Active crossover on the cheap???
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    I'll try to contact him. I had to spend a lot of coin to do my pre/phono pre just to get the right values. Now I have a ton of R's that I will probably never use, and I don't have R's that would be handy to mod XO slopes:(
    Ben
  • strider
    strider Posts: 2,568
    edited January 2009
    If he is still selling, lemme know. Right now I'm leaning towards one of the Marchand kits, but I'm really taking a WAG that a 4th order LR crossover will work in my situation. Something like the kit on the snippet link would be perfect to fool around with.
    Wristwatch--->Crisco
    treitz3 Posts: 20,134
    edited January 2009
    I just got hooked up with a Clearview active crossover. It's variable and does a great job in the rigs I have heard it in. When it gets here, I'll let you know how it works in my rig Mr. EarlyB.
  • ben62670
    edited January 2009
    I did the Marchand XO in my pre. It is a simple cheap kit. He has a program to figure out the slopes in case you want to mod it. They come with the BB2134 OpAmps now. All you need is a PS. A rat shack 12-0-12 transformer is fine if you mount it out of the box. The Marchand PCBs are top notch too.
    http://www.polkaudio.com/forums/showpost.php?p=900306&postcount=38
    treitz3 wrote: »
    Send it down with Russ in Feb I'll test it for you for free:) Actually I would love to have something I can turn a dial on to figure out where I want to fix my XO point at.
    Ben
  • Systems
    Systems Posts: 14,872
    edited January 2009
    ben62670 wrote: »
    Like this?http://www.behringer.com/EN/Products/CX2310.aspx Believe it or not I have heard reports of some using this inexpensive unit in very good systems with very good results. They can be had for $90ish.
    Testing
    Testing
    Testing
  • ben62670
    edited January 2009
    unbalanced:)
    Ben
  • Systems
    edited January 2009
    ben62670 wrote: »
    unbalanced:)
    Yeah the balanced only input is a pain, but you could whip up some bal to unbal adaptors/cables in a jiffy.
    Testing
    Testing
    Testing
  • ben62670
    edited January 2009
    I have a car stereo XO that I used to use. It worked pretty well, but no 15-0-15. I don't know how that affects SQ, but it is good to be able to turn some pots to test with. I have a GSA-700 surround amp I'll post some pics of later. I am ripping the digital out and I took a 4 1/2" grinder with a cut off wheel to the board to steal the amps. That will be my new integrated pre DAC XO. The pot that came with the Adcom is a motorized 6 channel, and I am thinking of stealing the IR control unit from my remote volume control on my other pre. The amp section is like a 535 from what I can see. I may drive the tweeters for now with that and see what it sounds like. There are a couple naughty DC caps in the signal path that I may bypass or replace with better units. It will be for the highs so caps shouldn't hurt?
    Ben
  • strider
    edited January 2009
    Early, et al.
    Found a pretty interesting XO project on DIYaudio while researching for my project. Basically an analog XO unit that's adjustable for order, frequency, and Q. Also has balanced and unbalanced inputs/outputs. I'm just wading into the thread, but looking at the schematics and PCB layouts on the first page it looks pretty promising.
    http://www.diyaudio.com/forums/showthread.php?s=&threadid=27651&highlight=
