Homegrown Audio
Hobbyguy
I just purchased some 18 awg solid silver wire from homegrown audio and will be making some speaker cables out of it. Has anybody ever done this?
http://www.homegrownaudio.com/bulk_wire.htm
Post edited by Hobbyguy on
and how will you be making these? You doing double runs, nanner/spade terms? etc....Life without music would♭
planning on 4 wires per cable. 4 spades on one end 2 LOK SureGrip BFA on the other end.
yes...Bi wire
worthwhile or waste of time?
If you go enough wire wth not. Depends how far down the rabbit hole you want to go. Do a search on DIY wires on here, you will be up all night reading. Good luck. Let up know how they turn out.
PaulyLife without music would♭ -
With the 18ga you are not going to want to biwire. You will want to star quad it for the equivalent of a single 15ga wire. That silver wire is not cheap. It takes almost 40 feet to make a pair of 3 foot IC's.
Ben -
Ben
Good point. Not much knowledge on silver. Only Copper...
Well maybe this will turn out into an expensive experiment. Here is the kit
Here is the first cable...12' . Bare ends so far.
Welcome to the Expensive Club
Show us the after....
Here is my finished cable next to my audioquest biwire (made from Audiotruth forest+ [green cable] and Audioquest crystal [blue cable]). After listening to both I can't tell the difference. This tells me that:
1)I need to listen to more music so I can learn to hear subtle differences
2)My Yamaha RX-V2700 is somehow masking the difference...or is not good enough to listen to high quality music
3)Maybe you don't need very thick cables if they are made of silver
4)Maybe my audioquest cable is not very good
To my ears the sound reproduction was very good so maybe i'll need somebody else's opinion with my solid silver speaker cable. -
The insulation on the Silver is much thinner. The ga of the wire should be near the same. Let the Silver burn in for a while. It takes longer than copper. I run Silver on my highs, and AQ on My lows.Please. Please contact me a ben62670 @ yahoo.com. Make sure to include who you are, and you are from Polk so I don't delete your email. Also I am now physically unable to work on any projects. If you need help let these guys know. There are many people who will help if you let them know where you are.
Ben
