Please Help!!
Johnnybass
Johnnybass Posts: 39
edited February 2009 in Speakers
I need help on where to place the rear speakers.Where the sofa is against the wall the speakers are "B".to the lerft and right of the sofa the speakers are"A".
Do you put the speakers facing front on the wall the sofa is on"B". or do you have them facing the sofa from the outer walls"A"
I also need to know how high over you head do you put them.
The room is 19 feet wide by 13 feet deep.
Thanks a bunch. John
Post edited by Johnnybass on
  • danger boy
    danger boy Posts: 15,722
    depends on if your rear speakers are direct or bi/di pole speakers. bi/di pole speaker seem to be more forgiving in their placement. they work well on side or rear walls. mine are on side walls running in bi pole mode. I have never had to move them.
    rear speakers should be placed 3ft above your head or higher.
    PolkFest 2012, who's going>?
  • Johnnybass
    danger boy wrote: »
    Danger boy
    There RM6005 satalite speakers
  • seeclear
    seeclear Posts: 1,244
    I don't know that I would go 7.1 in a room that short. 5.1, and put your surrounds on the side walls. Those rear speaks are not going to project much valuable output to the viewer on the couch anyway, IMO.
    "Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
  • Face
    Face Posts: 14,340
    I agree, stick with 5.1.
  • thuffman03
    thuffman03 Posts: 1,325
    +1 on a 5.1
    Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t
  • danger boy
    +1 on the 5.1 not many movies use 7.1 that I know of unless you go Blu Ray.
  • ddkane
    ddkane Posts: 8
  • kneedragger37
    kneedragger37 Posts: 108
    danger boy wrote: »
    No disrespect intended - just wanting to confirm your opinion on this... I've read posts on other forums that getting the surrounds 3 feet or more above the listeners' heads is from an old dolby pro logic guideline that restricted sounds in the surround speakers to ambient and directionless noises. Now that digital 5.1 puts distinct, directional sounds into the surrounds, placing the surrounds at ear-level is said to be more desirable -- dolby's own speaker setup guide at dolby.com shows surrounds for both 5.1 and 7.1 at ear level.
    Are these posts correct or should surrounds still be going up high?
  • Johnnybass
    I thought 5.1 is 5 speakers???i only have 5.
  • comfortablycurt
    comfortablycurt Posts: 6,745
    Johnnybass wrote: »
    5.1 is 5 speakers(fronts/center/surrounds), with the .1 being the subwoofer.
    +1 on the 5.1.
    Personally I prefer my surround speakers to be more at ear level. It used to be true that the surrounds were better off being above ear level, but I don't think it's really recommended anymore with the way todays soundtracks are recorded.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • NewHTguy
    NewHTguy Posts: 584
    Johnnybass wrote: »
    The .1 is the sub.
    Thanks for asking this question. I have the same layout and concerns.
    MAIN: Polk Lsi9s; Polk PSW505; Lsic (in box); Onkyo SR-875; Parasound 2250; Cambridge Audio 740C; LG BD370
    OFFICE: Polk Lsi7; REL T3; HK 3490; CA 840W; Onkyo C-S5VL
    BENCHED: CS20; OWM3s
  • Johnnybass
    NewHTguy wrote: »
    The .1 is the sub.
    i forgot:o
  • Johnnybass
    +1 on the 5.1.
    Ok sounds good.i guess it is better to have them pointing at your head on the side then facing forward and sending the sound back to the tv.
  • Face
    Face Posts: 14,340
    I guess it depends on your setup. Since my surrounds are only a couple of feet away from the listening position, I would not want them ear level. IMO, they sound best 2' from my head. But if the surrounds were further away, I could see ear level working out. I was unaware they changed their setup guide also.
  • Johnnybass
    Face wrote: »
    They will be 5 to 8 feet away from your head.it all depends on where you are sitting or what sofa or chair you are in.i think i might try them two feet above ear hight???what do you think?
  • Johnnybass
    they do sound better on the side wall two feet above our heads.i put the speckers on small and i'm learning about the different lisening modes the recever has.
    Thanks everybody!:D
