How to connect sub to older amp?
Big Dawg
Big Dawg Posts: 2,005
I have an Onkyo Integra integrated amp, model a-809. It's about 15 years old, and works great. I'm debating buying something like vintage polk sda speakers (for 2 channel audio), or getting something like RTia4 bookshelves and a sub like a PSW10.
Question: if I go the monitor-sub route, how do I connect the sub, via tape-out, speaker B terminals, or something else?
Post edited by Big Dawg on
  • comfortablycurt
    comfortablycurt Posts: 6,745
    edited January 2009
    You'd have to connect it to your main speaker outputs, and then connect your speakers to the sub.
    I'd go with the SDA's personally though, give your options.
    By the way...Welcome to Club Polk.
    The nirvana inducer-
    APC H10 Power Conditioner
    Parasound Halo P5 preamp
  • Big Dawg
    edited January 2009
    That makes sense!
  • comfortablycurt
    edited January 2009
    Also...you might want to look into a better sub than the PSW10 if you decide to go that route. The PSW10 is a good sub for it's price point...you'd really be better off going with something a bit better though. Possibly a PSW110 or PSW125. If you can swing a DSW series sub those are great too. You've gotta work within you're budget though of course.
  • rayslifecycle
    rayslifecycle Posts: 511
    edited January 2009
    Go for the SDA speakers - even with the SDA-CRS that I have - there is a healthy amount of base........positioning is key - and I am powering them with a similar age onkyo receiver......
