A bit of a modern twist on a classic
Braddles63
Braddles63 Posts: 184
edited January 2016 in Vintage Speakers
I bought a pair of Monitor 7A's a while back and the boxes were pretty knocked around. I stripped them back and planed on finishing them in the classic timber veneer. But the corners were really bad so i decided to take i different but risky move. I rounded off the edges of the boxes and found a granite look paint that i thought would look good. Im sure some will consider it sacrilege to do this but I'm happy with the lookand interestingly so is my wife.
I have rebuilt the cover using Jantzen Superior Z caps on the tweeter and cross caps on the MW. Also used their Mox 10 Watt "Superes" resistors. The tweeters where no good so after hanging out for some original Peerless on eBay etc i took the plunge and bought the new ones from Mid West. This was a bit costly to get them to Australia as the exchange rate is down to 70c but i ran out of patients.
Also done the usual dampening of the baskets and new seals. Still have to do T-Nuts and new grill cloth.
I have only about 20-30 hours on them so I'm trying not to judge them yet. They do sound a little veiled so far so we will see if they open up after some more time.ifj1cra2guqk.jpgdp5ja2w0ubu5.jpg
Post edited by Braddles63 on
  • jeremymarcinko
    Dang that actually looks fantastic. Bold move but it payed off...very cool
  • Braddles63
  • ken brydson
    ken brydson Posts: 8,660
    nbrowser wrote: »
    You know, I've seen some wild re-finishes on speakers that were downright garish and ugly, but this re-finish is actually very attractive! Different yet classy and done well. Good job mate!
    Purple shag carpet comes to mind. Cool look on these though..
  • Nightfall
    Nightfall Posts: 10,073
    I actually dig it too, nice work Braddles. Now if only you could remove the grey "trim" around the midwoofers and PRs, always thought that was ugly on the earlier models.
    afterburnt wrote: »
    Village Idiot of Club Polk
  • Braddles63
    Yes Nightfall i agree. I was going to taker them off all together to improve the look but I'm assuming they are there for an acoustic reason so i left them.
    Does anyone know if you can buy after market replacement trims?
  • westmassguy
    westmassguy Posts: 6,850
    Very nice job. The rings you're referring to are gaskets. They serve no purpose when the woofer or PR is front mounted (they're used when rear mounting the woofer to the front baffle). Removing them may be more difficult than you think. There will be a glue line leftover, and you risk damaging the rubber surrounds getting them off. New Gaskets are available, but finding an exact fit may pose a problem. Many are "universal" fit, come in four sections, and have sliding/adjustable joints. Not the nicest look.
    If the gaskets are in good shape, no blemishes, you could carefully mask off the rubber surrounds, and cones, then paint them......BLACK. If they have black paint down under.
    Use flat or matte finish. The gaskets are cardboard, and will soak up the paint, so any gloss finish will be uneven.
    Home Theater/2 Channel:
    dhsspeakerservice.com/
  • Faustin
    Faustin Posts: 1,149
    Nicely done. Most people would have parted them out. Glad to see that you were able to resurrect them.
  • [Deleted User]
    They look Heavy man!
    Would fit nicely in the studio.
    Well done.
    mhardy6647 Posts: 33,099
    (not that my opinion matters one whit, but...) I like 'em!
  • motorhead43026
    motorhead43026 Posts: 3,892
    edited January 2016
    Are those ETI AMG toppers on the speakers?
    2 channel: Anthem 225 Integrated amp; Parasound Ztuner; TechnicsTT SL1350; Vincent PHO-8 phono pre; Marantz CD6005 spinner; Polk SDA2BTL's; LAT International speaker cables, ZU Mission IC's and power cables all into a PS Audio Dectet Power center.
    Other; M10 series II, M7C's, Hafler XL600 amp, RB-980BX, Parasound HCA-1500 amp , P5 preamp, all in storage. All vintage Polk have had crossover rebuilds and tweeter upgrades.
    The best way to predict the future is to invent it.
    It is imperative that we recognize that an opinion is not a fact.
    Imagine making politics your entire personality.
    heh -- I just noticed that they're the seldom seen 7A variant with two fuses per loudspeaker system (tweeter & system fuses). Mine are identical (although still finished in their original, rather tired -- and orange! -- "rosewood" vinyl).
    I'm gonna (ahem) borrow a copy of the rear view photo above to document the XO configuration for posterity... since mine are boxed up in the basement and I am far too lazy to dig 'em out just for that :-P
    Thanks to the OP for posting those photos!
  • Braddles63
    edited January 2016
    Thanks all.
    Motorhead. Yes you are correct.
    hardy. Yes they are quite rare. Even more so here in Australia. The Xover is point to point rather than a PC board. I had to concentrate and take it slow so i didn't stuff it up,
    I assume that if i update the binding posts and loose the fuses it would improve things a bit more?
  • Gatecrasher
    Gatecrasher Posts: 1,550
    I think they look good but I might also be tempted to re-do the grills.
    Newly recovered black or grey grills might look pretty-nice.
  • Braddles63
    Yes mate thats in the plans for sure.
  • zappafan2
    I like them good job!!!!
    I am -- truth be told -- rather surprised to learn that there are ANY Polk Audio loudspeakers of that era (1970s) in Oz. Wonder how they even got there...?
  • [Deleted User]
    I'm going with twister.
  • Mikey081057
    Mikey081057 Posts: 7,127
    I like.... Rock Solid look...much better than the original contact paper fake wood "veneer"
    Garage | Polk Monitor 5B's
  • westmassguy
    They must have had some distribution, because I have several Polk Customers down under. Europe too.
  • Braddles63
    Polk have been available here in Oz as long as i can remember. Im 48.
    I bought my first pair of Monitor 10s in the late eighties.
    Im on the West coast of Australia in Perth. The most isolated capital city in the world. So to find them here is pretty rare. Same as when i found a pair of SDA CRS+.
    edited January 2016
    :- ) Now... that... that right there is some funny stuff, that is. Right there. Funny. Stuff.
    Now that you mention it, though... I do believe I saw Miss Gulch fly by on her bicycle.
    She may well have had a coupla Monitor 7As in her basket with that little dog...
    Braddles63 wrote: »
    So... let me do some math :-P You'd have been about 9 or 10 when the 7As were new (I bought mine, as scratch 'n' dent demonstrators, in 1978). :- ) In all seriousness, I had no idea Polk was distributed that far and wide that long ago! The early Polk products aren't really all that common outside of the US "midatlantic" area, to the best of my knowledge.
  • Braddles63
    edited January 2016
    You would have one more customer down under too for my CRS+ If it wasn't for a crappy exchange rate.
  • westmassguy
    Braddles63 wrote: »
    Thanks, Canada is right behind you in that respect.
  • Polkaguy58
    I'm thinking maybe some leopard fur covers.
    That way, they'd match my sofa.
    Granite finishes ROCK !
  • Moose68Bash
    Moose68Bash Posts: 3,842
    Nice and very creative job @Braddles63!
    Well done!
  • Braddles63
    Thanks for the feedback everyone.
    I have been running them for about 2 weeks solid 12-14 hours per day and I'm a bit disappointed at this stage. Top end is recessed and the bass is over powering and bloated. I know some have noted some improvement after run in but it will have to improve a fair bit for me to be happy.
  • westmassguy
    Those are not qualities normally associated with the 7s.
  • Braddles63
    Hopefully some more run time will help.
  • motorhead43026
    ^^I have my doubts^^
  • westmassguy
    Check for air leakage. Do the push test. Press in and hold the Passive Radiator, the woofer should pop out and stay out for 3-5 seconds, then slowly retract. If it doesn't, you've got leaks, which will affect the bass. Double check all drivers are in phase/wired properly.
