Is this a good deal for a pair of RTA 11Ts?
Dawgfish
Dawgfish Posts: 2,554
edited February 2009 in Vintage Speakers
Hello folks,
I am looking to start assembling a two channel set-up comprised of some vintage Polk speakers and tube amp and preamp. I have come across a pair of RTA 11T Polks here locally for $250/pr. The speakers are in fine operating condition, but have a few scratches on the cabinent (see attached photo). Is this a good deal for these speakers or would I be better of passing on these? I would eventualy like a set of SDAs for the setup, but wouldn't mind having something to get me by until I can find a pair of those. Thanks in advnce for the advice.
Post edited by Dawgfish on
  • george daniel
    george daniel Posts: 12,096
    edited January 2009
    eh,, offer him,, 200 bucks,,which is a fair price,IMHO
  • danz1906
    danz1906 Posts: 5,144
    edited January 2009
    That sounds like a Fair offer:cool:
    Linn AV5140 fronts
    Linn AV5120 Center
    Linn AV5140 Rears
    M&K MX-70 Sub for Music
    Odyssey Mono-Blocs
    SVS Ultra-13 Gloss Black:D
  • Dawgfish
    edited January 2009
    Thanks!. Yeah that's what I was thinking about offering him. That seems fair to me. I've done a search on these speakers and have seen mixed reviews on these. What do you all think of them and how would you compare their sound to some of today's Polk speakers like the RTi series or the LSis? Thanks in advance.
  • george daniel
    edited January 2009
    I've owned a couple pairs,, the bass and mids are very good for their size,, placement will result in some pretty good imaging,you may want to consider the rdo tweeter replacement at some point.Now,, if you put some tubes in the mix,with a good source,you will have a very respectable 2ch system. Good luck,let us know how it turns out.
  • Dawgfish
    edited January 2009
    Thanks for the advice. I think I'm going to pull the trigger on these. I'm definitely going for a vintage/tube/warm sound with the setup. I'll keep y'all posted as I add to the system and get it tweeked.
  • riglehart
    riglehart Posts: 276
    edited January 2009
    I have a pair and LOVE them. I own 4's, 5's, 7's, and 2.3TL. I consider the 11T the best bang for the buck of all.
    Jolida Tube
    Polk 11T, 7, 5, 5jr, 4
    Standard equip not worth bragging about.
  • Pauly
    Pauly Posts: 4,519
    edited January 2009
    I paid 200 on a minty pair local and they have great bass, imaging, clarity and are sexy with the tops off. Sure you can get those for 200 easy.
    Pauly
    Life without music would
  • Ron Temple
    Ron Temple Posts: 3,212
    edited January 2009
    Compared to RTis, I like the RTAs better...much more laid back, similar to SDAs w/o SDA. Compared to LSis, it's a toss up...probably go with LSis.
    Combo rig:
    SDA 1C, CS400i, SDA 2B
    PB13Ultra RO
    BW Silvers
    Oppo BDP-83SE
  • woodsman10b
    woodsman10b Posts: 408
    edited January 2009
    Just to let you know there is a pair on ebay, the auction ends in approx. 2 1/2 days. nobody has bid on these as of now and the starting bid is 100 bucks with shipping in at 102 bucks. they are eggshell color and appear to be in nice condition, but they have no grills. its worth a look you might like or dislike the color.
    Most of them only hear how loud it sounds, and the rest of us hear everything else - :rolleyes:
  • stixnstones
    stixnstones Posts: 1
    I also picked up a pair of these RTA11T and im having trouble with them. Getting nothing out of the tweeters and what sound im getting out of the rest is terrible. Not my amp as i hook up a pair of pioneer hpm 40s and they are fine. Are there still replacement parts for these models? Any help appreciated, this is my first post on polk. Thanks-Phil
  • danger boy
    danger boy Posts: 15,722
    sounds like several of the tweeters and drivers are toast in your speakers. something isn't right.. you'll have to do some more investigating to find out what the problem is. push the speaker and see if it sound scratch when you push it in. Not sure if that model had fuses on the back or not.. I don't think they do... but IF they do.. check the fuses.
    PolkFest 2012, who's going>?
  • comfortablycurt
    comfortablycurt Posts: 6,745
    danger boy wrote: »
    No, the RTA11T's didn't have fuses.
    You might want to check for airleaks too...that wouldn't really be affecting the tweeters, but it could definitely be affecting the mid-woofers. Push in and hold both of the passive radiators, the two mid-woofers should both come out, and stay out for a few seconds, and then start moving back in really slowly. If they move back in quickly, then you have some airleaks, which would definitely affect the sound quality.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • skrol
    skrol Posts: 3,464
    Are both speakers doing this?
    You might also check the crossovers. Mine seemed ok for 17 years then one of the tweeters stopped working. I found a few bad solder connections on the crossover.
    Stan
    Main 2ch:
    HT:
    Other stuff:
  • John30_30
    John30_30 Posts: 1,024
    I'd bet it's in the wiring or banana posts. You have a multi-meter?
    Pull the crossover panel off the back (gently) and have a look inside.
