In-Ceiling surround speakers
jps
jps Posts: 23
I'm new to this, so I'd like to ask for some recommendations on in-ceiling surround speakers. I presently have two Bose 191 speakers mounted in the ceiling and I would like to install two more speakers to complete the room. Should I replace the Bose with a Polk LC80i? Does anyone have any experience on how these compare.
I have other floor standing Polk speakers and consider them among the best. However, the in-ceiling models are new to me. I appreciate any feedback.
Jim
Post edited by jps on
  • Eric W
    Eric W Posts: 556
    edited January 2009
    As much as I'd like to recommend Polks :) your system should be as consistent as possible. Sooo, you should match the rears to your fronts and vice versa.
    However, if you upgrade to LC80i (ideally, all the way around) I'm sure you'll hear a dramatic improvement.
    -Eric
    -Polk Audio
  • jps
    jps Posts: 23
    edited January 2009
    Thanks for the advice. Are the LC80fx speakers a better choice for HT?
  • Eric W
    Eric W Posts: 556
    edited January 2009
    For the rears, yes.
    -Eric
    -Polk Audio
  • jeeper_nick
    jeeper_nick Posts: 27
    edited January 2009
    Watch out for the ohm rating on the LC series - they are 4 ohm rated, so you will need an amplification source up to the task of driving them.
    But they are BADASS speakers! I am using three as my L/R/C surrounds.
    jps wrote: »
    Jim
    Coming Soon: The GregorPlex II Cinema
    Sanyo PLV-Z2000 Projector
    106" HDTV Formatted Electric-drop screen
    50" Samsung PN50A450
    Onkyo TX-SR876
    Emotiva UPA-7 Amplifier
    PlayStation3
    Monster HTS 3600 mkII
    *undetermined upconvert DVD player*
    Polk LC265i Fronts
    Polk LCiC Front Center
    Polk LC80i Rears
  • jps
    jps Posts: 23
    edited January 2009
    Thanks Jeeper I have an onkyo 601 (dated). Should I use lc80i's for the front and lc80fx for the rear?
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2009
    You should definitely replace the Bose with some Polks.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Montoya
    Montoya Posts: 506
    edited January 2009
    You should look at getting tc or rc series opposed to the lc series. Unless you plan on getting an amp to drive them. The lci is the better series but if your not running a separate amp you wouldn't be getting the nest out of those speakers.
    jps wrote: »
  • jps
    jps Posts: 23
    edited January 2009
    I plan to upgrade my receiver to the Onkyo 806. Based on what you are saying, this receiver would not drive the LC series properly? If not, then I'll replace the bose with TC or RC sereis speakers. I appreciate the advice from everyone.
  • wingnut4772
    wingnut4772 Posts: 7,519
    edited January 2009
    +1. I had them for my rear speakers and they sound great but make sure that you have an adequate amp. Especially if you run more than one pair.
    Sharp Elite 70
    Anthem D2V 3D
    Parasound 5250
    Parasound HCA 1000 A
    Parasound HCA 1000
    Oppo BDP 95
    Von Schweikert LCR 4 Center
    Totem Mask Surrounds X4
    Sony PS3
    Squeezebox Touch
