PS3 best version?
gold01ca
gold01ca Posts: 50
edited February 2009 in Video Games
just wondering which version PS3 is the best buy?
best features, performance, compatibility etc.
thanks.
Post edited by gold01ca on
  • ND13
    ND13 Posts: 7,601
    edited January 2009
    The best was the 60gb original version. They'll be almost impossible to find new. Of the newer ones, just go with the one that has the hard drive that suits your needs.
    "SOME PEOPLE CALL ME MAURICE,
    CAUSE I SPEAK OF THE POMPITIOUS OF LOVE"
  • gold01ca
    gold01ca Posts: 50
    edited January 2009
    any other comments?
  • manman
    manman Posts: 256
    edited January 2009
    Yeah, the 60GB has more the most features- card reader, more usb ports (i think), hardware based backward ps2 compatibility, and plays SACDs. Not sure how well they hold up over time compared to the newer models though, that has yet to be seen.
    The newer ones are more power efficient, quieter, and don't heat up as much though. That's never really been a problem anyway, but I'm just noting that both have some advantages. 60GB still clearly wins out IMO though. :D
  • cheddar
    cheddar Posts: 2,390
    edited January 2009
    Yes, the 60GB had the most features. But it was the launch console in November 2006 along with the much less produced 20GB. So unless you're shopping on ebay, etc. you won't be able to find one at Target...no problem with reliability compared to console averages.
    After those units, you get declining compatibility with ps2 games with the 80GB released in 2007 IIRC. Then the 40GB and all hard drive sizes released at the end of 2008 to the present (including the 80GBs) will no longer play ps2 games or SACD.
    Other core functionality is the same, though, including blu-ray playback, across all the versions. So unless you absolutely have to have near 100% ps2 compatibility or SACD, searching for a 60GB might be a waste of time. If you do get a new one, get the cheapest one you can regardless of hard drive size. Don't pay attention to Sony marketing bundles that try to get you to buy a bigger hard drive package. Then get a cheap 160GB or greater generic SATA laptop drive that installs with a screw driver if you need the extra space. Search youtube for many how-to videos on how easy it is. My 60GB is now a 200GB and is still going strong since early 2007.
  • manman
    manman Posts: 256
    edited January 2009
    60GBs used to be really high priced, but now they go for a little over 400 on ebay not hard to find at all. If I had the cash I'd pick one up and put my other one in the bedroom... Also- there is one difference in the latest models of 80GB, they don't have the card reader that the old one used to
  • cheddar
    edited January 2009
    manman wrote: »
    I suppose this feature may be convenient for some, but there are so many other ways of getting content into the ps3 if you are using it as a media hub from streaming content from your pc to usb thumb drives and external hard drives...
  • manman
    manman Posts: 256
    edited January 2009
    Just pointing out the change, not making a value call on it.
  • Montoya
    Montoya Posts: 506
    edited January 2009
    I got a 20gig bought a 350 gig drive and had planned to harwire the net connection anyway so didn't need the wi-fi connection. I thought it was a good deal but not sure if the 20gig is still available?
  • fatchowmein
    fatchowmein Posts: 2,637
    edited January 2009
    manman wrote: »
    Yeah, the 60GB... Not sure how well they hold up over time compared to the newer models though, that has yet to be seen.
    Supposedly the BR laser portion was a cheap version and goes out. There is some rumble from PS3 60GB owners wanting a recall but there's not enough of us complaining or perhaps not enough of that particular model's BR laser croaking. Maybe a majority sent their unit in before the warranty expired. Others have resorted to purchasing replacement units on ebay and attempting to do the surgery themselves instead of forking over $150 to Sony. Difficult to determine as there's not that much info out there compared to the 360's RRoD.
  • jflail2
    jflail2 Posts: 2,868
    edited January 2009
    Ive got an original 60, but got it near the end of the cycle. Haven't had a problem one with it.
    I had 2 360's crap out on me in a month and took the second one back to BB for a PS3. With blu-ray and the new Sony LCD, I think I made the right choice.
  • manman
    manman Posts: 256
    edited January 2009
    The thing is- I actually have an 80GB that failed on me for BR... DVDs worked fine and everything just BRs stopped reading correctly. I sent myine in and they fixed it pretty quickly though. Of all my friends I'm the only one that has had this happen with the 80gb, and I dont' know anyone with the 60, so I don't really know what problems that has... could be that the 60 and 80 share the same laser assembly and I just got unlucky though...
  • doggie750
    doggie750 Posts: 1,171
    edited January 2009
    60GB..........IT has all the features you need.
    Godspeed,
    D0661E
    AVR:Pioneer Elite SC-07
    Surrounds: RTis
    2channel:Rti100 (carver driven
    Sub:SVS PB12-Plus/2
    Dedicated AMPs:Adcom GFA535, 2xCarver 1.5t, Carver m1.0t
    Wsrn:Hitachi ultra vision LCD60, 32XBR400
    PowerConditioner: MonsterC HTS5100
    PS3, Toshiba HD A2, etc: SonySACD/ Panasonic gears DIVX.
    MR3LIGION: Polkaudio; GSXR; E46; Reeftank;
    Odyclub; Xsimulator; Sony; Zune; Canon
  • wutadumsn23
    wutadumsn23 Posts: 3,702
    edited January 2009
    I have loved PS3 since they came out, and still love them now. I have lost a little bit of faith lately though with 2 of my 3 PS3's dying on me. Both my sons' PS3's died within 2 weeks of each other, both were older model 60's. I sent one in for repair, since it was out of warranty, and the other is just waiting toi get sent back in when I feel like shelling out another $170ish to get the other one fixed. I have an 80GB and (knocks on wood) have had no problems on it. I got scared the other day though when I went to watch a Blu-Ray and it said I couldn't read it!! I almost crapped my pants, luckily though it was just dirty and once cleaned worked fine.
    HT Rig
    Receiver- Onkyo TX-SR806
    Mains- Polk Audio Monitor 70
    Center- Polk Audio CS2
    Surrounds- Polk Audio TSi 500's :D
    Sub- Polk Audio PSW125
    Blu-Ray- 80 GB PS3
    2 CH rig (in progress)
    It's not that I'm insensitive, I just don't care.. :D
  • thsmith
    thsmith Posts: 6,082
    edited January 2009
    HAd my 60G near end of production and have had no problems with it, same for my X360 but they both are used for Audio and Video media only no games.
    They may last longer as media extenders and media players than gaming consoles.
  • CaligulaPolk
    CaligulaPolk Posts: 1,650
    edited January 2009
    if people's ps3 broke, not that long after purchased. THEY ABUSED IT!! OR DOWNLOADED **** off the net, lot damaging to hard drive.
    my 60 gb never gave me any trouble because I took good care of my ps3. i dust clean three times a week and polish it with micro fiber towels. I clean fans with Q tip sametime.
    offer few candles to worship PS3 Gods afterward, PS3 is the best!!
    NO IM NOT PLAYSTATION FAN NERD! PS3 is expensive and i take good care of the stuff in my home.
    I am 100% BORN DEAF and No I am not kidding! :D Why am I here? My wife's hearing! :p
    My Home Theater Rig || Television: 58" Panasonic TH-58PZ800U Viera Plasma || Power Conditioner: Power Monster HTS 3600 MKII || Receiver: Onkyo TX-SR805 || Blu-Ray/Gaming: 60 Gigabytes Playstation 3 || Amplifier: Emotiva XPA-5 || Fronts: Polk Audio RT800i || Center: Polk Audio CS245i || Surrounds: TBA|| Subwoofer: TBA
  • wutadumsn23
    edited January 2009
    Well said Caligula, that is exactly why my sons' playstation's broke, they used the hell out of them and didn't take care of them. I on the other hand baby my 80GB and have had it almost as long as they have had their 60's and it still working like a champ (knocks on wood)
    HT Rig
    Blu-Ray- 80 GB PS3
  • metal83
    metal83 Posts: 1,219
    edited January 2009
    ND13 wrote: »
    This sums it up pretty much, the only thing you'll be missing from the newer PS3's is SACD and BC. But i could personally care less about BC, i have no desire to play PS2 games when i could play PS3 games. But in all honestly i use my XBOX 360 for video games because i like it much better, my PS3 is used for blu-ray movies and music.
  • steveducie
    steveducie Posts: 192
    edited January 2009
    was there any problems with the 40gb . i see they've been discontinued . i only ask because i just picked up a used 40gb with the seperate MGS4 Collectors Box Edition and Skate games for 270.00 .
  • metal83
    edited January 2009
    steveducie wrote: »
    Nope, none that i'm aware of anyways. I've had my 40g for about a year with no issues at all.
    Decent price you got there by the way (if it's in good condition), especially considering you got some games with it.
  • steveducie
    edited January 2009
    metal83 wrote: »
    its in pretty good shape . plus i got on the layaway plan.im paying my sons insurance for the next 3 months and i already have possesion . he's more into the 360 .
  • fatchowmein
    I opened up my ps3 because it's out of warranty anyway. The B-R drive was spotless. The rest of the unit had very little dust. I mean there really wasn't anything to clean. To test it again, I ran 10 blu-rays through it: Resident Evil, 28 days later, 28 weeks later, Swordfish, The Hunt for Red October, Wanted, Wall*E, Underword, Underworld Revolution, and X-men the Last Stand. Only X-Men played and I let it play over and over again so I don't think this is a laser problem. When I inserted the next disk - nothing. No problems at all with DVD's.
    BR disk recognition problem? Perhaps a HDCP handshake problem? I just dunno. Latest patch installed but no luck.
