Another round of SDA Circuit Boards - Maybe
gimpod
Trey has 6 sets left and I'm trying to decide if I'm going to have another run made.
Is there enough interest to warrant a run of 25 sets (anything less is just not worth it). Or should I just stop before I get stuck with a bunch of boards I have no use for and be out a chunk of change.
That's wired I just got a message saying my response to your question would be posted as soon as it was approved.
Just goto my or Trey's vr3mods.com site.Post edited by gimpod on“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
That's wired I just got a message saying my response to your question would posted as soon as it was approved.
Just goto my or Trey's v3rmods.com site.
vr3mods.com
b]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Town Porch: WiiM Pro Plus * Sunfire Sig II * Canare 4S11 * Magnepan 1.6 * Dectet -
SORRY! I'm on drugs today, come to think of it I'm on drug everyday.
Thanks, Just fixed it. Thank god for the one hour edit.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Same as all the others $100.00 a set. It's the same board for all the forth and fifth gen SDA's 2B/CRS+, IC, SRS 2 (Pin/Blade), 3.1TLL, 1.2 and the 1.2TL
Check out my web site or you can order them here from, Trey Custom Not Polk SDA Circuit Boards Pair“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain -
Duplicate post. Man you just gotta love this forum software. NOT!Post edited by gimpod on“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain
Tony, it's like Larry's rings. As soon as they are no longer available, everyone wants them.Political Correctness'.........defined
President of Club Polk -
If you build them...they will come.
Go for it. Sooner or later you'll sell every one of them. I felt the same way about the polyurethane front suspension bushings for Toronado/ElDorado, but I commissioned a second run; and I'm almost out of those. -
Hey,
Ya know me, I am willing to help where I can... The Gimpod boards are great and have been an excellent modification for me...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I'd take a pair for my CRS+sMacBook Pro running Roon-Monoprice USB-Schiit Gungir Multibit-Audioquest Earth-Schiit Freya with Tung Sol 6SN7s-Audioquest Sky-Krell FPB 400cx-Audioquest Mont Blanc-1.2tls with all the mods.
I have some available, I can include them in your harness shipment.- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Make it so, Trey.MacBook Pro running Roon-Monoprice USB-Schiit Gungir Multibit-Audioquest Earth-Schiit Freya with Tung Sol 6SN7s-Audioquest Sky-Krell FPB 400cx-Audioquest Mont Blanc-1.2tls with all the mods.
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Are the boards necessary on the TL mod on the 2B's and CRS+? I need to do these mods and keep putting it off. I'm still undecided which ones to mod first. I'm leaning towards the CRS+s first.Home Theater
Polk Audio Boom Swimmer, Polk Audio Urchin -
I may take another set.Pio Elete Pro 520
Panamax 5400-EX
Sunfire TGP 5
PS Audio GCPH phono pre
Sunfire CG 200 X 5
Sunfire CG Sig 405 X 5
OPPO BDP-83 SE
Ctr CS1000p
Sur - FX1000 x 4
SUB - SVS PB2-Plus
Workkout room:
Onkyo TX-DS898
GFA 555
Yamaha DVD-S1800BL/SACD
Ft - SDA 1C
Not being used:
RTi 38's -4
RT55i's - 2
LSI 15's
CSi40
PSW 404 -
They aren't necessary for any SDA, but they make it MUCH easier and Tony's boards are of MUCH higher quality.Political Correctness'.........defined
Tony I would be interested in a set.Home Theater
They made the entire upgrade painless and easy. They provide the extra working room for the much larger caps.POLK SDA 2.3 TLS BOUGHT NEW IN 1990, Gimpod/Sonic Caps/Mills RDO-198
ONKYO HT RC-360 SONY BDP S590 TECHNICS SL BD-1 -
Yeah, after doing 3 sets of SDA's with Tony's boards; I must say it's doing SDA crossovers for "dummies".
If you have SDA's or plan on buying some in the future, you need a set or 3 of these boards.
"Have A Little Faith! And Everything You'll Face, Will Jump From Out Right On Into Place! Yeah! Take A Little Time! And Everything You'll Find, Will Move From Gloom Right On Into Shine!"- Arthur Lee -
WAAAAAAAAAAAAAAAAAAAAAA
afterburnt wrote: »They didn't speak a word of English, they were from South Carolina.
Village Idiot of Club Polk -
Hey all I just a quote from a company that can do 2 colors (black on top and green on bottom) Which if they can meet my standards I will do. But first I'm seeing if they'll run off a single set so I can check the quality and if they do then were in business.“The two most important days in your life are the day you are born and the day you find out why.” ~ Mark Twain
That's awesome- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
Sounds like a good planHome Theater/2 Channel:
dhsspeakerservice.com/ -
What do these cost? I may also be interested2 Channel - Polk SDA-2BTL, Carver TFM-35, Peachtree iDAC, Qobuz streamed via Episode Lynk using bubble UPnP server
Seems very reasonable. Do folks mount the larger erse sub bass complimentary inductors on these boards also or remote mount those?2 Channel - Polk SDA-2BTL, Carver TFM-35, Peachtree iDAC, Qobuz streamed via Episode Lynk using bubble UPnP server
Just a suggestion, maybe use google docs like they do for the group buys at diy audio. Folks enter their name, what they want. Once you get to or past the number of boards that makes it worthwhile, you close the GB and make your order.
https://www.google.com/docs/about/
An example.
https://docs.google.com/spreadsheets/d/1L6k7HAUnjGq9E8KBfIGz6SJ-vrsQGGyQrV-R8c4qBG0/edit?usp=sharingSalk SoundScape 8's * Audio Research Reference 3 * Bottlehead Eros Phono * Park's Audio Budgie SUT * Krell KSA-250 * Harmonic Technology Pro 9+ * Signature Series Sonore Music Server w/Deux PS * Roon * Gustard R26 DAC / Singxer SU-6 DDC * Heavy Plinth Lenco L75 Idler Drive * AA MG-1 Linear Air Bearing Arm * AT33PTG/II & Denon 103R * Richard Gray 600S * NHT B-12d subs * GIK Acoustic Treatments * Sennheiser HD650 * -
I'd be in for a set. Thanks, @Gimpod.
Craigb]Beach Audio[/b]: Rega RP6 (mods) - AT33PTG/II - Parks Budgie SUT - PSAudio NPC * Eversolo DMP-A6 * Topping D90iii * Joule-Electra LA-100 mkIII * Pass Aleph 30 * MIT S3 * Polk SRS 2.3tl (mods) * PSAudio PPP3
Oops wrong thread my apologiesHome Theater
unless it was possible to change the words to say " A Briefcase full of Circuit Boards"2 ch- Polk CRS+ * Vincent SA-31MK Preamp * Vincent Sp-331 Amp * Marantz SA8005 SACD * Project Xperience Classic TT * Sumiko Blue Point #2 MC cartridge
Still no love for the original SDA-SRS's (non 1.2/1.2tl)?
