SDA Polyswitches Are Nasty
12346»
    xschop Posts: 5,103
    Fire Marshall Bill
  • DarqueKnight
    DarqueKnight Posts: 6,765
    K_M wrote: »
    Sorry, 2 wrong assumptions.
    The assumptions were reasonable since low powered, over driven amplification is the most common cause of clipping and since you didn't explain that you were moving a loose power amp connection around while the amp was on.
    In either case, the cause of the clip was a transient energy spike.
    Toolfan66 Posts: 18,012
    It's been so long I don't even think about a poly switch these days, and forget how good it is to rid yourself of them, whether you call it a mod or taking out the trash, they are nasty!!!
  • K_M
    K_M Posts: 1,632
    K_M wrote: »
    Assumptions can be reasonable, but often wrong.
    Thanks for clarifying.
    heiney9 Posts: 25,428
    K_M wrote: »
    K_M wrote: »
    My assumption came from the comments and your general thoughts about the robustness of your receivers in the "Polk Signature Series Official Discussion". I guess you should have done a better job of giving enough information so people didn't have to extrapolate based on your most recent posts.
    More background info always helps to avoid miscommunication.
  • K_M
    K_M Posts: 1,632
    heiney9 wrote: »
    K_M wrote: »
    K_M wrote: »
    I did mention we were only "Trying" it (Avr) and compared to our power amps and stuff though. Not a big deal....thanks!
