Bottlehead Crack
  • mrbiron
    mrbiron Posts: 5,711
    I'm going to need a blow torch to correct the base issue. Sad I overlooked that minor issue this entire time.
    I gave it a quick hour of run time for now. I'll give it a workout tomorrow during "daddy's beer time".
    I plug everything into the Peachtree. Its the core man...THE CORE!!!
    SCompRacer Posts: 8,357
    edited July 2015
    mrbiron wrote: »
    Guess what I'm doing.......
    Oh crap the base is backwards!!... Guess I'll have to start over.
    LOL Bottlehead humor.....
    Kewl beans! Sometimes inexpensive and even mid range price volume pots don't balance volume for both channels equally well at lower levels anyway. Like a balance control, one channel will become slightly louder to shift center image. Cure for that is go resistor ladder network, but that can some mild to wild pricing.
  • mrbiron
    It took me a little over 7hours to de-solder everything to get the base issue corrected. My wife asked why I couldn't just spin the base?...*snicker* women are so silly...... :D
    I wish I could/would have painted the socket white as well. Its really bothering me.
  • ALL212
    ALL212 Posts: 1,558
    Good move and hours well spent. You do realize the Crack only sounds good if it is soldered correctly inline with the logo. Sounds like AM radio if it's not done right.
    Aaron
    Enabler Extraordinaire
  • voltz
    voltz Posts: 5,384
    Looking good! Nice job!
    Now remember all those caps need some burn in time, so time to get your ears on for at least a good 100 hours ;)
  • vcwatkins
    vcwatkins Posts: 1,993
    Beautiful job. Congrats!
    b]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
  • mrbiron
    That damn socket!!!! Arrrgg!!!!
    Now I have to find time to use it. The competition will start in a couple months to see if I actually keep it :p
    BH Crack vs PS Audio Sprout vs Peachtree Decco
    edited July 2015
    mrbiron wrote: »
    Looks great!
    No guts no glory...you can remove the socket cover easy enough and detail it. That's why I left mine au naturel, just for a little shiny stuff among the black panel.
    I really dared the Bottlehead badge sound quality gods by placing mine flat on the top left corner of panel. I think it's a first, but I haven't seen pics of all BH builds. ;)
  • ALL212
    ALL212 Posts: 1,558
    Resurrection...
    The drawing for the BAC. 10" x 12" with the original plate at the top.
    Aaron
  • voltz
    voltz Posts: 5,384
    wait... is the volume control under the 12au7 tube? Think I like the new one then.
  • ALL212
    ALL212 Posts: 1,558
    input on left, volume in middle, jack on right. Hope to figure out how to take out the 12AU7 and use a 6SN7 instead. Might move the on/off down the chassis about 1/2 way also.
    Aaron
  • mrbiron
    Where is the fuel tank going to go?
    Hurry up.... :D
    Sweet jebus, big enough? ;)
    mrbiron wrote: »
    Hurry up.... :D
    He's gonna use a...
  • ALL212
    ALL212 Posts: 1,558
    Way too small... Going nuclear (got some stuff from N. Korea!!)
    Aaron
    edited August 2015
    Always gotta go to extremes....lol
    I'm gonna buy something for a change. Parks Audio SUT w/Blue CineMag trannies. Reasonably priced compared to some ($339 shipped). Wired 1:9 & 1:18 (instead of 1:18 & 1:36). Too much gain with the Eros and my 1:18 & 1:36 SUT, even on low with my Ref 3. I don't want to take my DIY SUT apart, just leave it at 1:18 & 1:36. That worked perfect with your less gain Reduction/Integration. I'm sure I'll have a use for it again someday...
  • ALL212
    ALL212 Posts: 1,558
    edited August 2015
    Looks cool! Where's the plans for your fist one? The DIY?
    Aaron
    edited August 2015
    Here is my revised CineMag ground scheme. I got the extra enclosure from Carl pre-drilled with RCA holes. We did innie trannies. I built three, one for Carl, one for Larry, one for me. The 3440AH or blues can be wired for 1:9/1:18 or 1:18/1:36.
    I used these DPDT On/On switches from Digikey, CKN1032-ND. Pricey (~$9 each), they were chosen for aesthetics, are sealed with gold plated contacts. Sealed and silver plated would also be good.
    http://www.digikey.com/product-detail/en/7201P3YZBE/CKN1032-ND/5559
  • agfrost
    agfrost Posts: 2,421
    Nice preamp. ;)
    Jay
    edited August 2015
    agfrost wrote: »
    Nice preamp. ;)
    Thanks! I think someone else has it now. Finally sold the KRC-HR too.
  • ALL212
    ALL212 Posts: 1,558
    Does anyone have the non-explosive illudium Q-36 space modulator? I need one.
    Aaron
  • mrbiron
    ALL212 wrote: »
    Try the moon.....if there's anything left of it.
  • mrbiron
    edited September 2015
    Resurrection...
    Where is this BAC!!!!????
  • ALL212
    ALL212 Posts: 1,558
    Looks like I hit preview instead of post!
    All parts are in ...I think. Transformer is painted, bell polished. I still have some mods to make on the top plate. New holes for the 8 pin sockets and I need to drop the transformer down a bit to get the choke in.uet4ahhl9ldo.jpg
    Aaron
  • voltz
    voltz Posts: 5,384
    Now that is a pretty site!! B)
    This choke?
    or this one?
  • ALL212
    ALL212 Posts: 1,558
    Ya know....with friends like this....
    Aaron
  • mrbiron
    So, you still use all of the basic wiring from the original schematic and drop those oil drums in place the "puny" caps?
    What stepped attenuator is that?
    Are you swapping out the cheapo binding posts for something more robust?
    And where did you get those BLACK sockets!?!?! That is what i want for mine. I hate the white!!!! ROARRRRR!! AHHH!!!! VVVRRROOOOMMMM!!!
  • ALL212
    ALL212 Posts: 1,558
    yep, most of the wiring will remain the same. the 12au7 is replaced with a 6sn7, but that's just a different pin-out at the socket.
    Attenuator is from Goldpoint.
    Binding posts are Vampire's.
    The black sockets I only got to piss you off, I have no intention of actually using them.
    Ok, just kidding. Parts Connexion has them.
    Aaron
  • mrbiron
    Well, you did a good job at that. Now i'm angry that YOU didn't mention them a while ago when i was complaining about the white. You just want your BAC to look nicer than my simple crack. Selfish SOB! :p
    Im not changing them now!
  • ALL212
    ALL212 Posts: 1,558
    Don't be a hater - didn't know they existed until recently. But if I had I wouldn't have told you anyway!! :D
    Aaron
