Any truth here or all BS??
NotaSuv
NotaSuv Posts: 3,871
edited January 2009 in 2 Channel Audio
Post edited by NotaSuv on
  • Face
    Face Posts: 14,340
    edited January 2009
    Those will probably make a small difference, if any.
    Also, you can get them for cheaper elsewhere.
    F1nut Posts: 51,952
    edited January 2009
    It appears that MIT is aiming those at the HT inwall cable crowd. I don't know how they compare to the full blown cable versions with CVT couplers and MIT wire.
    http://www.mitcables.com/?option=com_virtuemart&page=shop.browse&category_id=7&Itemid=29
  • MillerLiteScott
    MillerLiteScott Posts: 2,564
    edited January 2009
    I wonder if the jumpers that they have would be a good match for those of us using AI-1 Avel transformer to make the connections to the speakers?
    I like speakers that are bigger than a small refrigerator but smaller than a big refrigerator:D
    F1nut Posts: 51,952
    edited January 2009
    Yep, been wondering that myself.
  • Face
    Face Posts: 14,340
    edited January 2009
    Are any of you able to make out the termination on those jumpers? I emailed MIT about it last night and am waiting on a response.
  • NotaSuv
    edited January 2009
    Would the speaker cable that these are attached too also have an effect on the sound ?
  • unc2701
    unc2701 Posts: 3,587
    edited January 2009
    Since the AVt modules have spring clips and most inwalls have spring clips, too, I'm guessing the jumpers are terminated w/ pins.
    Backburner:Krell KAV-300i
    F1nut Posts: 51,952
    edited January 2009
    NotaSuv wrote: »
    Absolutely, that's why I said I don't know how the end result would sound in comparision to full blown MIT cables.
    F1nut Posts: 51,952
    edited January 2009
    Face wrote: »
    Those are the ICONN bases, so you could use any of the ICONN ends.
  • mantis
    mantis Posts: 17,557
    edited January 2009
    I'm not into it at all, this means that they are basically saying there wire itself is meaningless or all wire is meaningless and the network is where it is all about.
    I'm not in on the magic boxes, make high quality wire not boxes to go onto the wire. I'm so not into it.
    Dan
  • Face
    Face Posts: 14,340
    edited January 2009
    Thanks Jesse, I'm having a hard time making them out on my monitor.
    F1nut Posts: 51,952
    edited January 2009
    mantis wrote: »
    I'm not getting it at all
    There, fixed it for you.
  • mantis
    edited January 2009
    I get it , I'm not "into" it.
    Dan
    F1nut Posts: 51,952
    edited January 2009
    Your loss.
