Need a recommendation for a receiver to drive a pair of LSi15.
Siddhartha
I just "won" a pair of LSi15 on ebay from Polk. I currently have a dodgey 13 year old top of line Pioneer receiver which I can now justify replacing.
I mostly will use my system to listen to music with ocassional playing of TV and movies. My price range cap is $1000 USD.
Any help will be apreciated!
Siddhartha
Siddhartha
Post edited by Siddhartha on
Those are 4 ohm speakers...most AVR's aren't really capable of driving 4 ohm loads, you'd probably be better off looking into a seperate pre/power amp combo. I'm sure you could manage to put something decent together for 1000 bucks.
Are you looking to set up a home theater system with them, or is it going to be dedicated two channel?The nirvana inducer-
APC H10 Power Conditioner
Parasound Halo P5 preamp
You need an amp.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben -
I am thinking about first getting an Onkyo TX SR 876 receiver and later adding an amp to drive the 4 ohm speakers. I live in an apartment and care about my neighbors so I think the Onkyo will suffice in the short term since I will not be playing my system too loudly.
I am open to suggestions about other options.
Siddhartha -
Here is one:
http://www.audiogon.com/cgi-bin/cls.pl?miscrcvr&1237217012&/Rotel-RSX-1067
welcome to CP, Sid.I am sorry, I have no opinion on the matter. I am sure you do. So, don't mind me, I just want to talk audio and pie. -
All,
Thank you for the information. A NAD amp looks like a good solution to my questions.
Thanks again
Siddhartha -
All current Denon, Marantz, and Harman Kardon receivers are capable of 4 ohm loads... I email all three companies a while back when looking for a receiver to power my MB Quart QLC-304's... I got a response back from their tech support that evening... Hope that helps.
AVKommonsense wrote: »All current Denon, Marantz, and Harman Kardon receivers are capable of 4 ohm loads... I email all three companies a while back when looking for a receiver to power my MB Quart QLC-304's... I got a response back from their tech support that evening... Hope that helps.
They're "capable" of it, that's the keyword. They aren't recommended to be used with 4 ohm loads though really. It puts a lot of unnecessary stress on the power section...and can ultimately lead to the amps shutdown circuit kicking in.The nirvana inducer-
Look at Outlaw Audio. They are having a pretty good sale right now on combo packages (pre/pro & amp).58" Samsung Plasma (on wall)(calibrated)
LSi15's front (modded xo's)
LSic center
LSiFX's sides
LSi7's rears
Sunfire Sig. 600 amp for 15's
Sunfire Sig. Cinema for C,S&R
Sony ES 3000 pre/pro
SVS 2039 PC Plus sub 12.3 (16hz tune)
PS3
Wii
Signal and Audioquest ic's
12 awg monster speaker-cable (bi-wired)
Belkin PF60 power conditioner
Monster power conditioner for sub -
i suggest check out ur local circuit city to see if they got any good receiver at GOOOOOOOD PRICE!! wont hurt u trying.
Didnt know there was drawing to win LSi 15's??? I would had enteredI am 100% BORN DEAF and No I am not kidding!
Why am I here? My wife's hearing!
My Home Theater Rig || Television: 58" Panasonic TH-58PZ800U Viera Plasma || Power Conditioner: Power Monster HTS 3600 MKII || Receiver: Onkyo TX-SR805 || Blu-Ray/Gaming: 60 Gigabytes Playstation 3 || Amplifier: Emotiva XPA-5 || Fronts: Polk Audio RT800i || Center: Polk Audio CS245i || Surrounds: TBA|| Subwoofer: TBA -
[QUOTE=Didnt know there was drawing to win LSi 15's??? I would had entered[/QUOTE]
Don't think he got it for free. Says he won it on eBay so he paid for it.Sunfire TGP, Sunfire Cinema Grand, Sunfire 300~2 (2), Sunfire True Sub (2),Carver ALS Platinum, Carver AL III, TFM-55, C-19, C-9, TX-8, SDA-490t, SDA-390t -
yamaha rx-z7The Gear... Carver "Statement" Mono-blocks, Mcintosh C2800 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon MiND2 Shunyata Triton
My amp was down for a while and I ran my 15's with my Marantz SR8001 which is a pretty stout AVR. It did an okay job if I hadn't been used to using my Sunfire amp. Make sure any AVR you get has pre-outs though, because it will be about 15 minutes before you want an amp. I would also be sure to get one that decodes the new HD audio codecs.My Main Gear
Mitsu HC5000 (Proj.)
Marantz SR8001 (AVR)
Sunfire TGA7200 (AMP)
Marantz DV7001 (SACD)
Samsung BD-P1500 Blu-Ray
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
DUAL SVS 20-39 CS Plus (Passive Subs)
Marantz IS201 I-Pod Dock[/SIZE]
Panamax M5300EX
Carada Criterion 106" Brightwhite Screen
Sunfire TGA 5200 & (4) B&W 605's in the party room -
Which receivers do you recommend? -
I personally love Marantz equipment and like the middle child SR6003. The Onkyo is also nice although I am kind of Marantz fan boy- I love the sexy look along with the terrific power. Shop around you may be able to find better prices on these guys. If you go with Onkyo I believe you can join club Onkyo using the link and save ten percent- btw I think that link is to a refurbished unit on the Onkyo.
http://us.marantz.com/Products/2515.asp
http://www.shoponkyo.com/detail.cfm?productid=TX-SR806&modelid=111&group_id=1&detail=1&ext_war=1My Main Gear
LSi 15's (Front)
LSiC (Center)
LSiFx (Surrounds)
Panamax M5300EX
Here is one:
welcome to CP, Sid.
If you don't want to go with an amp, Go with something like this. The Lsi's really shine with high amp power. Do a search on here. There is more to it then watts per channel.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
12.1 SVS driver in 4.53 cuft. tube
Harmony 880 -
Right now, my short term plan is to get a receiver which has the latest HT\audio capabilities and can drive a 4 ohm speaker system. Long term, in six months, I will get a power amp and use the receiver as a pre-amp.
I am looking into getting separates but everything I have seen so far is out of my price range. -
go seperates, go used. my .02Living Room 2 Channel -
Upstairs 2 Channel Rig -
Studio Rig - Scarlett 18i20(Gen3) DAW, Schitt Saga 2 preamp, Topping a90 headphone amp, Mac Mini, Audiophonics Hypex NC252m amp, Polk r200's -
Siddhartha wrote: »Right now, my short term plan is to get a receiver which has the latest HT\audio capabilities and can drive a 4 ohm speaker system. Long term, in six months, I will get a power amp and use the receiver as a pre-amp.
The problem in there are not many receivers out that will really handle load.
You could go for a receiver w/ pre-outs and add an amp but I would keep the volume to low levels until you add the amp.Michael
Samsung 50" HD DLP
Yamaha RX-V2500
(2) Outlaw 200
Adcom GFA 555
Sony BDP300
Denon 2900 DVD
Lsi9's mains
Lsi7's rear
Lsic center
Harmony 880
