Homegrown Audio
Hobbyguy
Hobbyguy Posts: 317
I just purchased some 18 awg solid silver wire from homegrown audio and will be making some speaker cables out of it. Has anybody ever done this?
http://www.homegrownaudio.com/bulk_wire.htm
Post edited by Hobbyguy on
  • Pauly
    Pauly Posts: 4,519
    edited January 2009
    and how will you be making these? You doing double runs, nanner/spade terms? etc....
    Life without music would
  • Hobbyguy
    Hobbyguy Posts: 317
    edited January 2009
    planning on 4 wires per cable. 4 spades on one end 2 LOK SureGrip BFA on the other end.
  • Pauly
    Pauly Posts: 4,519
    edited January 2009
    So Bi-Wires?
  • Hobbyguy
    Hobbyguy Posts: 317
    edited January 2009
  • Hobbyguy
    Hobbyguy Posts: 317
    edited January 2009
    worthwhile or waste of time?
  • Pauly
    Pauly Posts: 4,519
    edited January 2009
    Hobbyguy wrote: »
    If you go enough wire wth not. Depends how far down the rabbit hole you want to go. Do a search on DIY wires on here, you will be up all night reading. Good luck. Let up know how they turn out.
    Pauly
  • ben62670
    ben62670 Posts: 15,969
    edited January 2009
    With the 18ga you are not going to want to biwire. You will want to star quad it for the equivalent of a single 15ga wire. That silver wire is not cheap. It takes almost 40 feet to make a pair of 3 foot IC's.
    Ben
    Ben
  • Pauly
    Pauly Posts: 4,519
    edited January 2009
    ben62670 wrote: »
    Ben
    Good point. Not much knowledge on silver. Only Copper...
    Pauly
  • Hobbyguy
    Hobbyguy Posts: 317
    edited January 2009
    Well maybe this will turn out into an expensive experiment. Here is the kit
  • Hobbyguy
    Hobbyguy Posts: 317
    edited January 2009
    Here is the first cable...12' . Bare ends so far.
  • Pauly
    Pauly Posts: 4,519
    edited January 2009
    Hobbyguy wrote: »
    Welcome to the Expensive Club :)
    Show us the after....
    Pauly
  • Hobbyguy
    Hobbyguy Posts: 317
    edited January 2009
    Here is one completed cable.
  • Hobbyguy
    Hobbyguy Posts: 317
    edited January 2009
    Here is my finished cable next to my audioquest biwire (made from Audiotruth forest+ [green cable] and Audioquest crystal [blue cable]). After listening to both I can't tell the difference. This tells me that:
    1)I need to listen to more music so I can learn to hear subtle differences
    2)My Yamaha RX-V2700 is somehow masking the difference...or is not good enough to listen to high quality music
    3)Maybe you don't need very thick cables if they are made of silver
    4)Maybe my audioquest cable is not very good
    To my ears the sound reproduction was very good so maybe i'll need somebody else's opinion with my solid silver speaker cable.
  • ben62670
    edited January 2009
    The insulation on the Silver is much thinner. The ga of the wire should be near the same. Let the Silver burn in for a while. It takes longer than copper. I run Silver on my highs, and AQ on My lows.
    Ben
