Anyone play with their VTA?
Just bought a VPI Traveler and love it so far but I've never owned a turntable that had an adjustable tracking angle. Is this something to adjust when playing regular and 180g vinyl or will it make you go blind? :)
McCormack DNA-1 Amp, Parasound Halo P5 Pre Amp, Denon DVD 2900 CD player, Adcom GDA 700 DAC, VPI Traveler TT with Denon 103R cartridge, Lounge Audio MKiii phono pre and Copla SUT, Polk SDA SRS 3.1 TL speakers, Tributaries series 8 IC's and speaker cable.
  • honestaquarian
    Very few turntables have a VTA adjustment. In another thread about the venerable Technics SL-1200 DJ table I mentioned the fact that it has a VTA adjustment. The VTA should be set according to the cartridge you are using.
  • marvda1
    marvda1 Posts: 4,882
    look out, you'll go blind >:)
    Speaker Cables: Organic Audio Organic Reference 2
    Interconnects: Argento Organic Reference 2, Argento Organic 2
    Puritan PSM156
  • StevieB
    StevieB Posts: 256
    I would recommend messing around a bit if you're able, there's definitely a sweet spot. With the denon 103r a little down past parallel in the rear. Just listened to Electric Ladyland and was blown away! I honestly never realized vinyl could sound that good.
  • agfrost
    agfrost Posts: 2,421
    marvda1 wrote: »
    Ha! I opened this thread just to make that joke. You beat me to the punch.
    Jay
  • agfrost
    I found this article interesting.
    Personally, I don't go overboard--Just try to get the arm level during playback.
    Jay
    SCompRacer Posts: 8,363
    edited February 2016
    If you provide a man with a knob, he will turn it. ;) Jay pointed to a good article on it.
    My arm has a VTA knob with digital readout. Was thinking it would be kewl to make it remote control with a motor....VTA on the fly...lol
  • agfrost
    ahh, a pic from when your TT was going through its "Goth phase".
    (or Johnny Cash phase, perhaps?)
    Jay
  • ken brydson
    ken brydson Posts: 8,660
    marvda1 wrote: »
    Or get hairy palms (gets out razor)
    agfrost wrote: »
    I kinda dug hot goth chicks in my goth stage...
    OR.......cranked up past eleven,,,,,,
    Back in black!
    https://youtu.be/H8PC1_3fjvs
    tonyb Posts: 32,910
    I play with my VTA all the time.
    Wait....what are we talking about again...TT's ? My bad... :)
  • StevieB
    StevieB Posts: 256
    So after reading the article, maybe the guy who set it up didn't have the arm quite level? The sound stage was there, but was lacking much if any bass. Whatever the reason, sounds damn good now. Never had a good turntable with SDA's. :)
    agfrost wrote: »
  • agfrost
    StevieB wrote: »
    Excellent! There's some great sound to be gotten from a TT. A good pressing of a well recorded album is something to behold!
    Jay
    msg Posts: 9,533
    tonyb wrote: »
    Wait, we're allowed to talk about TT's on this board? when did *that* happen?!?
    Can we post pictures of TT's now too?!?
  • lightman1
    lightman1 Posts: 10,776
    I like a nice sized pair of TT's myself.
    You know... Like DJs have.
    msg Posts: 9,533
    yes, I agree - when I was looking for my TT, I kept seeing these really nice photos of sets of DJ TT's set up real nice, with the dust covers off. the black ones are my favorites, but I like the lighter color ones, too. the VTA dials on these units are just begging to be tweaked.
  • lightman1
    msg wrote: »
  • Dawgfish
    Dawgfish Posts: 2,554
    I definitely adjust my VTA. Luckily the four tables I own all have adjustable VTA. I read an article from Michael Fremer stating that basically most records are cut with the cutter head stylus at 92° and that one should also set the styli on your turntable at 92° to replicate the cutter head. After reading this I gave it a try. On 22 of the 23 cartridges I own, setting the VTA at 92° made a definite improvement in sound. The tonal balance from top to bottom was correct, and the soundstage width and depth increased from a decent to huge amount depending on the particular cartridge.
    One of the things you hear a lot in the audio community is Grado cartridges in general have rolled off highs. You need to hear a Grado set with a VTA of 92°! The highs really come to life, detail is improved, and soundstage width and depth become huge. Granted there still may not be as much high end extension as your typical AT or Sumiko, but high level detail is definitely there and much better than many realize without them being set to the proper VTA.
    I am not so fanatical with VTA that I change it between playing 140 gram to 200 gram records unless it seems grossly out of balance. Generally whenever swapping out cartridges, I set the VTA to 92° with a 180 gram record on the platter and leave it.
  • gce
    gce Posts: 2,158
    Dawgfish wrote: »
    So you're saying you have the back of the arm up higher then the front to get 92°?
    Anaheim Hills CA,
  • Dawgfish
    gce wrote: »
    Dawgfish wrote: »
    Yes that's exactly right. It sounds counter-intuitive to what you always heard about setup before. Before reading the article, I always ran the tonearm either level with the record or even with the tonearm slightly lower than the headshell with most carts. The thing is when you first try it, the rear of the tonearm will be higher than you were expecting it to be. It's ok though. Try it! You'll like what you hear! BTW, Soundsmith recommends setting carts up with a 92° VTA also.
    BTW, I use cartridge gauge blocks from Expressimo Audio to set the VTA. They are cheap ($19.99 iirc) and easy to use.
  • gce
    gce Posts: 2,158
    Thanks for the info. I've always heard down in the back, never up (92°). That's why I asked but I'm going to try it. You can always trust Michael. ;)
    Anaheim Hills CA,
  • voltz
    voltz Posts: 5,384
    when you mention 92 degrees I get lost thinking is that open? or closed? as it depends how you look at it. but now i know what you mean.
  • gce
    gce Posts: 2,158
    voltz wrote: »
    Yeah, I was a little confused too. That's why I put up the pic. Now I'zz get it. ;)
    Anaheim Hills CA,
  • StevieB
    StevieB Posts: 256
    I
    gce wrote: »
    voltz wrote: »
    It appears on the Expressimoaudio site they are measuring the 92 degrees from the other side of the stylus.
  • voltz
    voltz Posts: 5,384
    LOL Dang it Steve ...now you got me pulling my hair out and I ain't got much left :)
  • Dawgfish
    Trust me gentlemen, you want the back of the tonearm to be higher. http://www.analogplanet.com/content/how-use-usb-digital-microscope-set-92-degree-stylus-rake-angle-sra#vZepvdDA4cR7TY6l.97. This is a good place to start getting your read on. Not the using the USB microscope part, but click on the links regarding the 92° setting. Try it and let your own ears tell you!
    Oh yeah if you go to the Expressimo Audio website,http://www.expressimoaudio.com/vtablock.html, you want to use the +2 gauge block shown on the bottom pic. Raise the tonearm until the front of the cart is parallel to the edge of the +2 gauge block.
  • StevieB
    StevieB Posts: 256
    Hey, I'm not the only one that plays with it...I knew it! :)
  • Dawgfish
    StevieB wrote: »
    Lol! And if you say you don't, you're lying! :-)
  • gce
    gce Posts: 2,158
    Dawgfish wrote: »
    So if I understand this right, if I have a 9" arm raising or lowering it .157" (4mm) would = 1°. So if I was at 90° I would have to raise the back (pivot point) .314" to get 92°? That seems like a lot.
    Anaheim Hills CA,
  • miner
    miner Posts: 1,305
    That is right.
    Sin 2 deg = 0.0349
    0.0349 = A/9
    A = 9 X 0.0349 = 0.314
    On my VPI that would be 10 full turns of the VTA tower.
  • Dawgfish
    gce wrote: »
    Dawgfish wrote: »
    That is right. Again like I mentioned before, it seems like you raise it more than you should, but it works. I read somebody else's post in another forum that explains a cool experiment to try and here it goes: run your finger nail along a surface like a piece of lumber, tile, vinyl etc. First try it with your finger perpendicular to the surface to simulate a 90° VTA. Now try it with your finger raked back slightly to simulate a 92° VTA. Tell me what you feel and what the differences are. I know it's not a completely analogous comparison, but still try it and then think about what you just experienced. I'm not going to say any more about it. You can either dismiss it or try it. I tried it and was glad I did. I'm not the one who made this up.
