291&1455057398023&1455057404261&1455057418454&1455057432814
Wood glue, small nails and inside corner brackets to keep the frame sturdy...
F1E8A169-2848-47EB-9B72-347853B3432E_zpsahbtj7ev.jpg?1455057397291&1455057398023&1455057404261&1455057418455&1455057432817
  • hochpt21
    hochpt21 Posts: 5,423
    Some printed burlap at 30% off is about $11 per board...
    B9A01359-87A2-49A0-856F-9290512E8204_zpsoqwlfgxe.jpg?1455057397291&1455057398023&1455057404261&1455057418455&1455057432817
    Pulling tight and stapling is probably the most annoying part...
    91773DAE-47A7-407A-9B25-BD0A0BBE2242_zps6qfw1dxt.jpg?1455057397291&1455057398023&1455057404261&1455057418455&1455057432817
    Insert the fiber board. I got mine at ATS acoustic. It's similar to Owens Corning 705, but without the formaldehyde...
    D800A4BC-CF5B-44C4-A88B-A0D625F98A9E_zpsmukp66vk.jpg?1455057397291&1455057398023&1455057404261&1455057418455&1455057432817
  • hochpt21
    edited February 2016
    And here you go!
    Less than an hour per board. I am going to mount them and I'll show those pictures when that actually happens...
    F27DC718-E93A-4B57-B025-AB002BE61A34_zpsgdzbvanf.jpg?1455057397291&1455057398023&1455057404261&1455057418455&1455057432817
  • bikerboy
    bikerboy Posts: 1,207
    Looks very nice. I always said I would make the type you have made but never did get around to it. I finally did this
    http://www.diyaudio.com/forums/everything-else/269366-making-easy-diy-depot-sound-diffuser-panels-step-step.html
    I can work with the wood and 2-8 ft difusers cost about $130 not counting the nails to hold it all together. Made a huge improvement! Pics later.
    Post edited by bikerboy on
    Main system: Lyngdorf TDAI 2170 w/ Pioneer 42" plazma-> Polk LSiM 703 w/Tivo, Marantz tuner, BRPTT: Nothingham Spacedeck-> Pioneer PL L1000 linear arm-> Soundsmith DL 103R-> SUT->Bottlehead ErosDigital: I3 PC w/ Jriver playing flac -> Sonore Ultrarendu -> Twisted Pair Audio ESS 9028 w/ Mercury IVY Vinyl rips: ESI Juli@24/192-> i3 PC server
  • pumpkinman
    pumpkinman Posts: 9,533
    Very nice and I like the printed burlap. I've never seen it before.
    Looking forward to the final pictures.
    Because I am The Pumpkinking
  • westmassguy
    westmassguy Posts: 6,850
    Looks great.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • MrBuhl
    MrBuhl Posts: 2,419
    Reallly nice - great job - I might even get that approved here!
    Polk SDA1c modded
    Polk SDA2BTL (fully modded)
    SACD Marantz DV8300
    Sony S9000ES CD/DVD/SACD
    Yamaha YP-D6
    Soundcraftsmen PCR800
    Audible Illusions L1 Preamp
    Pho-700 Phono Pre
  • chumlie
    chumlie Posts: 8,658
    Nice job Paul. Hates the WAF. Glad I'm single. :)
  • Thorton
    Thorton Posts: 1,324
    Nice job. They look good.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
  • mdaudioguy
    mdaudioguy Posts: 5,165
    Yes, great job! Simple, but hopefully effective. Can't wait to hear how they work out for you.
  • Jaybeez
    Jaybeez Posts: 748
    Those look terrific. I was going to build my own when I set up my studio for recording, but never got around to it, so bought them.
    If the fiber board is flush with the back, you may want to put something in the corners to separate it a bit from the wall.
    An old, but effective article. Ethan Winer knows what he's talking about:
    http://recordinghacks.com/2011/12/13/mounting-acoustic-panels-variable-air-gap/
    2 Channel "Polk" Room:
    Marantz PM8004 Integrated
    Marantz SA8004 SACD Player
    WiiM Mini
    Polk 7B with RDO198s
  • BlueMDPicker
    msg Posts: 9,528
    Cool, Paul!
    Where did you source the printed burlap?
    And, you mean used potato sacks from 5 Guys Burgers wouldn't've been acceptable?
    What's ATS?
    Do you know how you'll mount them yet? Just hanging wire? Looks like a great place for hiding secret documents, too.
    I might be watching too much Burn Notice.
  • Mike Reeter
    Mike Reeter Posts: 4,314
    Good work, treating the room is one of the first steps to good audio! I made a set almost identical to yours a few years ago, wouldn't be without them now.
  • hochpt21
    msg wrote: »
    Cool, Paul!
    What's ATS?
    JoAnn Fabrics. Printed burlap is 2 or 3 times more expensive so use a coupon or wait for a sale. And if you want just standard burlap, you can make these super cheap.
    Google ATS acoustics. They sell fully completed products and also DIY material. I also think a lot of people like GIK acoustics.
    My plan to hang them... I bought 6" landscape screws and I'm going to have about 2.5" sticking out from the wall, then I'll put hooks on the top of the panel and just set them on the screws at the ends away from the wall.
    It looks cool in my mind, but we'll see how it turns out. :)
    msg Posts: 9,528
    That was a joke about 5 Guys Sacks, haha
    Regular burlap would probably be pretty gnarly unless you were putting these up in a rustic cabin? And they'd smell like potatoes.
    ah man, that actually does sound kind of cool having them out off the wall a bit.
    Great tips.
  • ledhed
    ledhed Posts: 1,088
    Very nice idea and implementation!
    I would think it'd be fairly easy to also use a standard fabric and screenprint/stencil a specific design onto it.
    God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8
  • sarnella
    Very nice. As an aside - I have been able to get a few burlap bags from a local
    coffee shop - some look quite nice.
  • mikeyb128
    mikeyb128 Posts: 2,885
    DSkip wrote: »
    Great job Paul. As already mentioned, room treatments are a must for anyone serious about the performance of their system. It is one of those investments that is hard to rationalize due to cost. Then you hear the difference....
    I believe if you hunt and dig hard enough it can be done for a reasonable cost. Buying them straight from gik or prime acoustic is super expensive. Six corner traps costing 299 a pair!
    2 channel:
    Theater:
  • Jaybeez
    Jaybeez Posts: 748
    Shipping is what kills you with a purchase. My bass traps are from GIK, and I love them, but they were expensive to ship. Fortunately I found someone in LA who makes the 2" panels for not much more than it would cost me. That said, these printed ones are WAY cool!
    WiiM Mini
  • indyhawg
    indyhawg Posts: 1,639
    Very nice work. I will echo what others have said that room treatments do make a big difference.
  • machone
    machone Posts: 1,484
    I like it
    1KVA Dreadnought
    Marantz SA 8005
    Sony PS4
