DIY Acoustic Panels With WAF...Pics!
hochpt21
About a buck a board...
Easy cuts...48" and 25.5"
Wood glue, small nails and inside corner brackets to keep the frame sturdy...
Some printed burlap at 30% off is about $11 per board...
Pulling tight and stapling is probably the most annoying part...
Insert the fiber board. I got mine at ATS acoustic. It's similar to Owens Corning 705, but without the formaldehyde...
2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
And here you go!
Less than an hour per board. I am going to mount them and I'll show those pictures when that actually happens...
Looks very nice. I always said I would make the type you have made but never did get around to it. I finally did this
http://www.diyaudio.com/forums/everything-else/269366-making-easy-diy-depot-sound-diffuser-panels-step-step.html
I can work with the wood and 2-8 ft difusers cost about $130 not counting the nails to hold it all together. Made a huge improvement! Pics later.Post edited by bikerboy onMain system: Lyngdorf TDAI 2170 w/ Pioneer 42" plazma-> Polk LSiM 703 w/Tivo, Marantz tuner, BRPTT: Nothingham Spacedeck-> Pioneer PL L1000 linear arm-> Soundsmith DL 103R-> SUT->Bottlehead ErosDigital: I3 PC w/ Jriver playing flac -> Sonore Ultrarendu -> Twisted Pair Audio ESS 9028 w/ Mercury IVY Vinyl rips: ESI Juli@24/192-> i3 PC server -
Very nice and I like the printed burlap. I've never seen it before.
Looking forward to the final pictures.
Because I am The Pumpkinking
Looks great.Home Theater/2 Channel:
dhsspeakerservice.com/ -
Reallly nice - great job - I might even get that approved here!VA HT HK AVR20II, Sony S9000ES CD/DVD/SACD, Polk Audio RC80i / Polk Audio CSi3, 60" Panasonic Plasma, Nordost / Signal Cable A2 / Wireworld / Pangea / Magic Power
Polk SDA1c modded
Polk SDA2BTL (fully modded)
SACD Marantz DV8300
Yamaha YP-D6
Soundcraftsmen PCR800
Audible Illusions L1 Preamp
Pho-700 Phono Pre
Nice job Paul. Hates the WAF. Glad I'm single.
Nice job. They look good._____________________________________________________________________________________________
DAC: Bricasti M1SE
Pre/Pro: Marantz AV8805
Subs: 2 - Rythmik F25's
Room Treatments: GIK Acoustics -
Yes, great job! Simple, but hopefully effective. Can't wait to hear how they work out for you.
Those look terrific. I was going to build my own when I set up my studio for recording, but never got around to it, so bought them.
If the fiber board is flush with the back, you may want to put something in the corners to separate it a bit from the wall.
An old, but effective article. Ethan Winer knows what he's talking about:
http://recordinghacks.com/2011/12/13/mounting-acoustic-panels-variable-air-gap/2 Channel "Polk" Room:
Marantz PM8004 Integrated
Marantz SA8004 SACD Player
WiiM Mini
Polk 7B with RDO198s -
Excellent
Cool, Paul!
Where did you source the printed burlap?
And, you mean used potato sacks from 5 Guys Burgers wouldn't've been acceptable?
What's ATS?
Do you know how you'll mount them yet? Just hanging wire? Looks like a great place for hiding secret documents, too.
I might be watching too much Burn Notice.I disabled signatures. -
Good work, treating the room is one of the first steps to good audio! I made a set almost identical to yours a few years ago, wouldn't be without them now.
Cool, Paul!
What's ATS?
JoAnn Fabrics. Printed burlap is 2 or 3 times more expensive so use a coupon or wait for a sale. And if you want just standard burlap, you can make these super cheap.
Google ATS acoustics. They sell fully completed products and also DIY material. I also think a lot of people like GIK acoustics.
My plan to hang them... I bought 6" landscape screws and I'm going to have about 2.5" sticking out from the wall, then I'll put hooks on the top of the panel and just set them on the screws at the ends away from the wall.
It looks cool in my mind, but we'll see how it turns out.2 ChannelTurntable - VPI Classic 2/Ortofon 2M BlueAmplification - Rogue Audio Cronus Magnum II, Parks Audio Budgie PhonoSpeakers - GoldenEar Triton 17.2 Home TheaterDenon AVR-X3300W; Rotel RMB-1066; Klipsch RP-280F's, Klipsch RP-450C, Polk FXi3's, Polk RC60i; Dual SVS PB 2000's; BenQ HT2050; Elite Screens 120"Man CaveTurntable - Pro-Ject 2.9 Wood/Grado GoldAmplification - Dared SL2000a, McCormack DNA 0.5 DeluxeCD: Cambridge AudioSpeakers - Wharfedale Linton 85th Anniversary; LSiM 703; SDA 2A -
That was a joke about 5 Guys Sacks, haha
Regular burlap would probably be pretty gnarly unless you were putting these up in a rustic cabin? And they'd smell like potatoes.
ah man, that actually does sound kind of cool having them out off the wall a bit.
Great tips.I disabled signatures. -
Very nice idea and implementation!
I would think it'd be fairly easy to also use a standard fabric and screenprint/stencil a specific design onto it.God shows his love for us in that while we were still sinners, Christ died for us. - Romans 5:8 -
Very nice. As an aside - I have been able to get a few burlap bags from a local
coffee shop - some look quite nice. -
Great job Paul. As already mentioned, room treatments are a must for anyone serious about the performance of their system. It is one of those investments that is hard to rationalize due to cost. Then you hear the difference....
I believe if you hunt and dig hard enough it can be done for a reasonable cost. Buying them straight from gik or prime acoustic is super expensive. Six corner traps costing 299 a pair!2 channel:
Theater:
Focal Aria 926,905,CC900, SVS PB ultra x2. Pioneer Elite SC85, Oppo BDP93, Panamax M5400PM, Minix neox6, Nordost Blue heaven LS power cables. -
Shipping is what kills you with a purchase. My bass traps are from GIK, and I love them, but they were expensive to ship. Fortunately I found someone in LA who makes the 2" panels for not much more than it would cost me. That said, these printed ones are WAY cool!2 Channel "Polk" Room:
WiiM Mini
Very nice work. I will echo what others have said that room treatments do make a big difference.
I like itMojo Audio Illuminati v3>>Quantum Byte w/LMS>>Rpi/PiCoreplayer>> Starlight 7 USB >> Mojo Audio Mystique v2 SE>>ModWright SWL 9.0 SE Signature>>Hafler DH-500 Amp+ (Musical Concepts Fully Modded)>>
1KVA Dreadnought
Marantz SA 8005
Sony PS4
