Installing rc60i in ceiling, 220v line near
jacobson
jacobson Posts: 1
edited November 2002 in Troubleshooting
I'm installing a pair of rc60i in a ceiling. The only spot I can put them will leave the speakers 1" from the 220v line that feeds my oven/stove. Will I get any interference through the speaker? 110v is near also (2-3"). Also, does anyone recommend placing insulation behind them ( for sound)? The placement is in the ceiling between the first and second floors. Thanks for the help.
Post edited by jacobson on
  • mantis
    mantis Posts: 17,057
    Right near power huh,
    not good.If you can relocate the speaker,it would be in your best interest.Don't defeat your purpose with a hum.....If the speaker has to stay there,At least run the speaker wire away from the power lines.I would consider a different location.Patching isn't hard save the cuttout and use wood backing.allgood.
    Insulate all day,use it,it will tighten up the little bass response you can get out of them.
    Dan
