Running Dual sub question
gudnoyez
gudnoyez Posts: 8,068
Hey quick question y'all should the subs be placed on the insides of the towers or the outsides of the towed for best performance? I'am waiting for my AVR to show up so just setting up the speakers now and would like to know sub placement I do want them up front.
Post edited by gudnoyez on
  • Tornado Red
    Tornado Red Posts: 939
    edited June 2014
    I have mine on the outside. My mains would have been too far apart for my sweet spot had I opted for the subs inside, plus they sound better there than inside, at least for my room and sitting area. YMMV, of course.
    SCompRacer Posts: 8,352
    edited June 2014
    Either inside of the mains or outside is fine. Keep in mind the closer you get to the corners of the room, you will get corner gain. I approach stereo sub setup like my main speakers. Listen, move, run a room sweep, L than R and then combined. You may have to move your subs closer to or further from rear wall or even at different distances to have them low frequencies at your listening position.
    Some subs have a boundary control for corner placement. My nht B-12d's have -3dB, 0 or +3dB control. Mine shore up the 25-35Hz range due to the large space my mains are in. I have them on the outside and set about a foot behind the front of my main speakers. My left sub runs at -3dB. I have stacked GIK Tri Traps in left corner, one on right corner chimney wall and one in left rear of room.
    edited June 2014
    Thanks Red, we will be sitting 8 foot back from the screen so my fronts will be 8 foot apart which leaves me plenty of room either on the inside of the fronts or on the outside of them as the wall is over 20 feet. I guess I will just experiment I just wondered if there is a preferred way by those that of tried it either way.
  • danz1906
    danz1906 Posts: 5,144
    edited June 2014
    SCompRacer,
    Nice Speakers!!!
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
    edited June 2014
    danz1906 wrote: »
    SCompRacer,
    Nice Speakers!!!
    +1 nice everything
  • Inspector 24
    Inspector 24 Posts: 1,308
    edited June 2014
    I've personally never liked the sound of a corner placement subwoofer, evar in any room I've heard. Only done it with very weak subs when it was the only way to get a boost from it, or other placement reasons.
    I do like subs placed either in the center of the room or 1/4 the room width from the side walls. Not as much ultimate output but much cleaner and tighter in my limited experience.
    Up
    LSi15 LSiC - RX-V3000
    Down
    Sim2 D60 - Dragonfly 106" Panny 500
  • Mikey081057
    Mikey081057 Posts: 7,127
    edited June 2014
    i have 2 mp3k's both of them on the outside...i set them up using the polk utility individually and then let audessy balance them to the ht pre pro...And have them both in subdudes..
    Garage | Polk Monitor 5B's
  • Thorton
    Thorton Posts: 1,324
    edited June 2014
    SCompRacer wrote: »
    I ageee and follow the same procedure. I also have GIK traps. REW makes placement and adjusting easier. Based on your AVR selection, you may have to do a "Sub distance tweak" to dial it in perfectly. The results can be outstanding. Good luck.
    DAC: Bricasti M1SE
    Pre/Pro: Marantz AV8805
    Subs: 2 - Rythmik F25's
    edited June 2014
    Thanks for the kind words!
    Thorton wrote: »
    I'm using a two channel pre so all I have are the sub adjustments and relocation. If I couldn't of got it right via those adjustments, I would have used a Behringer to digitally EQ them. Not visible in the right speaker pic, I am open to the main level at the edge of the two tier album rack. That adds another 25' x 20' area with 14' ceiling. My first floor area is a great lesson in room modes.
    Speaker response is 25Hz - 20KHz (+/- 1.5db). I've had other speakers that dig deeper, but they all needed help in the nether frequencies on that wall. Bass is not soggy or boomy, at all. Subs come in with dubstep or organ music, otherwise the speakers do the majority of the work for most of the music I listen to.
  • Thorton
    edited June 2014
    SComp, I kinda fiqured that based on your sig. That's a beautiful set-up you have. I bet they sound amazing. The SS8's are #1 on my list right now when I upgrade. I was amazed by them at Axpona . I would love to hear them in a proper room and set-up.
    Gudnoyez, what AVR did you purchase?
    DAC: Bricasti M1SE
    edited June 2014
    A Onkyo TX-NR838 it's shipping from a Chicago Area Magnolia once there stock arrives.
  • Polkie2009
    Polkie2009 Posts: 3,834
    edited June 2014
    Very nice room and system Tornado Red, love that Toronto Maple Leafs throw on the davenport sir!
  • Tornado Red
    edited June 2014
    Polkie2009 wrote: »
    Ha, nice catch. In the other pic I have a small Tim Horton wearing Leaf blue on a plaque on the end table.
  • AudioPro
    AudioPro Posts: 10
    edited June 2014
    Wow, those speakers are classic looking.
